S27S300D15Y
S27S300D15Y
    TAMURA
    S27S300D15Y
S27S300D15Y 数据手册
Hall Effect Current Sensor S27S300D15Y Features:        Current or voltage output  Conversion ratio K = 1:2000  Panel mounting with Molex Minifit connector  Large aperture  Insulated plastic case according to UL94V0   Specifications Excellent accuracy and linearity Low temperature drift Wide frequency bandwidth No insertion loss High Immunity to external interferences Optimised response time Current overload capability TA=25ºC, VCC=±15V Parameters Symbol S27S300D15Y If 300A Ifmax ± 500A (@ RM ≤ 5Ω) Rated Current Maximum Current Advantages: Closed Loop type 1 300A 500A 300A 500A 300A 500A ±12V If = ± ADC RM Measuring resistance @ 85°C ±15V ±20V : : : : : : 0Ω ~ 39Ω 0Ω ~ 12Ω 0Ω ~ 58Ω 0Ω ~ 22Ω 15Ω ~ 93Ω 15Ω ~ 45Ω K 1 : 2000 Output Current IOUT ± 150mA Offset Current IOE ≤ ± 0.2mA @ If = 0A Output Current Accuracy X IOUT ± 0.4% (w/o Iof) Output Linearity εL ± 0.1% @ If Conversion Ratio Supply Voltage 2 VCC ± 12V ~ ± 20V (±5%) Consumption Current ICC ± 20mA (Output Current is not included) Response Time3 tr < 1.0μs @ di/dt = 100A / μs Output Temperature Characteristic TCIOUT ≤ ± 0.01 % / ºC @ If Offset Temperature Characteristic TCIOE < ± 0.5mA max. @ If = 0A (-40ºC ~ +85ºC) IOH ≤ 0.08mA (0A  3 x If) Insulation Withstanding Vd AC 4000V, for 1minute (sensing current 0.5mA), inside of aperture  terminals Insulation Resistance RIS > 500MΩ (@ DC 500V) inside of aperture  terminals Frequency Bandwidth f DC .. 100 kHz Secondary Coil Resistance RS 25Ω @ TA = 70ºC 28Ω @ TA = 85ºC Operating Temperature TA – 40ºC ~ +85ºC Hysteresis allowance TS Storage Temperature 1 2 – 40ºC ~ +90ºC 3 @ VCC=±15V for 10 Seconds — Rated Current is restricted by VCC — Time between 10% input current full scale and 90% of sensor output full scale — < ± 0.3mA max. @ If = 0A (-10ºC ~ +70ºC) Electrical Characteristics E243511 S27S300D15YrevB , Aug2013 Tamura reserve the right to modify its products in order to improve them without prior notice Hall Effect Current Sensor S27S300D15Y Mechanical dimensions in mm 68 60 If LABEL Molex 5566 MINIFIT 2-Ø4.3 Ø54 4-(4.3x5.3) 56.5 Ø20.1 44 1 2 3 Terminal function: 1. +VCC 2. OUTPUT 3. –VCC 29.5 1 3 46 20 44 46 Electrical connection diagram Voltage output Current output IOUT +VCC RM GND +VCC -If +If 1 2 3 -VCC VOUT 1 2 3 -VCC GND Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet E243511 S27S300D15YrevB , Aug2013 Tamura reserve the right to modify its products in order to improve them without prior notice -If +If
S27S300D15Y 价格&库存
很抱歉,暂时无法提供与“S27S300D15Y”相匹配的价格&库存,您可以联系我们找货
