Hall Effect Current Sensor S28S500D24ZM
Features:
Advantages:
Closed Loop type
Current or voltage output
Conversion ratio K = 1:5000
Panel mounting with Molex mini-fit Jr
Large aperture
Insulated plastic case according to
UL94V0
Excellent accuracy and linearity
Very low temperature drift
No insertion loss
High Immunity to external interferences
Optimised response time
Wide supply voltage range
Specifications
TA=25ºC, VCC=±15V
Parameters
Rated Current
Maximum Current
1
Symbol
S28S500D24ZM
If
500A
Ifmax
± 800AT(see below)
500AT
800AT
500AT
800AT
500AT
800AT
±15V
If = ± ADC
RM
Measuring resistance @ 85°C
±18V
±24V
0Ω ~ 60Ω
0Ω ~ 11Ω
0Ω ~ 92Ω
0Ω ~ 30Ω
5Ω ~ 149Ω
5Ω ~ 65Ω
K
1 : 5000
Output Current
IOUT
± 100mA
Offset Current
IOE
≤± 0.4mA @ If = 0A
Output Current Accuracy
X
IOUT ± 0.5% (w/o IoE)
Output Linearity
εL
≤ ± 0.1% @ If
Conversion Ratio
Supply Voltage
2
VCC
± 15V ~ ± 24V (±5%)
Consumption Current
ICC
± 30mA (Output Current is not included)
Response Time3
tr
< 1.0μs @ di/dt = 100A / μs
TCIOUT
< ± 0.01 % / ºC @ If (w/o TCIoE)
TCIOE
< ± 0.4mA @ If = 0A (max)
IOH
≤ 0.2mA (max)
Insulation Withstanding
Vd
AC 4000V, for 1minute (sensing current 0.5mA), inside of aperture terminals
Insulation Resistance
RIS
> 500MΩ (@ DC 500V) inside of aperture terminals
Frequency Bandwidth
f
DC .. 100 kHz
Secondary Coil Resistance
RS
70Ω @ TA = 70ºC
Operating Temperature
TA
– 40ºC ~ +70ºC
Output Temperature Characteristic
Offset Temperature Characteristic
4
Hysteresis allowance
TS
Storage Temperature
1
2
– 40ºC ~ +85ºC
3
@ VCC=±15V for 10 Seconds — Rated Current is restricted by VCC — Time between 10% input current full scale and 90% of sensor output full scale
— < ± 0.4mA max. @ If = 0A (-10ºC ~ +70ºC)
Electrical Performances
S28S500D24ZMrevC, May 2013
Tamura reserve the right to modify its products in order to improve them without prior notice
Mechanical dimensions in mm
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Tamura:
S28S500D24ZM
很抱歉,暂时无法提供与“S28S500D24ZM”相匹配的价格&库存,您可以联系我们找货
