L03S500D15WM
L03S500D15WM
    TAMURA
    Module
    L03S500D15WM
L03S500D15WM 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L03S***D15WM Series Features:      Advantage: Open Loop type Panel mounting Molex connector Improved mounting Insulated plastic case according to UL94V0       Excellent accuracy and linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity To External Interference Current overload capability Specifications Parameters TA=25ºC, VCC=±15V, RL=10kΩ Symbol Primary nominal current 50AT If 100AT 200AT L03S300 D15WM L03S400 D15WM L03S500 D15WM L03S600 D15WM L03S700 D15WM L03S800 D15WM 300AT 400AT 500AT 600AT 700AT 800AT ≥±150AT ≥±300AT ≥ ±600AT ≥ ±900AT Ifmax Saturation current L03S050 L03S100 L03S200 D15WM D15WM D15WM Vo Rated output voltage 1 Offset voltage (at If=0A) Output linearity2 (0A~If) ≥ ±1000A 4V±0.040V (at If) Vof ≤ ±40mV ≤ ±30mV εL ≤±1% (at If) Power supply voltage VCC ±15V±5% Consumption current Icc ≤20mA tr ≤10μs (at di/dt=100A/μs) Thermal drift of gain4 TcVo ≤ ±0.1%/ºC Thermal drift of offset TcVof ≤±2mV/ºC Response time3 ≤±1.0 mV/ºC VOH ≤ ±20mV (at If=0A→If→0A) Insulation voltage Vd AC2500V for 1minute (sensing current 0.5mA), inside of through hole  terminal Insulation resistance RIS ≥ 500MΩ (at DC500V), inside of through hole  terminal TA -10ºC~+80ºC TS -25ºC~+85ºC Hysteresis error Ambient operation temperature Ambient storage temperature 1 After removal of core hysteresis— drift of offset 2 Without offset —3 Time between 10% input current full scale and 90% of sensor output full scale — 4 Without Thermal Electrical Performances Frequency characteristic(L03S600D15W ) 10 6 8 4 6 2 Output voltage (V) Attenuation (dB) Saturation characteristic(L03S600D15W) 0 -2 -4 -6 4 2 0 -2 -4 -8 -6 -10 -8 0.1 1 10 Frequency characteristic(kHz) @ If=6Arms L03SXXXD15WMrevF, March 2012 100 TA=25ºC Pulsed -10 -1500 -1200 -900 -600 -300 0 300 600 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 900 1200 1500 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L03S***D15WM Series Mechanical dimensions Connector Manufacturer Part Number Old Part Number Molex 22-04-1041 5045-04A Terminal number: 1. +Vcc(+15V) 2. -Vcc(-15V) 3. VOUT 4. GND NOTES 1. Unit is mm 2. Tolerance is 0.5mm Ø2.5 20 Ø4.5 Recommended retainer holes Electrical connection diagram 4 3 2 1 -VCC VOUT +If RL = 10kΩ -If +VCC GND Package & Weight Information L03SXXXD15WMrevF, March 2012 Weight Pcs/box Pcs/carton Pcs/pallet 51g 20 200 3600 Tamura reserve the right to modify its products in order to improve them without prior notice
L03S500D15WM 价格&库存
很抱歉,暂时无法提供与“L03S500D15WM”相匹配的价格&库存,您可以联系我们找货
