F02P006S05L
F02P006S05L
    TAMURA
    F02P006S05L
F02P006S05L 数据手册
Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F02P***S05L Features:       Backward compatible to F02PS***05 series Anti-Surge current (4kAT, 8/20uS, single) Mounting area reduced ; pin compatible. Longitudinal dimension reduced Super precision & High Stability (low temperature, drift) Unipolar power voltage ; +5V Multi-range models Comparison of the main features of F******S05L series Series Features F01P***S05L No reference access F02P***S05L No reference access. Ref In/Out F03P***S05L No reference access. Ref In/Out. Higher creep age and clearance distance. *** = Rated Current Symbol Specification F02P***S05L Maximum Peak Current 4kAT (2kAx2. Number of primary tunes is two tunes) Rated Current If (***= rated current symbol) 6A(006) / 15A(015) / 25A(025) 50A(050) Maximum Current ±20A(If=6A) / ±51A(If=15A) / ±85A(If=25A) / ±150A(If=50A) Existence of reference access Yes Number of primary busbar 3 pcs Clearance distance ; Primary ↔Secondary 7.5 mm Standards UL508 (file#E243511) , EN501758, EN61010-1 , EN60950-1 Ambient Operating Temperature -40°C ~ +105°C Mounting Area The mounting area has been reduced more than the F02P series. However , F02P***S05L series are 100% compatible with original footprint mounting. F02PxxxS05LrevA Dec 2013 1 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F02P***S05L Absolute Maximum Rating Symbol Unit Value Vcc V 7 Primary Conductor Temperature - °C 110 ESD (HBM: Human Body Model) - kV 4 C=100pF , R=1.5kΩ Maximum Peak Current - kAT 4 Current Waveform :  Front time 8ųs  Time to half value 20ųs  Single Supply Voltage Notes Isolation Characteristics Symbol Unit Value Insulation Voltage Vd - AC4100V for 1 min. (Sensing Current 0.5mA) Primary↔Secondary Insulation Resistance Ris - ≥500mΩ (@DC500V) Primary↔Secondary Clearance distance dCi - 7.5mm (TYP) Primary↔Secondary Creep age distance dCp - 7.5mm (TYP) Primary↔Secondary - - UL94 V-0 CTI V 600 - - 300V , CAT Ⅲ , PD2 Reinforced Isolation Non uniform field according to EN50178 , EN61010 - - 600V , CAT Ⅲ , PD2 Simple isolation Non uniform field according to EN50178 , EN61010 Case material Comparative Tracking Index (CTI) Application Example Notes Environmental and Mechanical Characteristics Symbol Unit Value min typ max Ambient Operating Temperature Ta °C - 40 + 105 Ambient Storage Temperature Ts °C - 40 +105 - g Mass F02PxxxS05LrevA Dec 2013 12 2 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F02P***S05L Specification (*1) = Offset voltage value is after removal of core hysteresis Symbol Unit Value min Rated Current F02P006S05L F02P015S05L F02P025S05L If 15 A 25 50 F02P006S05L F02P015S05L F02P025S05L Ipmax A F02P050S05L Supply Voltage Vcc V Number of primary turns Np T Number of secondary turns - 20 20 - 51 51 - 85 85 - 150 150 4.75 Ns 1737 T 1764 F02P050S05L 1600 F02P006S05L 25 F02P015S05L F02P025S05L 5.25 1816 F02P015S05L Consumption current (at If) 5.00 1,2,3 F02P006S05L F02P025S05L max 6 F02P050S05L Maximum Current (@ Vcc : +5V , Ta : +105°C) typ Notes Icc 30 mA Icc=15+Ip(mA) / Ns 35 F02P050S05L 55 Internal Reference Voltage (@Ip=0A) Vref1 V 2.495 External Reference Voltage Vref2 V 0 4 Vo V 0.375 4.625 Vo V Output Voltage Output Voltage (Ip=0A) Electrical Offset Voltage (*1 ) F02P006S05L - 2.210 2.210 - 1.35 1.35 F02P050S05L - 0.725 0.725 F02P006S05L - 51 51 - 53 53 - 54 54 - 58 58 Voe mV F02P015S05L F02P025S05L F02P050S05L Ioe mA Ref OUT mode Ref IN mode Vref1, Vref 2 5.300 F02P025S05L F02PxxxS05LrevA Dec 2013 2.505 - 5.300 F02P015S05L Electrical Offset Current referred to primary 2.500 3 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F02P***S05L Specification Symbol Unit Value min Temperature coefficient of Output voltage (@ Ip=0A) typ max ±6.0 ±14 ±2.3 ±6 ±1.4 ±4 F01P050S05L ±0.7 ±3 F01P006S05L 104.2 F01P006S05L F01P015S05L F01P025S05L Sensitivity (Theoretical value) Notes TCVo ppm/K F01P015S05L F01P025S05L 41.67 Gth mV/A 625mV/If 25 F01P050S05L Sensitivity Error 12.5 ᵋG % TCG ppm/K ᵋL % - 0.1 0.1 Magnetic offset current referred to primary (@ 10xIf) Iom A - 0.1 0.1 Output current noise referred to primary (@ 100Hz~100kHz) Ino ųA/ (Hz)1/2 20 - mV 40 160 F01P015S05L 15 60 F01P025S05L 10 40 F01P050S05L 5 20 Temperature coefficient of Sensitivity (@Ta=-40°C~+105°C) Output Linearity Peak to peak output ripple at oscillator frequency (If typ=450kHz) Reaction time (@ 10% of If) F01P006S05L F01P006S05L 0.7 ±40 RL=1kΩ RL=1kΩ RL=1kΩ, di/dt=18A/ųs 0.3 RL=1kΩ, di/dt=44A/ųs 0.3 RL=1kΩ, di/dt=68A/ųs F01P050S05L 0.3 RL=1kΩ, di/dt=100/ųs F01P006S05L 0.3 RL=1kΩ, di/dt=18A/ųs 0.3 RL=1kΩ, di/dt=44A/ųs 0.3 RL=1kΩ, di/dt=68A/ųs 0.3 RL=1kΩ, di/dt=100/ųs F01P025S05L tra ųs F01P015S05L F01P025S05L F01P050S05L F02PxxxS05LrevA Dec 2013 - 0.7 0.3 F01P015S05L Response time (@90% of If) ppm/K of 2.5V ( -40°C~+105°C) tr ųs 4 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F02P***S05L Specification Symbol Unit Value min typ Notes max Response time 2 (@ 10% of If to 90% of Vo) Frequency bandwidth (± 1dB) Frequency bandwidth (± 3dB) Output Voltage Accuracy (Overall) tr ųs 0.6 BW kHz 200 RL=1kΩ BW kHz 300 RL=1kΩ F01P006S05L F01P015S05L RL=1kΩ 1.7 XG % 1.2 F01P025S05L 1.0 F01P050S05L 0.9 XG=(100xVoe/625)+ԐG+ԐL Standards EN 50178 ; EN 61010-1 ; EN 60950-1 ; UL 508 (file no. E243511) Characteristic Curve (TYP) F02PxxxS05LrevA Dec 2013 5 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F02P***S05L Maximum Continuous DC primary current According to which the following conditions are true the maximum continuous DC primary current plot shows the boundary of the area. 1. Ip < Ipmax 2. Junction temperature Tj < 125ºC 3. Primacy conductor temperature < 110°C 4. Resistor power dissipation < 0.5 x rated power Frequency Derating Figure 7 : Maximum RMS AC primary current / maximum DC primary current vs frequency F02PxxxS05LrevA Dec 2013 6 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F02P***S05L Reference voltage Ref pin has two modes Ref IN and Ref OUT. The 2.5V internal precision reference is used by the transducer as the reference point for bipolar measurement. An external reference voltage is connected to the Ref pin; this voltage is specified in the range 0 to 4V. Its voltage is used as the reference voltage at the time of measurement. - Typical Source Current (Vref 2– 2.5) / 680 The maximum value will be 2.2mA typ when Vref2=4V - Typical Sink Current (Vref 2 - 2.5) / 680 The maximum value will be 3.68mA typ. When Vref2=0V The following graphs show how the measuring range of each transducer version depends on external reference voltage value If do not prefer to use the Ref pin, please disconnect. F02PxxxS05LrevA Dec 2013 7 Issued by Module Components Div, TAMURA CORPORATION Current Sensor : F02P***S05L Connection Dimensions (mm) Recommended Hole Diameter (mm) F02PxxxS05LrevA Dec 2013 8
F02P006S05L 价格&库存
很抱歉,暂时无法提供与“F02P006S05L”相匹配的价格&库存,您可以联系我们找货
