Issued by Module Components Div, TAMURA CORPORATION
Current Sensor : F03P***S05L
Features:
Backward compatible to F02PS***05 series
Anti-Surge current (4kAT, 8/20uS, single)
Mounting area reduced ; pin compatible. Longitudinal dimension reduced
Super precision & High Stability (low temperature, drift)
Unipolar power voltage ; +5V
Multi-range models
Comparison of the main features of F******S05L series
Series
Features
F01P***S05L
No reference access
F02P***S05L
No reference access. Ref In/Out
F03P***S05L
No reference access. Ref In/Out. Higher creep age and clearance distance.
*** = Rated Current Symbol
Specification
F03P***S05L
Maximum Peak Current
4kAT (2kAx2. Number of primary tunes is two tunes)
Rated Current If (***= rated current symbol)
6A(006) / 15A(015) / 25A(025) 50A(050)
Maximum Current
±20A(If=6A) / ±51A(If=15A) / ±85A(If=25A) / ±150A(If=50A)
Existence of reference access
Yes
Number of primary busbar
4 pcs
Clearance distance ; Primary ↔Secondary
8.2 mm
Standards
UL508 (file#E243511) , EN501758, EN61010-1 , EN60950-1
Ambient Operating Temperature
-40°C ~ +105°C
Mounting Area
The mounting area has been reduced
more than the F03P series. However ,
F03P***S05L series are 100%
compatible with original footprint
mounting.
F03PxxxS05LrevA Dec 2013
1
Absolute Maximum Rating
Symbol
Unit
Value
Vcc
V
7
Primary Conductor Temperature
°C
110
ESD (HBM: Human Body Model)
kV
4
C=100pF , R=1.5kΩ
kAT
4
Current Waveform :
Front time 8ųs
Time to half value 20ųs
Single
Supply Voltage
Notes
Isolation Characteristics
Symbol
Unit
Value
Insulation Voltage
Vd
AC4300V for 1 min.
(Sensing Current 0.5mA)
Primary↔Secondary
Insulation Resistance
Ris
≥500mΩ (@DC500V)
Primary↔Secondary
Clearance distance
dCi
8.2mm (TYP)
Primary↔Secondary
Creep age distance
dCp
8.2mm (TYP)
Primary↔Secondary
UL94 V-0
CTI
V
600
300V , CAT Ⅲ , PD2
Reinforced Isolation
Non uniform field according to
EN61010
600V , CAT Ⅲ , PD2
Simple isolation
EN50178
1000V , CAT Ⅲ , PD2
Simple isolation
EN50178 ,
Case material
Comparative Tracking Index (CTI)
Application Example
Notes
Environmental and Mechanical Characteristics
Symbol
Unit
Value
min
typ
max
Ta
°C
- 40
+ 105
Ambient Storage Temperature
Ts
°C
- 40
+105
g
Mass
12
2
Specification
(*1) = Offset voltage value is after removal of core hysteresis
Symbol
Unit
Value
min
Rated Current
F03P006S05L
F03P015S05L
F03P025S05L
If
15
A
25
50
F03P006S05L
F03P015S05L
F03P025S05L
Ipmax
A
F03P050S05L
Supply Voltage
Vcc
V
Number of primary turns
Np
T
Number of secondary turns
- 20
51
- 85
85
- 150
150
4.75
Ns
1737
T
1764
F03P050S05L
1600
F03P006S05L
25
F03P015S05L
F03P025S05L
5.25
1816
F03P015S05L
Consumption current (at If)
5.00
1,2,3,4
F03P006S05L
F03P025S05L
max
6
F03P050S05L
Maximum Current
(@ Vcc : +5V , Ta : +105°C)
typ
Notes
Icc
30
mA
Icc=15+Ip(mA) / Ns
35
F03P050S05L
55
Internal Reference Voltage
(@Ip=0A)
Vref1
V
2.495
External Reference Voltage
Vref2
V
Vo
V
0.375
4.625
Vo
V
Output Voltage
Output Voltage (Ip=0A)
Electrical Offset Voltage (*1 )
F03P006S05L
- 2.210
2.210
- 1.35
1.35
F03P050S05L
- 0.725
0.725
F03P006S05L
- 51
51
- 53
53
- 54
54
- 58
58
F03P015S05L
F03P025S05L
F03P050S05L
Voe
Ioe
mV
mA
Ref OUT mode
Ref IN mode
Vref1,
Vref 2
5.300
F03P025S05L
2.505
- 5.300
F03P015S05L
Electrical Offset Current
referred to primary
2.500
3
Specification
Symbol
Unit
Value
min
Temperature coefficient of
Internal reference voltage
Output voltage (@ Ip=0A)
Sensitivity
(Theoretical value)
Notes
typ
max
TCVref1
ppm/K
±5.0
±50
TCVo
ppm/K
±6.0
±14
F03P015S05L
±2.3
±6
F03P025S05L
±1.4
±4
F03P050S05L
±0.7
±3
F03P006S05L
104.2
F03P006S05L
F03P015S05L
F03P025S05L
41.67
Gth
mV/A
625mV/If
25
F03P050S05L
Sensitivity Error
12.5
ᵋG
TCG
ppm/K
ᵋL
- 0.1
0.1
Magnetic offset current referred
to primary (@ 10xIf)
Iom
A
- 0.1
0.1
Output current noise referred to
primary (@ 100Hz~100kHz)
Ino
ųA/
(Hz)1/2
mV
40
160
F03P015S05L
15
60
F03P025S05L
10
40
F03P050S05L
5
Sensitivity (@Ta=-40°C~+105°C)
Output Linearity
Peak to peak output ripple at
oscillator frequency (If
typ=450kHz)
Reaction time (@ 10% of If)
F03P006S05L
F03P006S05L
0.7
±40
RL=1kΩ
RL=1kΩ
RL=1kΩ, di/dt=18A/ųs
0.3
RL=1kΩ, di/dt=44A/ųs
0.3
RL=1kΩ, di/dt=68A/ųs
F03P050S05L
0.3
RL=1kΩ, di/dt=100/ųs
F03P006S05L
0.3
0.3
0.3
0.3
F03P025S05L
tra
ųs
F03P015S05L
F03P025S05L
F03P050S05L
- 0.7
0.3
F03P015S05L
Response time (@90% of If)
ppm/K of 2.5V
( -40°C~+105°C)
tr
ųs
4
Specification
Symbol
Unit
Value
min
typ
Notes
max
Response time 2
(@ 10% of If to 90% of Vo)
Frequency bandwidth
(± 1dB)
Frequency bandwidth
(± 3dB)
Output Voltage Accuracy
(Overall)
tr
ųs
0.6
BW
kHz
200
RL=1kΩ
BW
kHz
300
RL=1kΩ
F03P006S05L
F03P015S05L
RL=1kΩ
1.7
XG
1.2
F03P025S05L
1.0
F03P050S05L
0.9
XG=(100xVoe/625)+ԐG+ԐL
Standards
EN 50178 ; EN 61010-1 ; EN 60950-1 ; UL 508 (file no. E243511)
Characteristic Curve (TYP)
5
Maximum Continuous DC primary current
According to which the following
conditions are true the maximum
continuous DC primary current plot
shows the boundary of the area.
1. Ip < Ipmax
2. Junction temperature
Tj < 125ºC
3. Primacy conductor temperature
< 110°C
4. Resistor power dissipation
< 0.5 x rated power
Frequency Derating
Figure 7 : Maximum RMS AC primary current / maximum DC primary current vs frequency
6
Reference voltage
Ref pin has two modes Ref IN and Ref OUT.
The 2.5V internal precision reference is used by the transducer as the reference point for bipolar measurement.
An external reference voltage is connected to the Ref pin; this voltage is specified in the range 0 to 4V.
Its voltage is used as the reference voltage at the time of measurement.
- Typical Source Current (Vref 2– 2.5) / 680
The maximum value will be 2.2mA typ when Vref2=4V
- Typical Sink Current (Vref 2 - 2.5) / 680
The maximum value will be 3.68mA typ. When Vref2=0V
The following graphs show how the measuring range of each transducer version depends on external reference voltage value
If do not prefer to use the Ref pin, please disconnect.
7
Connection
Dimensions (mm)
Recommended Hole Diameter (mm)
8
很抱歉,暂时无法提供与“F03P006S05L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+125.928881+16.29226
- 5+114.358945+14.79538
- 10+110.0747310+14.24111
- 25+104.9388125+13.57664
- 50+101.4299950+13.12268
- 400+92.54843400+11.97361
- 800+90.06232800+11.65197
