S20S200D15M1
S20S200D15M1
    TAMURA
    Module
    SENSOR CURRENT HALL 200A AC/DC
S20S200D15M1 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors S20S200D15M1 Features:      Advantage: Closed Loop type Voltage or current output Panel mounting JST connector Insulated plastic case according to UL94V0         Excellent accuracy Very good linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity To External Interference Optimised response time Current overload capability Specifications TA=25ºC, VCC=±15V Parameter Symbol S20S200D15M1 If Primary nominal current 1 Maximum current @70ºC VCC=±15V Ifmax Measurement resistance @70ºC RM Conversion ratio KN 200A ±300A (at RM=30Ω) 2 5Ω~35Ω (at VCC = ±12V) 9Ω~13Ω (at VCC = ±12V) 25Ω~65Ω (at VCC = ±15V) 29Ω~33Ω (at VCC = ±15V) 1 : 2000 IO Rated output current 300A 100mA 150mA X Io±1% IOf ≤ ±0.5mA εL ≤ ±0.25% (at If) VCC ± 12V .. ± 15V ± 5% ICC ≤ ±16mA (Output current is not included) tr ≤ 1μs (at di/dt = 100A / μs) TcIo ≤ ±0.02%/ºC (at TA= -5ºC~+70ºC) TcIof ≤ ±0.012mA/ºC (at TA= -5ºC~+70ºC) Hysteresis error IOH ≤ 0.3mA (at If=0A → If → 0A) Insulation voltage Vd AC2500V, for 1minute (sensing current 0.5mA), inside of through hole  terminal Insulation resistance RIS ≥ 500MΩ (at DC500V), inside of through hole  terminal Secondary coil resistance RS 33Ω (at TA=70ºC) Ambient operation temperature TA -20ºC ~ +70ºC Ambient storage temperature TS Output current accuracy (at If) 3 Offset current (at If=0A) 2 Output linearity (0A~If) Power supply voltage 1 Consumption current Response rime 4 Thermal drift of gain 5 Thermal drift of offset current 1 -20ºC ~ +85ºC 2 Maximum current is restricted by V CC— Without offset current— output full scale — 5 Without Thermal drift of offset current 3 After removal of core hysteresis— 4 Time between 90% input current full scale and 90% of sensor Electrical Performances Frequency characteristic 6 8 4 6 2 Output voltage (V) Attenuation (dB) Saturation characteristic(RM=40Ω) 10 0 -2 -4 -6 4 2 0 -2 -4 -8 -6 -10 -8 0.1 1 10 Frequency characteristic(kHz) @ If=2AT(Arms) RM=40Ω S20S200D15M1revD, April 2012 100 -10 -400 TA=25ºC Pulsed -300 -200 -100 0 100 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 200 300 400 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors S20S200D15M1 Mechanical dimensions Connector Manufacturer Part Number JST B4B-XH-A-G NOTES 1. Unit is mm 2. Tolerance is 0.5mm (Gold plated terminal) Terminal number: 1. +Vcc(+15V) 2. -Vcc(-15V) 3. IOUT 4. NC(No connection) Electrical connection diagram Voltage Output Current Output 1 -If +If +If 4 1 NC +VCC -If VOUT RM GND -VCC 4 +VCC NC IOUT -VCC GND @ If=200A & VCC=±15V 25Ω ≤ RM ≤ 65Ω @ If=300A & VCC=±15V 29Ω ≤ RM ≤ 33Ω Package & Weight Information S20S200D15M1revD, April 2012 Weight Pcs/box Pcs/carton Pcs/pallet 46g 50 200 2400 Tamura reserve the right to modify its products in order to improve them without prior notice
S20S200D15M1 价格&库存
很抱歉,暂时无法提供与“S20S200D15M1”相匹配的价格&库存,您可以联系我们找货
