CR4210S-5
CR4210S-5
    CR
    Module
    SENSOR CURRENT XFMR 5A AC
CR4210S-5 数据手册
Self Powered AC Current Transducer DIN RAIL / PANEL MOUNT, AVERAGE RMS The CR4210 and CR4211 Series Current Transducers are self powered. These transducers are calibrated to provide a 0-5 VDC and 0-10 VDC signal that is proportional to the average RMS input AC current. Designed for multi-point current sensing, these devices provide excellent features in a value package. Applications Multi-point current sensing and control panels Remote current sensing Monitor motor faults Monitor heating elements Monitor lighting elements CR4210 CR4211 Transducers C Features Single Element - .79” Window 2 to 600 AAC Input Range 35mm DIN Rail or Panel Mount Available with 0 - 5 VDC or 0-10 VDC outputs Self powered, requires no external power source Use with external current transformers Low cost Connection diagram printed on case Regulatory Agencies Recognized to meet UL 61010B-1 Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004 Meets requirement of IEC 61010-1 and BS EN 61010-1 CR4210S CR4211S Single Element - 1.22” Window 5 to 200 AAC Input Range E199795 All single phase current transducers are available in split core design. Simply put an “S” at the end of the prefix* I.E. CR4210S-10 * Not UL Recognized Average 3 Phase Sensing PART NUMBERS - Single element with 0 - 5 VDC output (split core design) Single element with 0 - 10 VDC output (split core design)* *CR4210S and CR4211S only available in ranges 20 amps and above CR4210(S) CR4211(S) Add suffix for input range 2 5 10 20 50 70 100 150 200 - 0-2 AAC 0-5 AAC 0-10 AAC 0-20 AAC 0-50 AAC 0-70 AAC 0-100 AAC 0-150 AAC 0-200 AAC Ranges available up to and including 600 AAC The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 34 E-mail: sales@crmagnetics.com Self Powered AC Current Transducer DIN RAIL / PANEL MOUNT, AVERAGE RMS SPECIFICATIONS Basic Accuracy:.............................. 0.5% Linearity:......................................... 10% to 100% FS Thermal Drift:.................................. 500 PPM/°C Operating Temperature:................. 0°C to +60°C Installation Category:.................... CAT II Vibration Tested To:........................IEC 60068-2-6,1995 Pollution Degree:........................... 2 Insulation Voltage:........................ 2500 VDC Altitude:......................................... 2000 meter max. Frequency Range:......................... 50Hz - 400Hz Calibration:..............Average Sensing, RMS Calibrated MTBF:....................................Greater than 100 K Hours Cleaning:........................ Output Load:.................. Response Time:............. Relative Humidity:.......... Supply Power:................ Water-dampened cloth 2K Ω or Greater 250 ms max., 0-90%FS 5% to 95%, Non-Condensing Self powered (output voltage is obtained from current-sensing conductor) Torque Specs.:................ 3.0 inch lbs. (0.4Nm) Weight:............................ 0.5 lbs. C OUTLINE DRAWING DIN RAIL MOUNTING CLIP [20.1] .79 [41.8] 1.65 [25] .98 [76.6] 3.02 [73.1][83.3] 2.88 3.28 [50.7] 2.00 [5.6] .22 TYP [28.3] 1.12 [88.7] 3.49 Top View [36.6] 1.44 CR4210 CR4211 [3.3] .13 Optional Mounting End View CONNECTION DIAGRAM Request CR Magnetics Low & Medium Voltage Current Transformers Catalog. 1 2 3 4 + 9 8 7 6 5 OUTPUT 1 - CR4210 Single Element 0 - 5 VDC Output CR4211 Single Element 0 - 10 VDC Output NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 35 E-mail: sales@crmagnetics.com Transducers [26.6] 1.05
CR4210S-5 价格&库存
很抱歉,暂时无法提供与“CR4210S-5”相匹配的价格&库存,您可以联系我们找货
