F03P025S05D
F03P025S05D
    TAMURA
    F03P025S05D
F03P025S05D 数据手册
            CURRENT SENSORS Fluxgate system / Voltage-output type F03P***S05 SERIES rev A / May 2013 ABSOLUTE MAXIMUM RATINGS Parameters Supply voltage Primary conductor temperature Non repetitive primary current pulse(20μS),in powered or unpowered state. ESD(HBM: Human Body Model) Unit Value Vcc V 7 ― ℃ 110 Îp A 20 × If ― kV 4 Symbol Unit Vd ― RIS ― ≧ 500MΩ(at DC500V) Primary ⇔ Secondary dCi ― 8.2mm(TYP) Primary ⇔ Secondary dCp ― 8.2mm(TYP) Primary ⇔ Secondary ― ― UL94 V-0 CTI V 600 ― ― 300V,CAT Ⅲ,PD2 Reinforced isolation,non uniform field according to EN61010 ― ― 600V,CAT Ⅲ,PD2 Reinforced isolation,non uniform field according to EN50178 ― ― 1000V,CAT Ⅲ,PD2 Symbol Unit Ta Symbol Comment C=100pF,R=1.5kΩ ISOLATION CHARACTERISTICS Parameters lnsulation voltage lnsulation Resistance Clearance distance Creepage distance Case material Comparative Tracking Index; (CTI) Application example Value Comment AC4300V,for 1minute(Sensing current 0.5mA)  Primary ⇔ Secondary Simple isolation,non uniform field according to EN50178 ENVIRONMENTAL AND MECHANICAL CHARACTERISTICS Parameters Ambient operating temperature Ambient storage temperature Mass Value MIN TYP MAX ℃ -40 +105 TS ℃ -40 +105 m g 12 Comment            CURRENT SENSORS SPECIFICATIONS Ta=+25℃,RL=10kΩ,Vcc=+5V Parameters Rated Current F03P006S05 Symbol Unit If A Value MIN 15 F03P025S05 25 F03P006S05 50 Ipmax A F03P015S05 20 -51 51 -85 85 F03P050S05 -150 150 Number of primary turns Number of secondary turns -20 F03P025S05 Supply Voltage F03P006S05 4.75 V Np T 1,2,3,4 Ns T 1816 1737 F03P025S05 1764 F03P025S05 35 F03P050S05 55 Output voltage Output voltage(at Ip=0A) Electrical offset current reffered to primary Temperature coefficient of Sensitivity(at Ta=-40℃~+105℃) Output Linearity(at If) Magnetic offset current reffered to primary(at 10×If) Output current noise reffered to primary(at 100Hz~100kHz)   Offset voltage value is after removal of core hysteresis. 2.505 Vref2 V 0 4 Vo V 0.375 4.625 Vo V Voe mV 5.300 F03P015S05 -2.210 2.210 F03P025S05 -1.350 1.350 F03P050S05 -0.725 0.725 F03P006S05 -51 51 F03P015S05 -53 53 F03P025S05 -54 54 Ioe mA Ref OUT mode Ref IN mode Vref1,Vref2 -58 58 TCVref1 ppm/K ±5.0 ±50 TCVo ppm/K ±6.0 ±14 ppm/K of 2.5V F03P015S05 ±2.3 ±6 (-40℃~+105℃) F03P025S05 ±1.4 ±4 F03P050S05 ±0.7 ±3 F03P006S05 F03P006S05 Gth 104.2 mV/A F03P015S05 41.67 F03P025S05 25 625mV/If 12.5 F03P050S05 Sensitivity error 2.500 V -5.300 F03P006S05 Temperature coefficient of Internal reference voltage Sensitivity(Theoretical value) 2.495 Icc=15+Ip(mA)/Ns Vref1 F03P050S05 Temperature coefficient of Output voltage(at Ip=0A) 25 mA 30 External reference voltage Electrical offset voltage Icc F03P015S05 Internal reference voltage(at Ip=0A) 5.25 1600 F03P050S05 Consumption current (at If) 5.00 Vcc F03P015S05 F03P006S05 Comment MAX 6 F03P015S05 F03P050S05 Maximum current TYP -0.7 εG % TCG ppm/K εL % -0.1 IOM A -0.1 Ino μA/(Hz)1/2 0.7 ±40 0.1 0.1 20 RL=1kΩ             CURRENT SENSORS SPECIFICATIONS Ta=+25℃,RL=10kΩ,Vcc=+5V Parameters Peak to peak output ripple at oscillator freqency(f typ=450kHz) Symbol Unit ― mV Value MIN 40 160 15 60 F03P025S05 10 40 5 RL=1kΩ 20 RL=1kΩ,di/dt=18A/μs F03P015S05 0.3 RL=1kΩ,di/dt=44A/μs F03P025S05 0.3 RL=1kΩ,di/dt=68A/μs F03P050S05 0.3 RL=1kΩ,di/dt=100A/μs 0.3 RL=1kΩ,di/dt=18A/μs F03P015S05 0.3 RL=1kΩ,di/dt=44A/μs F03P025S05 0.3 RL=1kΩ,di/dt=68A/μs F03P050S05 0.3 RL=1kΩ,di/dt=100A/μs 0.6 RL=1kΩ,di/dt=If/μs F03P006S05 Response time 2 (at 10% of If to 90% of Vo ) Frequency bandwidth(±1dB) Frequency bandwidth(±3dB) F03P006S05 Output Voltage Accuracy(Overall) Comment 0.3 F03P006S05 Response time 1 (at 90% of If ) MAX F03P015S05 F03P006S05 F03P050S05 Reaction time(at 10% of If ) TYP tra tr μs μs tr μs BW kHz 200 RL=1kΩ BW kHz 300 RL=1kΩ XG % XG=(100×Voe/625)+εG+εL 1.7 F03P015S05 1.2 F03P025S05 1.0 F03P050S05 0.9 STANDARDS EN50178,EN61010-1,EN60950-1,UL508(file №E243511)       ※Please refer to the another sheet about conditions of UL Recognition. Characteristic curve(TYP) Ip Output Voltage Vo[V] 5 (4.625) 2.5 (=Vref1) Primary current Ip[A] (0.375) -Ipmax (≒-If×3) -If 0 If Ipmax (≒If×3)           Figure 1:Linearity curve(Internal reference voltage)                   Figure 2:Frequency response curve      ex)F03P025S05 Measurement condition Ta=+25℃,RL=1kΩ,Ip=3A,Vcc=+5V             CURRENT SENSORS SUPPORT DOCUMENTATION Ip(A)          Figure 3:Ip vs Ta for F03P006S05         Figure 5:Ip vs Ta for F03P025S05 Ip(A) Figure 4:Ip vs Ta for F03P015S05 Ip(A) Ip(A) Maximum continuous DC primary current Figure 6:Ip vs Ta for F03P050S05 According to which the following conditions are true the maximum continuous DC primary current plot shows the boundary of the area.   ①Ip < Ipmax   ②Junction temperature Tj < 125℃   ③Primary conductor temperature < 110℃   ④Resistor power dissipation < 0.5 x rated power Frequency derating    Figure 7:Maximum RMS AC primary current/maximum DC primary current vs frequency             CURRENT SENSORS  Reference voltage    The Ref pin has two modes Ref IN and Ref OUT:    <Ref OUT mode>    The 2.5V internal precision reference is used by the transducer as the reference point for bipolar measurements;    <Ref IN mode>    An external reference voltage is connected to the Ref pin; this voltage is specified in the range 0 to 4 V ,    its voltage is used as the reference voltage at the time of measurement.       -either to source a typical current of (Vref-2.5)/680,the maximum value will be 2.2mA typ.when Vref2=4V.       -or to sink a typical current of (2.5-Vref2)/680,the maximum value will be 3.68mA typ.when Vref2=0V. Ip(A) Ip(A)     The following graphs show how the measuring range of each transducer version depends on external reference voltage value Vref2. (Vref2=0...4V)       Upper limit: Ip = 85     (Vref2=0...2.5V)                         Ip =-40×Vref2+185 (Vref2=2.5...4V)       Lower limit: Ip =-40×Vref2+15 (Vref2=0...2.5V)                         Ip =-85     (Vref2=2.5...4V) If you do not want to use the Ref pin, please unconnected. Upper limit: Ip =80          (Vref2=0...1.29V)                   Ip =-24×Vref2+111(Vref2=1.29...4V) Lower limit: Ip =-24×Vref2+9 (Vref2=0...3.7V)                   Ip =-80          (Vref2=3.7...4V) Ip(A) (Vref2=0...4V)       Lower limit: Ip =-9.6×Vref2+3.6 Ip(A)       Upper limit: Ip =-9.6×Vref2+44.4 Upper limit: Ip =150    (Vref2=0...2.75V)                   Ip =-80×Vref2+370 (Vref2=2.75...4V) Lower limit: Ip =-80×Vref2+30 (Vref2=0...2.25V)                   Ip =-150        (Vref2=2.25...4V)             CURRENT SENSORS CONNECTION IN 2,3,4,5 Ip Int REF 14 680Ω 13 6,7,8,9 10kΩ OUT 40kΩ DIMENSIONS(mm) RECOMMENDED HOLE DIAMETER(mm) 8 7 6 2 3 4 5 9 8 7 6 1Ω 12 2 3 4 5 9 8 7 GND 6 Vo Vref 2 3 4 5 OUT IN 10pF 11 OUT IN If/2 + Rm 10kΩ 9 If/4 40kΩ OUT Vcc If IN OUT
F03P025S05D 价格&库存
很抱歉,暂时无法提供与“F03P025S05D”相匹配的价格&库存,您可以联系我们找货
