S23P50/100D15M1
S23P50/100D15M1
    TAMURA
    Module
    SENSOR CURRENT HALL 100A AC/DC
S23P50/100D15M1 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors S23P***D15M1 Series Features: Advantages:              Closed Loop type Current or voltage output Conversion ratio KN = 1:1000 Printed circuit board mounting Integrated primary Insulated plastic case according to UL94V0  UL Recognition Specifications Parameters Symbol 1 50A 100A Ifmax Maximum current (at 85°C) TA=25ºC, VCC=±15V S23P50/100D15M1 If Primary nominal current Excellent accuracy and linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity to external interferences Optimised response time Current overload capability ± 226A (at RM≤7.5Ω) Measuring resistance (If = ±ADC at 85°C) RM 20Ω~145Ω (at VCC = ±12V) 48Ω~205Ω (at VCC = ±15V) 20Ω~57Ω (at VCC = ±12V) 48Ω~85Ω (at VCC = ±15V) Conversion Ratio KN 1 : 1000 1 : 1000 IO 50mA 100mA Rated output current 2 X IO ±0.25% IOf ≤ ±0.30mA εL ≤ ±0.15% (at If) VCC ± 12V .. ± 15V ± 5% ICC ≤ ±16mA (Output current is not included) tr ≤ 0.5μs (at di/dt = 100A / μs) TcIo ≤ ±0.01%/ºC TcIof ≤ ±0.5mA typ ≤ ±0.8mA max (at TA= -25ºC  +85ºC) Hysteresis error IOH ≤ 0.3mA (at If=0A → If → 0A) Insulation voltage Vd AC5000V, for 1minute (sensing current 0.5mA), Primary  Secondary Insulation resistance RIS Secondary coil resistance RS ≥ 500MΩ (at DC500V) Primary  Secondary 33Ω (at TA = 70ºC) 35Ω (at TA = 85ºC) Ambient operation temperature TA Ambient storage temperature TS Output current accuracy (at If) 3 Offset current (at If=0A) 2 Output linearity (0A~If) Power supply voltage 1 Consumption current Response rime 4 Thermal drift of gain 5 Thermal drift of offset current –40ºC ~ +85ºC –40ºC ~ +90ºC 1 2 At VCC=±12V ,Ifmax Operating Time: ≤ 3 Seconds. Maximum current is restricted by V CC — Without offset current— 3 After removal of core hysteresis— 4 Time between 90% input current full scale and 90% of sensor output full scale — 5 Without Thermal drift of offset current Electrical Performances Frequency characteristic 6 8 4 6 2 Output voltage (V) Attenuation (dB) Saturation characteristic(RM=51Ω) 10 0 -2 -4 -6 4 2 0 -2 TA=25ºC Pulsed -4 -6 -8 -8 -10 0.1 1 10 Frequency characteristic(kHz) @ If=1(Arms) RM=51Ω S23PXXD15M1revD, April 2012 100 -10 -200 -150 -100 -50 0 50 100 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 150 200 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors S23P***D15M1 Series Mechanical dimensions NOTES 1. Unit is mm 2. Tolerance is 0.5mm 0.6 2.54±0.3 1 +1 1.4 12.7 ±0.4 (7.75) 3.5 -0.3 23 ±0.5 Terminal number: 1. –Vcc(-15V) 2. +Vcc(+15V) 3. IOUT 0.7 1.91±0.3 2.54±0.3 2.54±0.3 2.54±0.3 Connection specific 1.The primary connection 6Pins 1.4×1mm Recommended PCB hole diameter:Φ2mm 11.43±0.3 2.The secondary connection 3Pins 0.7×0.6mm Recommended PCB hole diameter:Φ1.2mm 15.73 ±0.5 Primary input current (+) Primary input current (-) 33.3±0.5 Electrical connection diagram +If Voltage output Current output S23PxxxD15M1 @ If=50A & VCC=±15VDC 48Ω ≤ RM ≤ 205Ω @ If=100A & VCC=±15VDC 48Ω ≤ RM ≤ 85Ω VOUT -VCC -If +VCC RM -VCC +VCC GND IOUT GND UL Standard UL 508 , CSA C22.2 No.14 (UL FILE No.E243511) • For use in Pollution Degree 2 Environment. • Maximum Surrounding air temperature rating, 85˚C. CAUTION Provide two min. 100 by 85 mm, 0.5 mm thick cupper conductor-cum-heat sink as primary conductor of each side for safe usage. The primary conductor temperature and PCB should not exceed 100˚C. Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 26g 100 400 9600 S23PXXD15M1revD, April 2012 Tamura reserve the right to modify its products in order to improve them without prior notice
S23P50/100D15M1 价格&库存
很抱歉,暂时无法提供与“S23P50/100D15M1”相匹配的价格&库存,您可以联系我们找货
