L08P200D15W
L08P200D15W
    TAMURA
    L08P200D15W
L08P200D15W 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L08P***D15W / IPV Features: Advantages:             Open Loop type Printed circuit board mounting 4 pin PCB connection Bipolar power supply Extended measurement range Insulated plastic case according to UL94V0 Excellent accuracy Very good linearity Low temperature drift No insertion loss High Immunity To External Interference Current overload capability Specifications TA=25ºC, VCC=±15V, RL=10kΩ Parameters Primary nominal current Saturation current Symbol L08P100D15IPV L08P200D15W L08P300D15IPVW If 100AT 200AT 300AT Ifmax ≥ ±300AT ≥ ±600AT ≥ ±600AT Rated output voltage Vo 4V ±0.040V (at If) Offset voltage1 Vof ≤ ± 0.030V (at If = 0A) Output linearity2(0A~If) εL ≤ ±1% (at If) Power supply voltage VCC ±15V ± 5% Consumption current Icc ≤ 20mA tr ≤ 5μs (at di/dt = 100A / μs) Thermal drift of gain4 TcVo ≤ ± 0.05% /ºC Thermal drift of offset TcVof ≤ ± 1.0mV /ºC VOH ≤ 20mV (at If=0A→If→0A) Insulation voltage Vd AC 2500V for 1minute (sensing current 0.5mA), inside of through hole  terminal Insulation resistance RIS ≥ 500MΩ (at DC500V), inside of through hole  terminal Ambient operation temperature TA -20ºC ~ +80ºC Ambient storage temperature TS -25ºC ~ +85ºC Response time3 Hysteresis error 1 After removal of core hysteresis— 2 Without offset —3 Time between 10% input current full scale and 90% of sensor output full scale — Thermal drift of offset 4 Without Electrical Performances Frequency characteristic(L08P300D15IPVW) 10 6 8 4 6 2 Output voltage (V) Attenuation (dB) Saturation characteristic(L08P300D15IPVW) 0 -2 -4 -6 4 2 0 -2 -4 -8 -6 -10 -8 0.1 1 10 Frequency characteristic(kHz) @ If=3(Arms) L08P***D15W/IPVrevB, March 2012 100 -10 -800 TA=25ºC Pulsed -600 -400 -200 0 200 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 400 600 800 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L08P***D15W / IPV Mechanical dimensions L08P100D15IPV L08P200D15W L08P300D15IPVW 4 7.5 4 - φ1.2 2.5 Electrical connection diagram 6 2 - φ2.5 NOTES 1. Unit is mm 2. Tolerance is 0.5mm 3.5 19 Circuit board hole dimension (View of solder side) Terminal number: 1. +VCC(+15V) 2. -VCC (-15V) 3. VOUT 4. GND Package & Weight Information VOUT -VCC +VCC -If GND L08P***D15W/IPVrevB, March 2012 +If Weight Pcs/box Pcs/carton Pcs/pallet 20g 50 500 9000 Tamura reserve the right to modify its products in order to improve them without prior notice
L08P200D15W 价格&库存
很抱歉,暂时无法提供与“L08P200D15W”相匹配的价格&库存,您可以联系我们找货
