Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors L08P***D15W / IPV
Features:
Advantages:
Open Loop type
Printed circuit board mounting
4 pin PCB connection
Bipolar power supply
Extended measurement range
Insulated plastic case according
to UL94V0
Excellent accuracy
Very good linearity
Low temperature drift
No insertion loss
High Immunity To External Interference
Current overload capability
Specifications
TA=25ºC, VCC=±15V, RL=10kΩ
Parameters
Primary nominal current
Saturation current
Symbol
L08P100D15IPV
L08P200D15W
L08P300D15IPVW
If
100AT
200AT
300AT
Ifmax
≥ ±300AT
≥ ±600AT
≥ ±600AT
Rated output voltage
Vo
4V ±0.040V (at If)
Offset voltage1
Vof
≤ ± 0.030V (at If = 0A)
Output linearity2(0A~If)
εL
≤ ±1% (at If)
Power supply voltage
VCC
±15V ± 5%
Consumption current
Icc
≤ 20mA
tr
≤ 5μs (at di/dt = 100A / μs)
Thermal drift of gain4
TcVo
≤ ± 0.05% /ºC
Thermal drift of offset
TcVof
≤ ± 1.0mV /ºC
VOH
≤ 20mV (at If=0A→If→0A)
Insulation voltage
Vd
AC 2500V for 1minute (sensing current 0.5mA), inside of through hole terminal
Insulation resistance
RIS
≥ 500MΩ (at DC500V), inside of through hole terminal
Ambient operation temperature
TA
-20ºC ~ +80ºC
Ambient storage temperature
TS
-25ºC ~ +85ºC
Response time3
Hysteresis error
1
After removal of core hysteresis— 2 Without offset —3 Time between 10% input current full scale and 90% of sensor output full scale —
4
Without
Electrical Performances
Frequency characteristic(L08P300D15IPVW)
10
6
8
4
6
2
Output voltage (V)
Attenuation (dB)
Saturation characteristic(L08P300D15IPVW)
-4
-6
4
2
-4
-8
-6
-10
-8
0.1
1
10
Frequency characteristic(kHz)
@ If=3(Arms)
L08P***D15W/IPVrevB, March 2012
100
-10
-800
TA=25ºC Pulsed
-600
-400
-200
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
400
600
800
Mechanical dimensions
L08P100D15IPV
L08P200D15W
L08P300D15IPVW
4
7.5
4 - φ1.2
2.5
Electrical connection diagram
6
2 - φ2.5
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
3.5
19
Circuit board hole dimension
(View of solder side)
Terminal number:
1. +VCC(+15V)
2. -VCC (-15V)
3. VOUT
4. GND
Package & Weight Information
VOUT
-VCC
+VCC -If
GND
+If
Weight
Pcs/box
Pcs/carton
Pcs/pallet
20g
50
500
9000
很抱歉,暂时无法提供与“L08P100D15IPV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+98.974841+12.80504
