Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors L34S***D15 Series
Features:
Advantage:
Open Loop type
Panel mounting
Bipolar power supply
Large aperture
Insulated plastic case according
to UL94V0
UL Recognition
Excellent accuracy and linearity
Wide nominal current range
Low temperature drift
No insertion loss
High Immunity To External Interference
Optimised response time
Current overload capability
Specifications
Parameters
TA=25ºC, VCC=±15V, RL=10kΩ
Symbol L34S200D15 L34S300D15 L34S400D15 L34S500D15 L34S600D15 L34S800D15 L34S1T0D15 L34S1T2D15 L34S1T5D15
Primary nominal current
Saturation current
If
200A
300A
Ifmax
≥ ±600A
≥ ±900A
400A
500A
600A
800A
1000A
1200A
≥ ±1200A ≥ ±1500A ≥ ±1800A ≥ ±2400A ≥ ±2500A ≥ ±2500A ≥ ±2500A
Rated output voltage
Vo
4V ± 0.040V (at If)
Offset voltage1
Vof
≤ ± 0.020V (at If=0A)
εL
≤ ± 0.5% (at If)
Power supply voltage
VCC
± 15V ±5 %
Consumption current
Icc
≤ 25mA
tr
≤ 5μs (at di/dt = 100A / μs)
Thermal drift of gain4
TcVo
≤ ± 0.05% / ºC
Thermal drift of offset
TcVof
≤ ± 1.0 mV/ºC
VOH
≤ 10mV (at If=0A→If→0A)
Insulation voltage
Vd
AC3000V for 1minute (sensing current 0.5mA), inside of aperture terminal
Insulation resistance
RIS
≥ 500MΩ (at DC500V), inside of aperture terminal
TA
-30ºC~+80ºC
Output linearity
( 0A, 0.5If , If)
2
Response time3
Hysteresis error
Ambient operation
temperature
Ambient storage temperature
-40ºC~+85ºC
TS
1
After removal of core hysteresis—
drift of offset
1500A
2
3
Without offset — Time between 10% input current full scale and 90% of sensor output full scale —
4
Without Thermal
Electrical Performances
Frequency characteristic(L34S1T0D15)
6
15
10
2
Output voltage (V)
Attenuation (dB)
4
Saturation characteristic(L34S1T0D15)
-4
-6
-8
5
-10
TA=25ºC Pulsed
-10
0.1
1
10
Frequency characteristic(kHz)
@ If=60AT(Arms)
L34SXXXD15revB, March 2012
100
-15
-4000 -3000 -2000 -1000
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
2000
3000
4000
Mechanical dimensions
16
Φ4.5 (HOLE)
4
Φ4.5 (HOLE)
Lot
No.
5.5×4.5 (SLOT HOLE)
11
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
38.75
Current direction
78
(8.8)
Terminal No.
Connector
20.5
1
2
3
4
17
33.25
53.5
LE)
40.5
(HO
Connector
65.5
3
.5
Φ 4
2 -
64.5
40.5
1.5
1
5
78
89.5
5
Manufacturer
Part Number
Old
Part Number
Molex
22-04-1041
5045-04A
Terminal Number:
1: +VCC(+15V)
2: - VCC(-15V)
3: VOUT
4: GND
3
19
10
Electrical connection diagram
+VCC
-VCC
1 2 3 4
-If
+If
RL = 10kΩ
VOUT
GND
UL Standard
UL 508 , CSA C22.2 No.14 (UL FILE No.E243511)
• For use in Pollution Degree 2 Environment.
• Maximum Surrounding air temperature rating, 80˚C.
CAUTION
Do not wrap the primary conductor around the core part of the product for preventing to reduce the required
Spacings.
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
165g
10
50
很抱歉,暂时无法提供与“L34S800D15”相匹配的价格&库存,您可以联系我们找货
