L07P030D15
L07P030D15
    TAMURA
    Module
    SENSOR CURRENT HALL 30A AC/DC
L07P030D15 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L07P***D15 Series Features: Advantage:      Open Loop type Dual integrated primary Bipolar power supply Printed circuit board mounting Insulated plastic case according to UL94V0  UL Recognition         Excellent accuracy and linearity Wide nominal current range Low temperature drift Wide frequency bandwidth No insertion loss High Immunity To External Interference Optimised response time Current overload capability Specifications TA=25ºC, VCC=±15V, RL=10kΩ Parameters Symbol L07P003D15 L07P005D15 L07P010D15 L07P015D15 L07P020D15 L07P025D15 L07P030D15 3A If Primary nominal current 5A 10A 15A 20A 25A 30A Ifmax ≥ ± If x 3 Rated output voltage Vo 4V ±0.060V (at If) Offset voltage1 Vof ≤ ±0.060V (at If = 0A) Output linearity2(0A~If) εL ≤ ±1% (at If) Power supply voltage VCC ±15V±5% Consumption current IC ≤ ±30mA Response time3 tr ≤ 5μs (at di/dt = If / µs) Thermal drift of gain4 TcVo ≤ ±0.1% / ºC Thermal drift of offset TcVof ≤ ±2.5mV / ºC VOH ≤ 30mV (at If = 0A→If →0A) Insulation voltage Vd AC2000V for 1minute (sensing current 0.5mA), primary  secondary Insulation resistance RIS ≥ 500MΩ(at DC500V), primary  secondary TA -30ºC~+80ºC Saturation current Hysteresis error Ambient operation temperature Ambient storage temperature -40ºC~+85ºC TS 1 2 3 After removal of core hysteresis— Without offset — Time between 10% input current full scale and 90% of sensor output full scale. each channel's value,non-measured circuit is set to 0A. — 4 Without Thermal drift of offset Electrical Performances Saturation characteristic Frequency characteristic(L07P010D15) 15 6 10 2 Output voltage (V) Attenuation (dB) 4 0 -2 -4 -6 5 0 L07P003D15 L07P015D15 -5 L07P025D15 -8 -10 TA=25ºC Pulsed -10 0.1 1 10 Frequency characteristic(kHz) @ If=3Arms L07PXXXD15revC, March 2012 100 -15 -100 -80 -60 -40 -20 0 20 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 40 60 80 100 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L07P***D15 Series Mechanical dimensions Terminal Function 1 +VCC(+15V) 2 -VCC(-15V) 3 VOUT1 4 VOUT2 5 GND 6 Primary input current1 (+) 7 Primary input current1 (-) 8 Primary input current2 (+) 9 Primary input current2 (-) 4±1 11.2 12 NOTES 1. Unit is mm 2. Tolerance is 0.5mm 25 φD φ0.6 φ0.8 φ1.4 φ1.6 3.6 7.2 UL 508 , CSA C22.2 No.14 (UL FILE No.E243511) 54321 VOUT1 VOUT2 • For use in Pollution Degree 2 Environment. • Maximum Surrounding air temperature rating, 80˚C. 8 +If2 +VCC -VCC 5 rectangular pins 0.25x0.5 UL Standard 6 7 -If1 6 5 4 3 2 1 Electrical connection diagram +If1 7 1.5 A 3A 5A 10~15A 20~30A 8 4.75 16 9 9.4 11.2 4.75 RL = 10kΩ 9 -If2 GND Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 12g 100 400 12800 L07PXXXD15revC, March 2012 Tamura reserve the right to modify its products in order to improve them without prior notice
L07P030D15 价格&库存
很抱歉,暂时无法提供与“L07P030D15”相匹配的价格&库存,您可以联系我们找货
