S21S180D15JN
S21S180D15JN
    TAMURA
    Module
    Current Sensor 180A 1 Channel Hall Effect, Closed Loop Bidirectional Module
S21S180D15JN 数据手册
Hall Effect Current Sensor S21S180D15JN Features: Advantages:            Closed Loop type Current or voltage output Conversion ratio K = 1:4000 Panel mounting with JST connector  Aperture  Insulated plastic case according to UL94V0 Specifications Excellent accuracy and linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity to external interferences Optimised response time Current overload capability TA=25ºC, VCC=±15V Parameters Symbol S21S180D15JN Rated Current If 180A Ifmax ± 540A @ TA=25̊C 5Ω ≤ Rm ≤ 30 Ω ± 540A @TA=80̊C 5Ω ≤ Rm ≤ 20 Ω 0 - 68 Ω @ Vcc ±12V 0 - 100 Ω @ Vcc ± 15 V Maximum Current1 Measuring resistance If = ± ADC @ 80°C RM Conversion Ratio K 1 : 4000 Output Current IOUT ± 45mA Offset Current IOE ≤ ± 0.2mA @ If = 0A Output Current Accuracy X IOUT ± 1% (without IOE) Output Linearity εL ≤ ± 0.3% @ If VCC ± 12V ± 5% ICC ≤ ± 16mA (Output Current is not included) tr ≤ 1μs @ di/dt = 100A / μs Output Temperature Characteristic TCIOUT ≤ ± 0.02% / ºC @ If Offset Temperature Characteristic TCIOE ≤ ± 0.01mA / °C @ If = 0A Hysteresis allowance IOH ≤ 0.2mA (0A  If) Insulation Withstanding Vd AC 2500V, for 1minute (sensing current 0.5mA), inside of aperture  terminal Insulation Resistance RIS 500MΩ (@ DC 500V) inside of aperture  terminal Frequency Bandwidth f DC .. 200 kHz Secondary Coil Resistance RS 48Ω @ 25C° 60Ω @ 80Cº Operating Temperature TA – 30ºC ~ +80ºC Supply Voltage 2 Consumption Current Response Time 3 TS Storage Temperature 1 2 –40ºC ~ +85ºC 3 @ VCC=±15V for 10 Seconds — Rated Current is restricted by VCC — Time between 10% input current full scale and 90% of sensor output full scale Electrical Performances Tamura reserve the right to modify its products in order to improve them without prior notice S21S180D15JNrevB, Aug 2013 Hall Effect Current Sensor S21S180D15JN Mechanical dimensions in mm 20 12 7 Ø5.5 If 22 0 8 49.4 R1 Terminal function: 1. +VCC 2. –VCC 3. OUT 4. N.C. 2 24.7 4 1 MAX 3.5 49.4 JST B4B-XH-A Electrical connection diagram Voltage output -If Current output -If +If 4 +If 1 4 - VCC VOUT RM 1 - VCC IOUT + VCC + VCC GND GND Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 71g 25 100 1600 Tamura reserve the right to modify its products in order to improve them without prior notice S21S180D15JNrevB, Aug 2013
S21S180D15JN 价格&库存
很抱歉,暂时无法提供与“S21S180D15JN”相匹配的价格&库存,您可以联系我们找货
S21S180D15JN
  • 100+197.16946100+25.63139
