S26P200D15Y
S26P200D15Y
    TAMURA
    Module
    Current Sensor 200A 1 Channel Hall Effect, Closed Loop Bidirectional Module
S26P200D15Y 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors S26P200D15Y Features: Advantages:              Closed Loop type Current or voltage output Conversion ratio KN = 1:2000 Printed circuit board mounting Aperture Insulated plastic case according to UL94V0  UL Recognition Specifications Parameters Symbol 1 200A 300A Ifmax Maximum current (at 85°C) Measuring resistance (at 85°C) RM Conversion Ratio KN ± 350A (at RM ≤ 5Ω) 3 0Ω ~ 4Ω (at VCC = ±12V)2 0Ω ~ 8Ω (at VCC = ±15V) 0Ω ~ 26Ω (at VCC = ±12V) 0Ω ~ 56Ω (at VCC = ±15V) 1 : 2000 IO Rated output current TA=25ºC, VCC=±15V S26P200D15Y If Primary nominal current Excellent accuracy and linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity to external interferences Optimised response time Current overload capability 150mA 100mA Output current accuracy (at If) X IO ± 0.4% Offset current4(at If=0A) IOf ≤ ± 0.2mA εL ≤ ± 0.15% (at If) VCC ± 12V .. ± 15V ± 5% ICC ≤ ± 16mA (Output current is not included) tr ≤ 1.0μs (at di/dt = 100A / μs) TcIo ≤ ± 0.01% / ºC TcIof ≤ ± 0.5mA max (at TA = – 40ºC  +85ºC) Hysteresis error IOH ≤ 0.3mA (@ If=0A → If → If=0A) Insulation voltage Vd AC 3000V, for 1minute (sensing current 0.5mA), inside of through hole  terminal Insulation resistance RIS ≥ 500MΩ (@ DC 500V) , inside of through hole  terminal Secondary coil resistance RS Ambient operation temperature TA 3 Output linearity (0A~If) Power supply voltage 1 Consumption current Response rime 5 Thermal drift of gain 6 Thermal drift of offset current Ambient storage temperature 60Ω (at TA = 70ºC) , – 40ºC ~ +85ºC TS 1 2 65Ω (at TA = 85ºC) – 40ºC ~ +90ºC 3 4 Maximum current is restricted by VCC — If = 250A — Without offset current— After removal of core hysteresis— 5 Time between 90% input current full scale and 90% of sensor output full scale — 6 Without Thermal drift of offset current Electrical Performances Frequency characteristic Saturation characteristic(RM=20Ω) 6 2 Output voltage (V) Attenuation (dB) 4 0 -2 -4 -6 -8 -10 0.1 1 10 Frequency characteristic(kHz) @ If=3AT(Arms) RM=100Ω S26P200D15YrevC, April 2012 100 3.0 2.5 2.0 1.5 1.0 0.5 0.0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 -250 -200 -150 -100 TA=25ºC Pulsed -50 0 50 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 100 150 200 250 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors S26P200D15Y Mechanical dimensions If 48 0.5 11 Terminal number: 1. +Vcc(+15V) 2. IOUT 3. –Vcc(-15V) 8.4 33.5 NOTES 1. Unit is mm 2. Tolerance is 0.5mm 21 10.2 17 4.5 14 1 3 2 Terminal number 3-(0.6X0.7) Lot No 11.5 12.7 12.7 (25.4) Electrical connection diagram Current output Voltage output -If - If +If 3 2 +If 1 -VCC S26P200D15Y At If = 200A & VCC = ±15VDC 0Ω ≤ RM ≤ 56Ω 3 -VCC +VCC VOUT 2 1 +VCC I OUT RM GND GND UL Standard UL 508 , CSA C22.2 No.14 (UL FILE No.E243511) • For use in Pollution Degree 2 Environment. • Maximum Surrounding air temperature rating, 85˚C. CAUTION Do not wrap the primary conductor around the core part of the product to increase measured current. Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 45g 50 200 5400 S26P200D15YrevC, April 2012 Tamura reserve the right to modify its products in order to improve them without prior notice
S26P200D15Y 价格&库存
很抱歉,暂时无法提供与“S26P200D15Y”相匹配的价格&库存,您可以联系我们找货
