L06P800S05
L06P800S05
    TAMURA
    Module
    Current Sensor 800A 1 Channel Hall Effect, Open Loop Bidirectional Module
L06P800S05 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L06P***S05 Series Features:        Advantage: Open Loop type Printed circuit board mounting Horizontal mounting Unipolar power supply Industrial temperature range Mounting pins Insulated plastic case according to UL94V0         Excellent accuracy and linearity Wide nominal current range Low temperature drift Wide frequency bandwidth No insertion loss High Immunity To External Interference Optimised response time Current overload capability Specifications TA=25ºC, VCC=+5V, RL=10kΩ Parameters Symbol L06P400S05 L06P600S05 L06P800S05 If 400AT 600AT 800AT Primary nominal current Saturation current Ifmax ≥ ± If x 1.33 Rated output voltage Vo Vof +1.5V ± 0.035V (at If) Offset voltage1 Vof VREF1 ± 30mV (at If = 0A) Output linearity2(0A~If) εL ≤ ± 1% (at If) Power supply voltage VCC + 5V ± 0.1V Consumption current ICC ≤ 15mA tr ≤ 5μs (at di/dt = 100A / μs) Thermal drift of gain4 TcVo ≤ ± 1.5mV/ºC Thermal drift of offset TcVof ≤ ± 1.0 mV/ºC Hysteresis error VOH ≤ 10mV (at If = 0A→If →0A) Insulation voltage Vd AC2500V for 1minute (sensing current 0.5mA), inside of through hole  terminal Insulation resistance RIS ≥ 500MΩ(at DC500V), inside of through hole  terminal TA -40ºC~+85ºC Response time3 Ambient operation temperature Ambient storage temperature -40ºC~+85ºC TS 1 2 3 VREF = VCC / 2 (ratiometric) . After removal of core hysteresis— Without offset — Time between 90% input current full scale and 90% of sensor output full scale— 4 Without Thermal drift of offset Electrical Performances Frequency characteristic(L06P400S05) 5.0 6 4.5 4 4.0 2 Output voltage (V) Attenuation (dB) Saturation characteristic(L06P400S05) 0 -2 -4 -6 3.5 3.0 2.5 2.0 1.5 -8 1.0 -10 0.5 0.1 1 10 Frequency characteristic(kHz) @ If=40AT(Arms) L06PXXXS05revE, March 2012 100 0.0 -800 TA=25ºC Pulsed -600 -400 -200 0 200 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 400 600 800 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L06P***S05 Series Mechanical dimensions NOTES 1. Unit is mm 2. Tolerance is 0.5mm Terminal Number: 1: VOUT 2: GND 3: +VCC(+5V) Electrical connection diagram -If +If 321 VOUT + VCC RL = 10k GND Package & Weight Information L06PXXXS05revE, March 2012 Weight Pcs/box Pcs/carton Pcs/pallet 65g 100 500 4800 Tamura reserve the right to modify its products in order to improve them without prior notice
L06P800S05 价格&库存
很抱歉,暂时无法提供与“L06P800S05”相匹配的价格&库存,您可以联系我们找货
