S29S1T0D24ZJ
S29S1T0D24ZJ
    TAMURA
    S29S1T0D24ZJ
S29S1T0D24ZJ 数据手册
Hall Effect Current Sensor S29S1T0D24ZJ Features: Advantages:           Closed Loop type Current or voltage output Conversion ratio K = 1:5000 Panel mounting with JST : BH3P-VH-1.  Large aperture  Insulated plastic case according to Specifications Excellent accuracy and linearity Very low temperature drift No insertion loss High Immunity to external interferences Optimised response time Wide supply voltage range UL94V0 TA=25ºC, VCC=±24V Parameters Symbol S29S1T0D24ZJ Rated Current If 1000A Ifmax Maximum Current 70°C ±15V 85°C If = ± ADC RM Measuring resistance @ 85°C 70°C ±24V 85°C ± 2100A (see below) 1000A : 0Ω ~ 21Ω 1200A : 0Ω ~ 9Ω 1300A : 0Ω ~ 5Ω 1000A : 0Ω ~ 18Ω 1200A : 0Ω ~ 7Ω 1000A : 0Ω ~ 60.5Ω 1800A : 0Ω ~ 14Ω 2100A : 0Ω ~ 4Ω 1000A : 10Ω ~ 58.5Ω 1800A : 10Ω ~ 12Ω K Conversion Ratio 1 : 5000 Output Current IOUT ± 200mA Offset Current IOE ≤ ± 0.4mA @ If = 0A1 Output Current Accuracy X IOUT ± 0.4% (without IOf) Output Linearity εL ≤ ± 0.1% @ If Supply Voltage VCC ± 15V ~ ± 24V (±5%) Consumption Current ICC ± 35mA (Output Current is not included) Response Time2 tr < 1.0μs @ di/dt = 100A / μs Output Temperature Characteristic TCIOUT < ± 0.01 % / ºC @ If (without TCIOE) Offset Temperature Characteristic TCIOE ≤± 0.8mA max @ If = 0A IOH ≤ 0.2mA (0A  3 x If) Hysteresis allowance Insulation Withstanding Vd AC 4000V, for 1minute (sensing current 0.5mA), inside of aperture  terminals Insulation Resistance RIS > 500MΩ (@ DC 500V) inside of aperture  terminals Frequency Bandwidth f DC .. 100 kHz Secondary Coil Resistance RS 48Ω @ TA = 70ºC 50Ω @ TA = 85ºC Operating Temperature TA – 40ºC ~ +85ºC Storage Temperature TS – 40ºC ~ +90ºC 1 Offset current value is after removal of core hysteresis — 2 Time between 90% input current full scale and 90% of sensor output full scale Electrical Performances Frequency Characteristics S29S1T0D24ZJrevA, Aug 2013 Saturation Characteristics Tamura reserve the right to modify its products in order to improve them without prior notice Hall Effect Current Sensor S29S1T0D24ZJ Mechanical dimensions in mm Tolerance : ±0.5 Unit : mm Terminal No. 1. -Vcc 2. lout 3. +Vcc Connector Plating of terminal : Sn S29S1T0D24ZJrevA, Aug 2013 Weight : 560g Maker JST Part No. BH3P-VH-1 *Unless specified, tolerance shall be ±0.5mm Tamura reserve the right to modify its products in order to improve them without prior notice
S29S1T0D24ZJ 价格&库存
很抱歉,暂时无法提供与“S29S1T0D24ZJ”相匹配的价格&库存,您可以联系我们找货
