Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors S25P***D15Y Series
Features:
Advantages:
Closed Loop type
Current or voltage output
Conversion ratio KN = 1:2000
Printed circuit board mounting
Aperture
Insulated plastic case according to
UL94V0
UL Recognition
Specifications
Parameters
Excellent accuracy and linearity
Low temperature drift
Wide frequency bandwidth
No insertion loss
High Immunity to external interferences
Optimised response time
Current overload capability
TA=25ºC, VCC=±15V
Symbol
S25P100D15Y
S25P150D15Y
If
100A
150A
Ifmax
± 150A (at 20Ω ≤ RM ≤ 25Ω)
± 200A ((at 0Ω ≤ RM ≤ 40Ω)
Measuring resistance (If = ±ADC at 85°C)
RM
0Ω ~ 42Ω (at VCC = ±12V)
20Ω ~ 102Ω (at VCC = ±15V)
0Ω ~ 15Ω (at VCC = ±12V)
0Ω ~ 55Ω (at VCC = ±15V)
Conversion Ratio
KN
Primary nominal current
1
Maximum current (at 85°C)
Rated output current
1 : 2000
IO
2
50mA
75mA
Output current accuracy (at If)
X
Offset current3(at If=0A)
IOf
≤ ± 0.1mA
≤ ± 0.2mA
εL
≤ ± 0.15% (at If)
≤ ± 0.25% (at If)
2
Output linearity (0A~If)
Power supply voltage
1
Consumption current
Response rime
4
Thermal drift of gain
5
IO ± 0.5%
VCC
± 12V..± 15V ± 5%
ICC
≤ ± 16mA (Output current is not included)
tr
≤ 1.0μs (at di/dt = 100A / μs)
TcIo
≤ ± 0.5mA (at TA = – 40ºC +85ºC)
TcIof
Thermal drift of offset current
± 0.01% / ºC
IOH
≤ 0.3mA (at If=0A → If → 0A)
Insulation voltage
Vd
AC 3000V, for 1minute (sensing current 0.5mA),
inside of through hole terminal
Insulation resistance
RIS
Secondary coil resistance
RS
Ambient operation temperature
TA
Hysteresis error
Ambient storage temperature
1
≥ 500MΩ (at DC 500V) , inside of through hole terminal
120Ω (at TA = 70ºC)
95Ω (at TA = 70ºC)
128Ω (at TA = 85ºC)
85Ω (at TA = 85ºC)
– 40ºC ~ +85ºC
TS
–40ºC ~ +90ºC
2
3
Maximum current is restricted by VCC — Without offset current— After removal of core hysteresis— 4 Time between 90% input current full scale
and 90% of sensor output full scale — 5 Without Thermal drift of offset current — 6 At Small signal
Electrical Performances
Frequency characteristic(S25P100D15Y)
10
6
8
4
6
2
Output voltage (V)
Attenuation (dB)
Saturation characteristic(S25P100D15Y, RM=100Ω)
-4
-6
-8
4
2
-4
TA=25ºC Pulsed
-6
-8
-10
0.1
1
10
Frequency characteristic(kHz)
@ If=3AT(Arms) RM=100Ω
100
-10
-250 -200 -150 -100
-50
100
150
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
S25P***D15YrevC, April 2012
200
250
Mechanical dimensions
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
Terminal number:
1. +Vcc(+15V)
2. –Vcc(-15V)
3. IOUT
A field display
B field display
Current A field
Coil turn B field
50A
050
1000T
X
100A
100
2000T
Y
150A
150
50A is 1000T only
150A is 2000T only
Electrical connection diagram
Voltage
output
Current
output
+If
+If
-If
3 2
-If
1
3 2
VOUT
S25P150D15Y
AtIf = 150A & VCC = ±15VDC
0Ω ≤ RM ≤ 55Ω
1
IOUT
-VCC
+VCC
-VCC
S25P100D15Y
At If = 100A & VCC = ±15VDC
20Ω ≤ RM ≤ 102Ω
+VCC
RM
GND
GND
UL Standard
UL 508 , CSA C22.2 No.14 (UL FILE No.E243511)
• For use in Pollution Degree 2 Environment.
• Maximum Surrounding air temperature rating, 85˚C.
CAUTION
Do not wrap the primary conductor around the core part of the product to increase measured current.
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
20g
100
300
7200
很抱歉,暂时无法提供与“S25P100D15Y”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 300+102.98095300+13.28481
