F01P050S05L
F01P050S05L
    TAMURA
    F01P050S05L
F01P050S05L 数据手册
Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F01P***S05L Features:        Backward compatible to F01PS05 series Anti-Surge current (4kAT, 8/20uS, single) Mounting area reduced ; pin compatible. Longitudinal dimension reduced Super precision & High Stability (low temperature, drift) Unipolar power voltage ; +5V Multi-range models F01P***S05L series are designed by the pin compatibility as high-end models of S22P***X05M2 series. Comparison of the main features of F******S05L series Series Features F01P***S05L No reference access F02P***S05L No reference access. Ref In/Out F03P***S05L No reference access. Ref In/Out. Higher creep age and clearance distance. *** = Rated Current Symbol Specification F01P***S05L Maximum Peak Current 4kAT (2kAx2. Number of primary tunes is two tunes) Rated Current If (***= rated current symbol) 6A(006) / 15A(015) / 25A(025) 50A(050) Maximum Current ±20A(If=6A) / ±51A(If=15A) / ±85A(If=25A) / ±150A(If=50A) Existence of reference access 0 Number of primary busbar 3 pcs Clearance distance ; Primary ↔Secondary 7.7 mm Standards UL508 (file#E243511) , EN501758, EN61010-1 , EN60950-1 Ambient Operating Temperature -40°C ~ +105°C Mounting Area The mounting area has been reduced more than the F01P series. However , F01P***S05L series are 100% compatible with original footprint mounting. F01PxxxS05LrevA Dec 2013 1 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F01P***S05L Absolute Maximum Rating Symbol Unit Value Vcc V 7 Primary Conductor Temperature - °C 110 ESD (HBM: Human Body Model) - kV 4 C=100pF , R=1.5kΩ Maximum Peak Current - kAT 4 Current Waveform :  Front time 8ųs  Time to half value 20ųs  Single Supply Voltage Notes Isolation Characteristics Symbol Unit Value Insulation Voltage Vd - AC4200V for 1 min. (Sensing Current 0.5mA) Primary↔Secondary Insulation Resistance Ris - ≥500mΩ (@DC500V) Primary↔Secondary Clearance distance dCi - 7.7mm (TYP) Primary↔Secondary Creep age distance dCp - 7.7mm (TYP) Primary↔Secondary - - UL94 V-0 CTI V 600 - - 300V , CAT Ⅲ , PD2 Reinforced Isolation Non uniform field according to EN50178 , EN61010 - - 600V , CAT Ⅲ , PD2 Simple isolation Non uniform field according to EN50178 , EN61010 Case material Comparative Tracking Index (CTI) Notes Application Example Environmental and Mechanical Characteristics Symbol Unit Value min typ max Ambient Operating Temperature Ta °C - 40 + 105 Ambient Storage Temperature Ts °C - 40 +105 - g Mass F01PxxxS05LrevA Dec 2013 12 2 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F01P***S05L Specification (*1) = Offset voltage value is after removal of core hysteresis Symbol Unit Value min Rated Current F01P006S05L F01P015S05L F01P025S05L If 15 A 25 50 F01P006S05L F01P015S05L F01P025S05L Ipmax A F01P050S05L Supply Voltage Vcc V Number of primary turns Np T Number of secondary turns - 20 20 - 51 51 - 85 85 - 150 150 4.75 Ns 1737 T 1764 F01P050S05L 1600 F01P006S05L 25 F01P015S05L F01P025S05L Icc 30 mA 55 Output Voltage Vo V Output Voltage (Ip=0A) Vo V F01P006S05L 4.625 2.5 10.40 - 7.10 7.10 - 6.25 6.25 F01P050S05L - 5.80 5.80 F01P006S05L - 0.10 0.10 - 0.17 0.17 - 0.25 0.25 - 0.46 0.46 F01P025S05L Voe mV F01P015S05L F01P025S05L F01P050S05L F01PxxxS05LrevA Dec 2013 0.375 - 10.40 F01P015S05L Electrical Offset Current referred to primary Icc=15+Ip(mA) / Ns 35 F01P050S05L Electrical Offset Voltage (*1 ) 5.25 1816 F01P015S05L Consumption current (at If) 5.00 1,2,3 F01P006S05L F01P025S05L max 6 F01P050S05L Maximum Current (@ Vcc : +5V , Ta : +105°C) typ Notes Ioe A 3 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F01P***S05L Specification Symbol Unit Value min Temperature coefficient of Output voltage (@ Ip=0A) typ max ±10.0 ±80.0 ±7.5 ±70.0 ±6.5 ±60.0 F01P050S05L ±6.0 ±60.0 F01P006S05L 104.2 F01P006S05L F01P015S05L F01P025S05L Sensitivity (Theoretical value) TCVo ppm/K F01P015S05L F01P025S05L Sensitivity Error Temperature coefficient of Sensitivity (@Ta=-40°C~+105°C) Output Linearity Magnetic offset current referred to primary (@ 10xIf) F01P006S05L mV/A ᵋG % TCG ppm/K ᵋL % - 0.1 0.1 Iom A - 0.1 0.1 Ino ųA/ (Hz)1/2 ±40 36 F01P050S05L 300 - mV RL=1kΩ 40 160 F01P015S05L 15 60 F01P025S05L 10 40 F01P050S05L 5 20 F01P006S05L RL=1kΩ 0.3 RL=1kΩ, di/dt=18A/ųs 0.3 RL=1kΩ, di/dt=44A/ųs 0.3 RL=1kΩ, di/dt=68A/ųs F01P050S05L 0.3 RL=1kΩ, di/dt=100/ųs F01P006S05L 0.3 RL=1kΩ, di/dt=18A/ųs 0.3 RL=1kΩ, di/dt=44A/ųs 0.3 RL=1kΩ, di/dt=68A/ųs 0.3 RL=1kΩ, di/dt=100/ųs F01P025S05L tra ųs F01P015S05L F01P025S05L F01P050S05L F01PxxxS05LrevA Dec 2013 0.7 150 F01P015S05L Response time (@90% of If) - 0.7 F01P025S05L (f typ=450kHz) Reaction time (@ 10% of If) 12.5 90 F01P006S05L 625mV/If 25 F01P015S05L Peak to peak output ripple at oscillator frequency ppm/K of 2.5V ( -40°C~+105°C) 41.67 Gth F01P050S05L Output current noise referred to primary (@ 100Hz~100kHz) Notes tr ųs 4 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F01P***S05L Specification Symbol Unit Value min typ Comment max Response time 2 (@ 10% of If to 90% of Vo) Frequency bandwidth (± 1dB) Frequency bandwidth (± 3dB) Output Voltage Accuracy (Overall) tr ųs 0.6 BW kHz 200 RL=1kΩ BW kHz 300 RL=1kΩ F01P006S05L F01P015S05L RL=1kΩ 2.5 XG % 1.9 F01P025S05L 1.8 F01P050S05L 1.7 XG=(100xVoe/625)+ԐG+ԐL Standards EN 50178; EN 61010-1 ; EN 60950-1 ; UL 508 (file no. E243511) Characteristic Curve (TYP) F01PxxxS05LrevA Dec 2013 5 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F01P***S05L Maximum Continuous DC primary current According to which the following conditions are true the maximum continuous DC primary current plot shows the boundary of the area. 1. Ip < Ipmax 2. Junction temperature Tj < 125ºC 3. Primacy conductor temperature < 110°C 4. Resistor power dissipation < 0.5 x rated power Frequency Derating Figure 7 : Maximum RMS AC primary current / maximum DC primary current vs frequency F01PxxxS05LrevA Dec 2013 6 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F01P***S05L Connection Dimension (mm) Recommended Hole Diameter (mm) F01PxxxS05LrevA Dec 2013 7
F01P050S05L 价格&库存
很抱歉,暂时无法提供与“F01P050S05L”相匹配的价格&库存,您可以联系我们找货
F01P050S05L
  • 1+126.099901+16.31439
  • 5+114.521425+14.81641
  • 10+110.2190310+14.25978
  • 25+105.0799025+13.59489
  • 50+101.5653150+13.14019
  • 400+92.67405400+11.98987
  • 800+90.18499800+11.66784
库存:1111
