Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors L03S***D15WM Series
Features:
Advantage:
Open Loop type
Panel mounting
Molex connector
Improved mounting
Insulated plastic case according
to UL94V0
Excellent accuracy and linearity
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity To External Interference
Current overload capability
Specifications
Parameters
TA=25ºC, VCC=±15V, RL=10kΩ
Symbol
Primary nominal current
50AT
If
100AT
200AT
L03S300
D15WM
L03S400
D15WM
L03S500
D15WM
L03S600
D15WM
L03S700
D15WM
L03S800
D15WM
300AT
400AT
500AT
600AT
700AT
800AT
≥±150AT ≥±300AT ≥ ±600AT ≥ ±900AT
Ifmax
Saturation current
L03S050 L03S100 L03S200
D15WM D15WM D15WM
Vo
Rated output voltage
1
Offset voltage
(at If=0A)
Output linearity2
(0A~If)
≥ ±1000A
4V±0.040V (at If)
Vof
≤ ±40mV
≤ ±30mV
εL
≤±1% (at If)
Power supply voltage
VCC
±15V±5%
Consumption current
Icc
≤20mA
tr
≤10μs (at di/dt=100A/μs)
Thermal drift of gain4
TcVo
≤ ±0.1%/ºC
Thermal drift of offset
TcVof ≤±2mV/ºC
Response time3
≤±1.0 mV/ºC
VOH
≤ ±20mV (at If=0A→If→0A)
Insulation voltage
Vd
AC2500V for 1minute (sensing current 0.5mA), inside of through hole terminal
Insulation resistance
RIS
≥ 500MΩ (at DC500V), inside of through hole terminal
TA
-10ºC~+80ºC
TS
-25ºC~+85ºC
Hysteresis error
Ambient operation
temperature
Ambient storage temperature
1
After removal of core hysteresis—
drift of offset
2
Without offset —3 Time between 10% input current full scale and 90% of sensor output full scale —
4
Without Thermal
Electrical Performances
Frequency characteristic(L03S600D15W )
10
6
8
4
6
2
Output voltage (V)
Attenuation (dB)
Saturation characteristic(L03S600D15W)
-4
-6
4
2
-4
-8
-6
-10
-8
0.1
1
10
Frequency characteristic(kHz)
@ If=6Arms
L03SXXXD15WMrevF, March 2012
100
TA=25ºC Pulsed
-10
-1500 -1200 -900 -600 -300
600
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
900
1200 1500
Mechanical dimensions
Connector
Manufacturer
Part Number
Old
Part Number
Molex
22-04-1041
5045-04A
Terminal number:
1. +Vcc(+15V)
2. -Vcc(-15V)
3. VOUT
4. GND
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
Ø2.5
Ø4.5
Recommended
retainer holes
Electrical connection diagram
4 3 2 1
-VCC
VOUT
+If
RL = 10kΩ
-If
+VCC
GND
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
51g
3600
很抱歉,暂时无法提供与“L03S200D15WM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+71.71872200+9.28201
