Hall Effect Current Sensor S29S1T0D24ZM
Features:
Advantages:
Current or voltage output
Conversion ratio K = 1:5000
Panel mounting with Molex 6410-03C.
Large aperture
Insulated plastic case according to
Closed Loop type
Excellent accuracy and linearity
Very low temperature drift
No insertion loss
High Immunity to external interferences
Optimised response time
Wide supply voltage range
UL94V0
Specifications
TA=25ºC, VCC=±24V
Parameters
Symbol
S29S1T0D24ZM
Rated Current
If
1000A
Ifmax
Maximum Current
70°C
±15V
85°C
If = ± ADC
RM
Measuring resistance @ 85°C
70°C
±24V
85°C
± 2100A (see below)
1000A
: 0Ω ~ 21Ω
1200A
: 0Ω ~ 9Ω
1300A
: 0Ω ~ 5Ω
1000A
: 0Ω ~ 18Ω
1200A
: 0Ω ~ 7Ω
1000A
: 0Ω ~ 60.5Ω
1800A
: 0Ω ~ 14Ω
2100A
: 0Ω ~ 4Ω
1000A
: 10Ω ~ 58.5Ω
1800A
: 10Ω ~ 12Ω
K
Conversion Ratio
1 : 5000
Output Current
IOUT
± 200mA
Offset Current
IOE
≤ ± 0.4mA @ If = 0A1
Output Current Accuracy
X
IOUT ± 0.4% (without IOf)
Output Linearity
εL
≤ ± 0.1% @ If
Supply Voltage
VCC
± 15V ~ ± 24V (±5%)
Consumption Current
ICC
± 35mA (Output Current is not included)
Response Time2
tr
< 1.0μs @ di/dt = 100A / μs
Output Temperature Characteristic
TCIOUT
< ± 0.01 % / ºC @ If (without TCIOE)
Offset Temperature Characteristic
TCIOE
≤± 0.8mA max @ If = 0A
IOH
≤ 0.2mA (0A 3 x If)
Hysteresis allowance
Insulation Withstanding
Vd
AC 4000V, for 1minute (sensing current 0.5mA), inside of aperture terminals
Insulation Resistance
RIS
> 500MΩ (@ DC 500V) inside of aperture terminals
Frequency Bandwidth
f
DC .. 100 kHz
Secondary Coil Resistance
RS
48Ω @ TA = 70ºC
50Ω @ TA = 85ºC
Operating Temperature
TA
– 40ºC ~ +85ºC
Storage Temperature
TS
– 40ºC ~ +90ºC
1
Offset current value is after removal of core hysteresis — 2 Time between 90% input current full scale and 90% of sensor output full scale
Electrical Performances
Frequency Characteristics
S29S1T0D24ZMrevA, Aug 2013
Saturation Characteristics
Tamura reserve the right to modify its products in order to improve them without prior notice
Mechanical dimensions in mm
Tolerance : ±0.5
Unit : mm
Terminal No.
1. -Vcc
2. lout
3. +Vcc
Connector
Plating of terminal : Sn
Weight : 560g
Maker
Molex
Part No.
6410-03C (38-00-6293)
*Unless specified, tolerance shall be ±0.5mm
很抱歉,暂时无法提供与“S29S1T0D24ZM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1842.54480
- 200+735.18840
- 500+710.62920
- 1000+698.49000
- 国内价格 香港价格
- 12+1265.5859912+163.03647
