L18P030S05R
L18P030S05R
    TAMURA
    Module
    SENSOR CURRENT HALL 30A AC/DC
L18P030S05R 数据手册
Hall Effect Current Sensors L18P***S05R Series Features: Advantages:               Open Loop type Printed circuit board mounting Integrated primary Unipolar power supply Busbar version from 40A to 60A Insulated plastic case according to UL94V0  Regulated offset voltage Excellent accuracy and linearity Wide nominal current range Low temperature drift Wide frequency bandwidth No insertion loss High Immunity To External Interference Optimised response time Current overload capability Specifications TA=25ºC, VCC=+5V, RL=10kΩ Parameters Symbol Rated current If L18P003S05R L18P005S05R L18P010S05R L18P015S05R L18P020S05R L18P025S05R L18P030S05R L18P040S05R L18P050S05R L18P060S05R 3A 5A 10A 15A 20A 25A 30A 40A 50A Maximum Current Ifmax If x 3 Output Voltage VOUT VOE ± 0.625V ± 0.045V @ ± If Offset Voltage1 VOE 2.5V ± 0.035V @ If = 0A Accuracy @ If X ± 1% Output Linearity εL ≤ ± 1% @ If Power Supply VCC +5V ± 5% Consumption Current IC ≤ 15mA Response Time3 tr ≤ 5μs (@ di/dt = If / μs) TCVOUT ≤ ± 2.0mV/ºC TCVOE ≤ ± 2.0mV/ºC VOH ≤ 25mV (0A  If) Vd AC 3000V for 1minute (sensing current 0.5mA), primary pin  secondary pin RIS > 500MΩ (500V DC), primary pin  secondary pin f DC .. 50kHz Operating Temperature TA -10ºC~+80ºC Storage Temperature TS -20ºC~+85ºC 2 Output Temperature Characteristic2 Offset Temperature Characteristic Hysteresis error Withstand Voltage Insulation Resistance Frequency Bandwidth 1 4 4 60A VOE is fixed (independent of VCC) — 2 Without offset — 3 Time between 10% input current full scale and 90% of sensor output full scale — Small signal only to avoid excessive heating of magnetic core Electrical Performances Saturation Characteristic (L18P060S05R) Frequency Characteristic (L18P060S05R) 2,0 5,0 Output Voltage (V) Attenuation (dB) 0,0 -2,0 -4,0 -6,0 -8,0 4,0 3,0 2,0 1,0 0,0 -10,0 0,1 1 10 If frequency (kHz) @ If=3.0Arms L18PXXXS05RrevA, May 2013 100 -300 -200 -100 0 100 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 200 300 Hall Effect Current Sensors L18P***S05R Series Mechanical dimensions in mm L18P S05R S05R 17.5 L18P Terminal Pin Identification 1: GND 2: GND 3: +VCC 4: Output 5: Primary input current (+) 6: Primary input current (–) 15 3 5±1 14.4 15.2 17 1.3 φD φ0.6 φ0.8 φ1.1 φ1.4 φ1.6 5 5 (+) 4 3 2 1 4 - 0.25x0.5 1 5.4 8.8 2.8 5 (+) 6 (-) 18 MAX 6 (-) 1 11 6 4 1.5 18 MAX 4 3 2 1 3 A 3A 5A 10A 15A 20A~30A NOTES 1. Unit is mm 2. Tolerance is 0.5mm 3. Cover is optional 4 - 0.25x0.5 2.54 7.62 Electrical connection diagram +If +VCC –If GND RL = 10kΩ VOUT Package & Weight Information L18PXXXS05RrevA, May 2013 Weight Pcs/box Pcs/carton Pcs/pallet 8g 100 600 9600 Tamura reserve the right to modify its products in order to improve them without prior notice
L18P030S05R 价格&库存
很抱歉,暂时无法提供与“L18P030S05R”相匹配的价格&库存,您可以联系我们找货
L18P030S05R
  • 600+57.45538600+7.43930
