CR4320-30
CR4320-30
    CR
    Module
    SENSOR CURRENT XFMR 30A AC
CR4320-30 数据手册
TRANSDUCERS Solutions For Voltage, Current, Power & Frequency CURRENT SOLUTIONS An Advanced Line Of Precision Transducers: • True RMS • DC Sensing • Loop Powered • Self Powered • Active & Reactive Power TM www.crmagnetics.com sales@crmagnetics.com Ph: 636-343-8518 Fx: 636-343-5119 544 Axminister Dr. Fenton, MO 63026 USA Specialists in Electrical Current and Power Monitoring Products CURRENT True RMS, Average RMS, DIN Rail, Panel Mount, Rugged Environment, Multi-phase, Mono-phase, AC & DC VOLTAGE True RMS, Average RMS, DIN Rail, Panel Mount, Rugged Environment, Multi-phase, Mono-phase, AC & DC POWER Active, Reactive, 1, 2, or 3 Elements, DIN Rail, Panel Mount FREQUENCY Sine Wave, Square Wave, Zero-Cross, DIN Rail, Panel Mount © 2003 CR Magnetics, Inc. — All rights reserved The information in this catalog has been carefully checked and is believed to be accurate; however, no responsibiliy is assumed for any inaccuracies. CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 3 transducer03a Selection Guide TRANSDUCERS CURRENT AC DC AC/DC True RMS RMS Average RMS 24 Vdc Power Source Elements Input Range 24 Vdc Loop Powered 1 2 3 1 2 1 1 0.5 - 150 Aac 0.5 - 15 Aac 0.5 - 15 Aac 0.5 - 50 Aac 0.5 - 50 Aac 5 - 400 Aac 5 - 200 Aac 0 - 5 Vdc 4-20 mAdc Output 1 1 4-20 mAdc 1 20 - 300 0 - 300 5 - 600 Aac/dc Adc Aac ±DC - 4 KHZ DIN/ PANEL PANEL DIN/PANEL Mounting Part Number 120 Vac Self Powered Powered 0-5 Vdc 0-10 Vdc 4-20 mAdc ±5 Vac/dc 0-5 Vdc 4-20 mAdc CR4110 CR4120 CR4150 CR4160 CR4170 CR4180 CR4220 CR4260 CR4320 CR4310 CR4311 CR4340 CR5410 CR5210 CR5220 6 6 6 14 14 10 8 12 16 18 Agency Approval Page 4 transducer03a Selection Guide TRANSDUCERS POWER VOLTAGE DC AC RMS Active/Reactive AC Average RMS True RMS 3∆ 3Y 1 24 Vdc Loop Powered 24 Vdc 1 50-500 Vac 120-480 Vac .05-200 Vdc DIN/PANEL PANEL 0-5Vdc 4-20 mAdc 2 Sine Wave Square Wave Zero-Cross 12 Vdc 3∆ 3Y 1 FREQUENCY 1 24 Vdc 3∆ 3Y 1 5-50 Aac 150-500 Vac 100-5000K Hz DIN/PANEL 0 - 5 Vdc 4-20 mAdc 4-20 mAdc CR4510 CR4520 CR4550 CR4560 CR4570 CR4580 CR4620 CR4640 CR4730 CR4731 20 20 24 24 22 CR5310 CR5320 CR6210 CR6211 CR6220 CR6221 CR6230 CR6231 CR6240 CR6241 CR6250 CR6251 CR6260 CR6261 CR6610 CR6611 CR6612 CR6620 CR6621 CR6622 26 28 28 28 32 CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 5 transducer03a Selection Guide RELAYS and INDICATORS Relays Indicators Part Number CR4395 CR7310 CR9321 CR45 Model 18 & 19 Description Current Relay Ground Fault Sensor Current Switch Current Indicator Current Indicator Current Indicator Frequency 60/400 Hz 60/400 Hz 50/400Hz 50/60 Hz 50/60 Hz 50/400 Hz Input Range .01 to 100 Aac .01 to 100 Aac 0.350 Aac 2 to 100 Aac 2 to 100 Aac 2 to100 Aac Output Relay Transistor Triac Relay Transistor Triac Solid State Visual Visual Visual Accuracy — — — — — — Dimensions (H)x(W)x(D) 2.13 x 3.50 x 2.5 (54.1x88.9x63.5) 2.13 x 3.50 x 2.5 (54.1x88.9x63.5) See Catalog See Catalog Power Source 120 Vac 240 Vac 24 Vdc 120 Vac 240 Vac 24 Vdc Agency Approval 1.50x1.0x.75 1.04x.95x.46 (38.1x25.4x19.1) (26.4x24.1x11.7) CR2550 Self Powered Self Powered Self Powered Self Powered — — — — Contact factory or see Internet site for additional information on our Current Sensing Relays and Visual Current Indicators. 6 transducer03a Selection Guide CURRENT TRANSFORMERS Current Transformers 17,18, 19 CR8750 CR8400 CR8300 Wire Lead Commercial ANSI Class Horizontal Mount Wire Lead Split Core Vertical Mount Medium Voltage 50-400 Hz 50-400 Hz 50-400 Hz — 50-400 Hz 50-400 Hz 50-400 Hz Up to 60 Aac Up to 4,000 Aac Up to 60 Aac — Up to 10,000 Aac Up to 100 Aac Up to 3,000 Aac — 5.0, 1.0 0.2, 0.1 AAC — — 5.0 Aac & High Ratios — 5.0 Aac — Up to 0.3% — — Up to 0.3% — Up to 0.3% .29 & .55 (7.4 & 14.0) See Catalog .250 (6.4) .232 to .610 (5.8 to 15.5) See Catalog .272 to .772 (6.9 to 19.6) See Catalog — — — — — — — — — — Contact factory or see Internet site for additional information on our Current Transformers. CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 7 transducer03a True RMS AC Current Transducer DIN RAIL / PANEL MOUNT, TRUE RMS The CR4100 Series true RMS Current Transducers and Transmitters are designed for applications where AC current waveforms are not purely sinusoidal. More precise and accurate than other transducers, these devices are ideal in chopped wave and phase fired control systems. E199795 Regulatory Agencies CR4110 • Approved to UL3111-1, First Editon, Ammendment 2 • Approved to CAN/CSA-C22.2, No. 1010.1-92 • Meets requirement of IEC 61010-1 and BS EN 61010-1 CR4120 One Element - .79” Window 0.5 to 150 Aac Range Applications • • • • Phase fired controlled heaters Quickly varying motor loads Chopped wave form drivers Harmonic currents Features • • • • • • CR4150 CR4160 Two Element - .26” Window 0.5 to 30 Aac Range 35mm DIN Rail or Panel Mount Available with 0 - 5 Vdc or 4 - 20 mA DC outputs 24 Vdc powered Use with external current transformers Highest precision available Connection diagram printed on case Internet Resources http://www.crmagnetics.com/ • Pricing: pricing/4100.html • Application Sheets: pdf/ancr4310.pdf, pdf/ancr4310-2.pdf, pdf/ancr4320.pdf CR4170 CR4180 Three Element .26” window 0.5 to 30 Aac Range See page 34 for typical applications Part Numbers CR4110 CR4120 CR4150 CR4160 CR4170 CR4180 * - ❑ ❑ ❑ ❑ ❑ ❑ Single element with 0 - 5 Vdc output Single element with 4 - 20 mA DC output Two element with 0 - 5 Vdc output * Two element with 4 to 20 mA DC output * Three element with 0 - 5 Vdc output * Three element with 4 - 20 mA DC output * Two and three element transducers are available only in ranges of 0.5 to 30 Aac ❑ .5 5 10 15 20 25 30 - Add suffix for input range 0-.5 0- 5 0-10 0-15 0-20 0-25 0-30 Aac * Aac * Aac * Aac * Aac * Aac * Aac * 40 50 75 100 150 - 0-40 Aac 0-50 Aac 0-75 Aac 0-100 Aac 0-150 Aac Other Ranges Available 8 transducer03a True RMS AC Current Transducer Specifications Basic Accuracy:...................... Calibration:................................ Thermal Drift:............................ Operating Temperature:............ Installation Catagory:................ Polution Degree:....................... Insulation Voltage:.................... Altitude:..................................... Frequency Range:.......... MTBF:............................ Cleaning:........................ Supply Voltage:.............. Output Load:.................. 20 Hz - 5 KHz Greater than 100 K hours Water-dampened cloth 24 Vdc ±10% 4-20 mA dc - 0 to 300 Ω 0-5 Vdc - 2K Ω or Greater Response Time:............. 250 ms max. 0-90% FS Relative Humidity:.......... 80% for temperatures up to 31°C and decreasing linearly to 50% at 40°C 0.5% True RMS Sensing 500 PPM/°C 0°C to +60°C CAT II 2 2500 Vdc 2000 meter max. Connection Drawings CR4110 One Element 0 - 5 Vdc Output CR4120 One Element 4 - 20 mA DC Output CR4150 Two Element 0 - 5 Vdc Output CR4160 Two Element 4 - 20 mA DC Output CR4170 Three Element 0 - 5 Vdc Output CR4180 Three Element 4 - 20 mA DC Output Note: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. Outline Drawing 1 hole, 0.79 (20) Dia. for CR4110 & CR4120, shown 2 holes, 0.26 (6.5) Dia. for CR4150 & CR4160 3 holes, 0.26 (6.5) Dia. for CR4170 & CR4180 inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 9 transducer03a AC Current to Voltage Transducer PANEL MOUNT RUGGED CONDITION, AVERAGE SENSING The CR4310 Series, current-to-voltage transducer produces a DC voltage output signal that is proportional to the input average RMS AC current. Designed for use with sinusoidal AC current signals, these devices provide an easy implementation of most AC current sensing requirements. E154235 Applications • • • • Directly connect to PLC high impedance inputs Sense motor stalls and short circuits Process control loops Industrial instrumentation Features • Permanently calibrated and sealed for rugged • • • • environments Continuous operation at 150% of Full Scale Output overload protected Self-powered, requires no external power source 5 & 10 Vdc output available CR4310 CR4311 .93” Window Internet Resources http://www.crmagnetics.com/ • Pricing: pricing/4310.html • Application Sheet: pdf/ancr4310.pdf, pdf/ancr4310-2.pdf Part Numbers CR4310 - ❑ CR4311 - ❑ ❑ 0 - 5 Vdc output 0 - 10 Vdc output 5 10 15 20 30 40 50 75 100 150 200 10 Add suffix for input range - 0-5 Aac 0-10 Aac 0-15 Aac 0-20 Aac 0-30 Aac 0-40 Aac 0-50 Aac 0-75 Aac 0-100 Aac 0-150 Aac 0-200 Aac Accuracy 1.0 0.75 0.75 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 transducer03a AC Current to Voltage Transducer Specifications Accuracy:....................................Depends on the range, see Part Numbers table Calibrated Signal Out:.............. 0 - 5 Vdc for CR4310 0 - 10 Vdc for CR4311 Max. Signal Out:...................... 16 Vdc for CR4310 33 Vdc for CR4311 Response Time:..........................250 ms max., 10-90% FS Continuous Thermal Current Rating Factor:...2.50 @ 30°C Short Time Thermal Current Rating Factor:.60 x FS (1 Sec) Operating Temperature Range:. -30°C to +60°C Storage Temperature Range:.... -55°C to +85 °C Shipping Weight:....................... 1.5 pounds (.68 kg.) Frequency:.............................. 50/60 Hz Ripple:......................... 1% Max. peak Insulation Class:.......... 600 V, BIL 10 KV Full Wave Output Load: 4310 - 1 Meg Ω or Greater 4311 - 150 K Ω or Greater Connection Drawing Outline Drawing inch (mm) Typical Application + + - + - + - 3-PHASE SYSTEMS Three-phase systems may be monitored by attaching three transducers in series. The total output voltage will be the sum of each individual transducer. If each transducer is sized for the full-scale current, the output voltage will be 0-15 Vdc for the CR4310 Series (0-30 Vdc for the CR4311 Series) at 0 to 100% full-scale. As an alternate, each transducer may be sized for three times the full-scale current, then the output voltage for the CR4310 will be 0-5 Vdc for 0 to 100% full-scale. CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 11 transducer03a 2-Wire AC Current Transmitter PANEL MOUNT RUGGED CONDITION, AVERAGE SENSING The CR4320 Series, Loop-powered, Current Transmitter produces 4 - 20 mA DC output current proportional to the input average RMS AC current. These devices provide long range monitoring of AC sinusoidal currents in an easy to install package. E154235 Applications • • • • • Remote sensing of current from distant locations Sense motor stalls and short circuits Process control loops Industrial automation Electrically noisy environments 5-200 Aac input .93 Window Features • Permanently calibrated and sealed for rugged environments Loop powered 2-wire connection eases installation • • Output overload protected • Continuous operation at 130% full scale Internet Resources http://www.crmagnetics.com/ • Pricing: pricing/4320.html • Application Sheet: pdf/ancr4320.pdf 300 and 400 Aac input 1.25 Window Part Numbers CR4320 - ❑ ❑ 2-Wire AC Current Transmitter Add suffix for input range .93” Window 5 10 15 20 30 50 75 100 150 200 12 - 0-5 Aac 0-10 Aac 0-15 Aac 0-20 Aac 0-30 Aac 0-50 Aac 0-75 Aac 0-100 Aac 0-150 Aac 0-200 Aac 1.25” Window 300 400 - 0-300 Aac 0-400 Aac * * not UL recognized transducer03a 2-Wire AC Current Transmitter Specifications Accuracy:.................................. ±0.5% Full-Scale Repeatability:............................ Less than 0.1% Ripple & Noise:......................... 1% max. P/P Calibrated Signal Out:............... 4 - 20 mA DC Response Time:....................... 200 ms max. Max. Signal Out:....................... 30 mA DC Temperature Coefficient:.......... ± 0.04%/°C Supply Voltage:......................... 24 Vdc ±10% Frequency:................................ 50/60 Hz Continuous Thermal Rating Factor:.1.33 @ 30°C. Output Load:............................. 0 to 600 Ω Insulation Class:........................ 600 V, BIL 10 KV Full Wave Reverse Polarity Protection:...... Yes Operating Temperature Range: -30°C to +60°C Storage Temperature Range:.... -55°C to +85°C Approximate Weight:................. 1.5 pounds (.68 kg) Short Time Thermal Current Rating Factor (30 Sec.): 6.0 x Full Scale for AC ranges up to 200 Amp. 4.0 x Full Scale for ranges 300 and 400 Amp. Connection Drawing Outline Drawings inch (mm) 300 and 400 Aac input 5-200 Aac input Typical Application EXTERNAL CURRENT TRANSFORMERS The transducers and transmitters may be used with an external split-core or solid-core current transformer. The external transformer can be used to access remote loads or where the current-carrying wire is too large to fit through the window opening of the unit. A standard, 5 Amp secondary, commercial grade current transformer would be attached with the secondary leads threaded through the window opening. A transducer or transmitter with a 0-5 Amp input range would be selected. Request CR Magnetics current transformer catalog. CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 13 transducer03a 4-Wire AC Current Transmitter PANEL MOUNT RUGGED CONDITION, AVERAGE SENSING The CR4340 Series Current Transmitter produces a calibrated 4 - 20 mA DC signal proportional to the average RMS input AC current. The output signal is produced by an internal current generator powered from an external 120 Vac supply. E154235 Applications • • • • • Remote current sensing of distant locations Sense motor stalls and short circuits Process control loops Stand alone or small instrumentation systems Electrically noisy environments 5-75 Aac input .94” Window Features • Permanently calibrated and sealed for rugged environments • Direct attachment to instrumentation without the need of a DC power supply in the loop • Output overload protected • Continuous operation at 130% Full Scale Internet Resources http://www.crmagnetics.com/ Pricing: pricing/4340.html Application Sheet: pdf/ancr4340-1.pdf 100-600 Aac input 2.13” Window Part Numbers ❑ CR4340 - ❑ Add suffix for input range .94” Window 4-Wire AC Current Transmitter 5 - 2.13” Window 0-5 Aac 20 0-10 Aac 0-15 Aac 0-20 Aac * * * 75 0-25 Aac 0-50 Aac 0-75 Aac * * * 100 150 200 300 400 600 - 0-100 0-150 0-200 0-300 0-400 0-600 Aac Aac Aac Aac Aac Aac * Range set with field selectable switch 14 transducer03a 4-Wire AC Current Transmitter Specifications Accuracy:.................................. ±0.5% Full-Scale Ripple & Noise:......................... 1% max., P/P Calibrated Signal Out:............... 4-20 mA DC Response Time:........................ 150 ms max. Supply Voltage:........................ 120 ±10% Vac Frequency:............................... 50/60 Hz Continuous Thermal Current Rating Factor: 1.50 @ 30°C for ranges up to 75 Amp. 1.33 @ 30°C for ranges 100 Amp. and over Output Load:.......................................... 0 - 1000 Ω Operating Temperature Range:............. -30°C to +60°C Storage Temperature Range:................ -55°C to +85°C Temperature Coefficient:........................ ±0.02%/°C Max. Signal Out:..................................... 30 mA DC Insulation Class:.......... 600 V, BIL 10 KV Full Wave Short Time Thermal Current Rating Factor (For 30 Sec.): 15.0 x Full Scale for AC ranges up to 75 Amp. 4.0 x Full Scale for ranges 400 Amp. and over Outline Drawings inch (mm) 5-75 Aac input 100-600 Aac input Connection Drawings CR4340 CR4340 5 - 75 Aac 100 - 600 Aac CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 15 transducer03a Loop-Powered AC Current Transmitter DIN RAIL / PANEL MOUNT, AVERAGE SENSING The CR4200 Series, Current Transmitters produce a calibrated 4-20 mA DC signal that is proportional to the average RMS input AC current. Designed for multi-point current sensing, these devices provide excellent features in a high value package. The output signal is generated from a user supplied 24 Vdc power supply within the output current loop. E199795 Regulatory Agencies • Approved to UL3111-1, First Editon, Ammendment 2 • Approved to CAN/CSA-C22.2, No. 1010.1-92 • Meets requirement of IEC 61010-1 and BS EN 61010-1 Applications • • • • • CR4220 One Element - .79” Window 0.5 to 50 Aac Range Multi-point current sensing and control panels Remote current sensing Monitor motor faults Monitor heating elements Monitor lighting elements Features Relatively low cost 35mm DIN rail or panel mount High Accuracy Easy wiring Interfaces with most commercially available instrumentation • Connection diagram printed on case • • • • • CR4260 Two Element - .26” Window 0.5 to 30 Aac Range Internet Resources http://www.crmagnetics.com/ See page 34 for typical applications • Pricing: pricing/4200.html Part Numbers ❑ CR4220 - ❑ CR4260 - ❑ * Single element with 4 to 20 mA DC output Two element with 4 to 20 mA DC output * Two element transducers are available only in ranges of 0.5 to 30 Aac Add suffix for input range .5 5 10 15 20 25 30 40 50 - 0-.5 0- 5 0-10 0-15 0-20 0-25 0-30 0-40 0-50 Aac * Aac * Aac * Aac * Aac * Aac * Aac * Aac Aac Other Ranges Available 16 transducer03a Loop-Powered AC Current Transmitter Specifications Basic Accuracy:..................... 0.5% Thermal Drift:......................... 500 PPM/°C Operating Temperature:......... 0°C to +60°C Installation Catagory:............ CAT II Polution Degree:.................... 2 MTBF:.................................... Greater than 100 K hours Altitude:.................................. 2000 meter max. Response Time:..................... 250 ms max., 0-90% FS Calibration:............... Average Sensing, RMS Calibrated Insulation Voltage:....... 2500 Vdc Loop Voltage:.............. 24 Vdc Frequency Range:...... 20Hz- 4 KHz Compliance Voltage:... 16 to 28 Vdc Typical Load:............... 0 To 300 Ω @ 24 Vdc Cleaning:..................... Water-dampened cloth Response Time:.......... 250 ms max., 0-90% FS Relative Humidity:....... 80% for temperatures up to 31°C and decreasing linearly to 50% at 40°C Connection Drawings CR4220 CR4260 One Element - 4 - 20 mA DC Output Two Element 4 - 20 mA DC Output CR4220 CR4260 One Element with external current transformer * Two Element with external current transformer * * REQUEST CR MAGNETICS LOW AND MEDIUM VOLTAGE CURRENT TRANSFORMER CATALOG Note: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. Outline Drawing 1 hole, 0.79 (20) Dia. for CR4220, shown 2 holes, 0.26 (6.5) Dia. for CR4160 inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 17 transducer03a AC/DC Hall Effect Current Transducer DIN RAIL / PANEL MOUNT, TRACING OUTPUT The CR5400 Series, AC/DC Hall Effect Current Transducers, are designed to provide a bipolar output that proportionally reflects (traces) the waveform of the input current. These devices are specifically targeted to be used in applications where multi-mode current sensing is required. Applications • Inverter and multi-frequency drives • Multi-mode ground paths carrying both AC and DC signals • Feed back loop building block Features • • • • CR5410 .79” Window Output isolated from input Non-contact current sensing 35mm DIN Rail or Panel Mount Connection diagram printed on case See page 35 for typical applications Internet Resources http://www.crmagnetics.com/ Pricing: pricing/5400.html Part Numbers CR5410 - ❑ ❑ Add suffix for input range ±5 Vac/dc output .79” Window 20 30 50 75 100 150 300 18 - ±20 A ac/dc ±30 A ac/dc ±50 A ac/dc ±75 A ac/dc ±100 A ac/dc ±150 A ac/dc ±300 A ac/dc transducer03a AC/DC Hall Effect Current Transducer Specifications Basic Accuracy:...................... 1.0% Thermal Drift:.......................... 500 PPM/°C Operating Temperature:.......... 0°C to +50°C Insulation Voltage:................... 2500 Vdc MTBF:............................. Greater than 100 K hours Supply Voltage:........................ Frequency Range:................... Output:..................................... Output Load:............................ 24 Vdc ±10% DC - 4 KHz ±5 Vac/DC 2 K Ω or greater Connection Drawing + CR5410 ±5 Vac/DC Output Outline Drawing inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 19 transducer03a DC Current Transducer DIN RAIL / PANEL MOUNT The CR5200 Series, DC Current Transducers are designed to provide a DC signal which is proportional to a DC sensed current. These devices are designed for direct current only, targeting them towards general and daily applications. The ranges 2 to 10 Amp utilize an advanced Magnetic Modulator technology and the ranges 20 amps and above utilize Hall Effect technology. Applications • • • • Battery chargers and systems DC motor drives Power supply management Mobile applications 2 to 10 Adc input .51” Window Features • • • • • Closed loop sensing for accuracy 35mm DIN rail or panel mount 0 - 5 Vdc or 4 - 20 mA DC outputs Non-contact DC current sensing Connection diagram printed on case 20 to 300 Adc input .79” Window Internet Resources http://www.crmagnetics.com/ Pricing: pricing/5200.html See page 34 for typical applications Part Numbers CR5210 - ❑ CR5220 - ❑ ± 5 Vdc output ❑ 4 - 20 mA DC output Add suffix for input range .51” Window 2 5 10 - 20 0-2 Adc 0-5 Adc 0-10 Adc .79” Window 20 30 50 75 100 150 300 - 0-20 Adc 0-30 Adc 0-50 Adc 0-75 Adc 0-100 Adc 0-150 Adc 0-300 Adc transducer03a DC Current Transducer Specifications Basic Accuracy:...................... Thermal Drift:.......................... Operating Temperature:.......... Response Time: ..................... Insulation Voltage:................... 1.0 % 500 PPM/°C 0°C to +50°C 250 ms. max.,0-90% FS 2500 Vdc Supply Voltage:............................... 24 Vdc ±10% Frequency Range:.......................... DC only MTBF:............................. Greater than 100 K hours Output Load:......0-5 Vdc................ 2 K or greater 4-20 mA DC......... 0 - 300Ω Connection Drawing + + - - CR5210 CR5220 0 - 5 Vdc Output 4 - 20 mA DC Output Outline Drawing 0.51 (13) Dia. for ranges 2 to 10 Adc 0.79 (20) Dia. for ranges 20 to 200 Adc inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 21 transducer03a True RMS AC Voltage Transducer DIN RAIL / PANEL MOUNT, TRUE RMS The CR4500 Series, true RMS Voltage Transducers and Transmitters are designed for applications where AC voltage waveforms are not purely sinusoidal. More precise and accurate than other devices, these units are ideal in chopped wave and phase fired control systems. E199795 Regulatory Agencies • Approved to UL3111-1, First Editon, Ammendment 2 • Approved to CAN/CSA-C22.2, No. 1010.1-92 • Meets requirement of IEC 61010-1 and BS EN 61010-1 CR4520 CR4510 Single Phase Applications • • • • Phase fired controlled devices Quickly varying voltage supplies Chopped waveform drivers Harmonic voltages Features • • • • • • 35mm DIN rail mount or panel mount Available with 0-5 Vdc or 4-20 mA DC outputs 24 Vdc powered Highest precision available Outputs isolated from inputs Connection diagram printed on case Internet Resources http://www.crmagnetics.com/ CR4550 CR4560 CR4570 CR4580 Three Phase • Pricing: pricing/4500.html Part Numbers CR4510 CR4520 CR4550 CR4560 CR4570 CR4580 - ❑ ❑ ❑ ❑ ❑ ❑ Single Phase with 0 to 5 Vdc Output Single Phase with 4 - 20 mA DC Output 3-Phase 3-Wire with 0 to 5 Vdc Output 3-Phase 3-Wire with 4 - 20 mA DC Output 3-Phase 4-Wire with 0 to 5 Vdc Output 3-Phase 4-Wire with 4 - 20 mA DC Output ❑ Add suffix for input range 50 150 250 500 - 0-50 Vac 0-150 Vac 0-250 Vac 0-500 Vac * Other Ranges Available * not UL recognized 22 transducer03a True RMS AC Voltage Transducer Specifications Basic Accuracy:........................ Calibration:............................... Thermal Drift:........................... Operating Temperature:........... Installation Catagory:............... Polution Degree:...................... Response Time: ...................... Altitude:.................................... Insulation Voltage:.................... Supply Voltage:..............24 Vdc ±10% Frequency Range:.........20 Hz - 5 KHz Cleaning:.......................Water-dampened cloth MTBF:......................... Greater than 100 K hours Output Load:............0-5 Vdc - 2 K Ω or greater 4-20 mA dc - 0 to 300 Ω Relative Humidity:....80% for temperatures up to 31°C and decreasing linearly to 50% at 40°C 0.5% True RMS sensing 500 PPM/°C 0°C to +60°C CAT II 2 250 ms 2000 meter max. 2500 Vdc Connection Drawings CR4520 CR4510 Single Phase - 4 - 20 mA DC Output Single Phase - 0 - 5 Vdc Output CR4550 CR4560 3 Phase, 3 Wire - 0 - 5 Vdc Output 3 Phase, 3 Wire - 4-20 mA DC Output CR4580 CR4570 3 Phase. 4 Wire - 0 - 5 Vdc Output 3 Phase - 4 Wire - 4 - 20 mA DC Output Outline Drawing 2.20 (56) for CR4620 2.99 (76) for CR4640 inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 23 transducer03a 3-Phase AC Voltage Transmitter PANEL MOUNT RUGGED CONDITION, AVERAGE SENSING The CR4730 Series, AC Voltage Transmitters are expanded scale instruments designed to accurately measure three-phase AC voltages. Each model produces three discrete 4-20 mA DC signals which are proportional to each three-phase AC voltage. E154235 Applications • Sense phase loss • Use in power calculations and applications • Use in feed-forward motor drive controls CR4730 CR4731 Features Internet Resources http://www.crmagnetics.com/ • Permanently calibrated and sealed for rugged environments Pricing: pricing/4730.html Application Sheet: pdf/ancr4730-1.pdf • Fully isolated outputs and inputs • Expanded scale allows more accurate monitoring of small variances • Available in line-to-line and line-to-neutral models Scaling PART NUMBERS APPLICATION NOMINAL VOLTAGE RANGE CR4730-120 Line-to-line 120 V CR4730-480 (Dual Range) Line-to-line CR4731-120 Line-to-neutral 120 V CR4731-277 Line-to-neutral 277 V 240 V 480 V INPUT VOLTAGE RANGE INPUT BURDEN (MAX) TRANSFER FUNCTION ILOOP MA DC = EIN - 75 3.75 EIN - 150 180 V to 300 V 0.1 VA @ 265 V 7.5 EIN - 300 360 V to 600 V 0.1 VA @ 530 V 15 EIN - 75 90 V to 150 V 0.1 VA @ 150 V 3.75 EIN - 150 180 V to 300 V 0.1 VA @ 300 V 7.5 EIN = Volts RMS 90 V to 150 V 0.1 VA @ 240 V Part Numbers CR4730-120 CR4730-480 CR4731-120 CR4731-277 3 3 3 3 Phase, Phase, Phase, Phase, 3 3 4 4 Wire, Wire, Wire, Wire, Line to Line, 120 Vac Nominal Line to Line, 240/480 Vac Nominal, Dual Range Line-to-Neutral, 120 Vac Nominal Line-to-Neutral, 277 Vac Nominal 24 transducer03a 3-Phase AC Voltage Transmitter Specifications Nominal Input Voltages:....... 120, 240, 277 & 480 Vac Accuracy:.............................. ±0.5% Full-Scale (FS) Ripple On Output:................. Less than 1% Calibrated Signal Out:........... 4 - 20 mA DC Temperature Coefficient:..... ± 0.03%/°C Supply Voltage:..................... 24 Vdc ± 10% Response Time:.................... 1.50 sec. max., 10 - 90% FS Frequency:.................................... 50/60 Hz Max. Continuous Input Voltage: ... 600 V Operating Temperature Range: ... -30°C to +60°C Storage Temperature Range:....... -50°C to +85°C Reverse Polarity Protection:.......... Yes Load Resistance:.......................... 0-600 Ω Shipping Weight:......... Approx: 1.3 Pounds (.59 kg) Connection Drawings CR4730-120 CR4731-120 CR4731-277 3 Phase, 3 Wire 120 VL- L 3 Phase, 4 Wire 120 VL-N 3 Phase, 4 Wire 277 VL- N 180-300 VL- L Connection 360-600 VL- L connection CR4730-480 3 Phase, 3 Wire Outline Drawing Side View Top View inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 25 transducer03a Loop-Powered AC Voltage Transmitter 4-20 mA DC LOOP POWERED, AVERAGE SENSING The CR4600 Series, Loop-Powered AC Voltage Transmitters are designed to provide a 4 - 20 mA DC output that is proportional to the average RMS AC voltage input. These devices are best suited for general applications, such as fixed frequency voltage supplies. E199795 Regulatory Agencies • Approved to UL3111-1, First Editon, Ammendment 2 • Approved to CAN/CSA-C22.2, No. 1010.1-92 • Meets requirement of IEC 61010-1 and BS EN 61010-1 CR4620 One Element Transmitter Features • • • • Monitor for over/under voltage Sense phase loss Power monitoring Multi-point instrumentation needs Applications • • • • 35 DIN Rail or Panel Mount Outputs isolated from inputs One or two element Connection diagram printed on case Internet Resources http://www.crmagnetics.com/ CR4640 Two Element Transmitter • Pricing: pricing/4600.html See page 35 for typical applications Part Numbers CR4620 - ❑ CR4640 - ❑ ❑ Single Element with 4 - 20 mA DC output Two Element with 4 - 20 mA DC output Add suffix for input range 50 150 250 500 - 0-50 Vac 0-150 Vac 0-250 Vac 0-500 Vac * Other Ranges Available * not UL recognized 26 transducer03a Loop-Powered AC Voltage Transmitter Specifications Basic Accuracy:........................ 0.5% Thermal Drift:............................ 500 PPM/°C Operating Temperature:............ 0°C to +60°C Polution Degree:....................... 2 Installation Catagory:................ CAT II Response Time: ...................... 250 ms Insulation Voltage:.................... 2500 Vdc Altitude:..................................... 2000 meter max. Calibration:........... Average Sensing, RMS Calibrated Power Source:.......... Loop Powered Loop Voltage:........... 24 Vdc Frequency Range:.... 20Hz - 5 KHz Typical Load:............. 0 - 300 Ω @ 24 Vdc Compliance Voltage:. 16 to 28 Vdc MTBF:....................... Greater than 100 K hours Cleaning:.................. Water-dampened cloth Relative Humidity:..... 80% for temperatures up to 31°C and decreasing linearly to 50% at 40°C Connection Drawings CR4620 CR4640 Two Element, 4 - 20 mA DC Output One Element 4 - 20 mA DC Output CR4640 Two Element with CR4620 One Element with External Voltage Transformers * * External Voltage Transformers * * * * USE CR MAGNETICS LOW AND MEDIUM VOLTAGE POTENTIAL TRANSFORMERS Note: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. Outline Drawing 2.20 (56) for CR4620 2.99 (76) for CR4640 inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 27 transducer03a DC Voltage Transducer DIN RAIL / PANEL MOUNT The CR5300 Series, DC Voltage Transducers and Transmitters, are designed to provide an output DC signal that is proportional to the input DC voltage. These devices are especially suited for applications with a current shunt to monitor DC current. E199795 Regulatory Agencies • Approved to UL3111-1, First Editon, Ammendment 2 • Approved to CAN/CSA-C22.2, No. 1010.1-92 • Meets requirement of IEC 61010-1 and BS EN 61010-1 Applications • • • • Power Supply over/under sensing Battery chargers and systems Mobile applications Power sensing Features • • • • CR5310 Output isolated from input 0 - 5 Vdc or 4 - 20 mAdc outputs 35mm DIN rail or panel mount Connection diagram printed on case CR5320 Internet Resources http://www.crmagnetics.com/ Pricing: pricing/5300.html Part Numbers ❑ CR5310 - ❑ CR5320 - ❑ 0 - ±5 Vdc Output 4 - 20 mAdc Output Add suffix for input range .01 .05 .1 1 10 50 150 200 - 0-0.01 Vdc 0-0.05 Vdc 0-0.1 Vdc 0-1 Vdc 0-10 Vdc 0-50 Vdc 0-150 Vdc 0-200 Vdc other ranges available 28 transducer03a DC Voltage Transducer Specifications Insulation Voltage:.... Supply Voltage:........ Frequency Range:.... Output Load:............. 2500 Vdc 24 Vdc ± 10% DC 0-5 Vdc - 2 K Ω or Greater 4-20 mAdc - 0 to 300 Ω Cleaning:.................. Water-dampened cloth Relative Humidity:..... 80% for temperatures up to 31°C and decreasing linearly to 50% at 40°C Basic Accuracy:....................... 0.5% Calibration:............................... RMS Calibrated Thermal Drift:.......................... 200 PPM/°C Operating Temperature:........... 0°C to +60°C Installation Catagory:............... CAT II Polution Degree:...................... 2 Response Time: ..................... 250 ms Altitude:................................... 2000 meter max. MTBF:............................... Greater than 100 K hours Connection Drawings CR5310 CR5320 0 - ±5 Vdc Output 4 - 20 mAdc Output Note: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. Outline Drawing inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 29 transducer03a AC Power Transducer DIN RAIL / PANEL MOUNT, AVERAGE SENSING The CR6200 Series, Power Transducers and Transmitters are designed to provide a controlled output that is proportional to the average power. These devices are specifically targeted to provide an efficient solution to most power sensing needs. Units are designed for operation in systems with sinusoidal voltage and current wave forms. E199795 Regulatory Agencies • Approved to UL3111-1, First Editon, Ammendment 2 • Approved to CAN/CSA-C22.2, No. 1010.1-92 • Meets requirement of IEC 61010-1 and BS EN 61010-1 CR6210, CR6211 CR6220, CR6221 Applications • • • • Energy Management Motor Efficiency Multi-point power sensing Remote power sensing over long distances CR6230, CR6231 CR6240, CR6241 Features • • • • • 35mm DIN Rail or Panel Mount Ranges available for any power sensing need Active and Reactive power sensing 0 - 5 Vdc and 4 - 20 mAdc outputs Connection diagram printed on case Internet Resources http://www.crmagnetics.com/ • Pricing: pricing/6200.html • Application Sheets: pdf/an6230-1.pdf, CR6250, CR6251 CR6260, CR6261 pdf/an6250-1.pdf Part Numbers CR6210 CR6211 CR6220 CR6221 CR6230 CR6231 CR6240 CR6241 CR6250 CR6251 CR6260 CR6261 - ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ - ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ ❑ 1 Phase, Active Power with 0 - 5 Vdc Output 1 Phase, Reactive Power with 0 - 5 Vdc Output 1 Phase, Active Power with 4 - 20 mAdc Output 1 Phase, Reactive Power with 4 - 20 mAdc Output 3-Phase, 3-Wire, Active Power with 0 - 5 Vdc Output 3-Phase, 3-Wire, Reactive Power with 0 - 5 Vdc Output 3-Phase, 3-Wire, Active Power with 4 - 20 mAdc Output 3-Phase, 3-Wire, Reactive Power with 4 - 20 mAdc Output 3-Phase, 4-Wire, Active Power with 0 - 5 Vdc Output 3-Phase, 4-Wire, Reactive Power with 0 - 5 Vdc Output 3-Phase, 4-Wire, Active Power with 4 - 20 mAdc Output 3-Phase, 4-Wire, Reactive Power with 4 - 20 mAdc Output ❑ 150 250 500 ❑ - 0-150 Vac 0-250 Vac 0-500 Vac * other ranges available * not UL recognized 5 20 50 - 0-5 Aac 0-20 Aac 0-50 Aac other ranges available 30 transducer03a AC Power Transducer Specifications Frequency Range:................. 20Hz - 5 KHz, sine wave Insulation Voltage:................. 2500 Vdc Altitude:................................. 2000 meter max. Output Load:............ 4-20 mAdc -0 to 300 Ω 0-5 Vdc - 2K Ω or Greater Cleaning:................. Water-dampened cloth Relative Humidity:... 80% for temperatures up to 31°C and decreasing linearly to 50% at 40°C Basic Accuracy:......................... 0.5% Thermal Drift:............................ 500 PPM/°C Operating Temperature:............ 0°C to +60°C Installation Catagory:................. CAT II Polution Degree:........................ 2 Response Time: ....................... 250 ms max. 0-90% FS Supply Voltage:......................... 12 to 24 Vdc MTBF:............................... Greater than 100 K hours Connection Drawings CR6210 CR6211 CR6220 Single Phase, 0 - 5 Vdc Output CR6210 CR6220 CR6211 CR6231 CR6240 3 Phase - 3 Wire, 0 - 5 Vdc Output CR6230 CR6221 Single Phase, 4 - 20 mAdc Output with external voltage transformers Single Phase, 0 - 5 Vdc Output with external voltage transformers CR6230 CR6221 Single Phase, 4 - 20 mAdc Output CR6241 3 Phase - 3 Wire, 4 - 20 mAdc output CR6231 CR6240 3 Phase - 3 Wire, 0 - 5 Vdc Output with external voltage and current transformers CR6241 3 Phase - 3 Wire, 4 - 20 mAdc Output with external current transformer Note: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 31 transducer03a AC Power Transducer Connection Drawings CR6250 CR6260 CR6251 CR6261 Three Phase - 4 Wire, 4 - 20 mAdc Output shown with external current transformers Three Phase - 4 Wire, 0 - 5 Vdc Output shown with external voltage and current transformers Typical Application POWER TRANSDUCER A university campus needs to monitor the power coming into each building and record the results at a central location. The incoming feeds are rated at 480/277, 2000 amps, 3-phase, 4-wire Y. An ANSI Metering Class Current Transformer, part number CR170RL-202, is selected from the CR Magnetics current transformer catalog to convert the full-load current down to 5 Amps for input to the transducer. The voltage legs are connected directly to the transducer. Outline Drawing 1 hole, 0.79 (20) Dia. for single phase, shown CR6210 thur CR6221 2 holes, 0.26 (6.5) Dia. 3-Phase, 3-Wire CR6230 thur CR6241 3 holes, 0.26 (6.5) Dia. for 3-Phae, 4-Wire CR6250 thur CR6261 inch (mm) 32 transducer03a AC Motor Loads & U.S. Standard Voltages A C Motor Loads * MOTOR FULL LOAD CURRENTS SINGLE PHASE HP 1/2 3/4 1 11/2 2 3 5 71/2 10 15 20 25 30 40 50 60 75 100 125 150 200 115 V 9.8 13.8 16 20 24 34 56 80 100 MAXIMUM LOCKED ROTOR CURRENTS 3-PHASE A.C. INDUCTION 230 V 4.9 6.9 8 10 12 17 28 40 50 115 V 4 5.6 7.2 10.4 13.6 200 V 2.3 3.2 4.15 6 7.8 11 17.5 25 32 48 62 78 92 120 150 177 221 285 358 415 550 OVER 200 HP APPROX. AMPS / HP 230 V 2 2.8 3.6 5.2 6.8 9.6 15.2 22 28 42 54 68 80 104 130 154 192 248 312 360 480 460 V 1 1.4 1.8 2.6 3.4 4.8 7.6 11 14 21 27 34 40 52 65 77 96 124 156 180 240 575 V .8 1.1 1.4 2.1 2.7 3.9 6.1 9 11 17 22 27 32 41 52 62 77 99 125 144 192 2.75 2.40 1.20 3-PHASE A.C. INDUCTION 2300 V 4160 V 200 V 23 29 34.5 46 57.5 73.5 106 146 186 267 334 420 500 667 834 16 8.9 1000 20 11 1250 26 14.4 1670 31 17 2085 37 20.5 2500 49 27 3340 .96 .24 220/230 V 440/460 V 550/575 V 2300 V 20 10 8 25 12.5 10 30 15 12 40 20 16 50 25 20 64 32 25 92 46 37 127 63 51 162 81 65 232 116 93 290 145 116 365 182 146 35 435 217 174 41 580 290 232 55 725 362 290 69 870 435 348 83 1085 592 435 104 1450 725 580 139 1815 907 726 173 2170 1085 870 208 2900 1450 1160 278 4160 V 19 23 30 38 46 57 76 96 115 153 .133 *This information provided as reference only. Consult motor manufacturer and related standards for additional information. U.S. STANDARD VOLTAGES SINGLE-PHASE POLYPHASE A A A LINE 240 (480) 120 (240) N GROUND B LINE 120 (240) [480] 240 (480) 208 (416) B 120 (240) [480] 120 (240) 120 (240) [480] 240 (480) 120 (240) 120 V, 3 W (240 V, 3 W) [480 V, 3 W] THREE-PHASE, THREE-WIRE 240/120 V, 4 W (480/240 V, 4 W) THREE-PHASE, FOUR-WIRE DELTA 208 (480) LINE 120 (277) B 120 (240) [480] N B N 120 (240) 120/240 V, 3 W (240/480 V, 3 W) THREE-WIRE A C C GROUND A 208 (480) 120 (277) 208 (480) N 120 (277) 120 V, 2 W (240 V, 2 W) [480 V, 2 W] TWO-WIRE C 208Y/120 V, 4 W (480Y/277 V, 4 W) THREE-PHASE, FOUR-WIRE WYE CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 33 transducer03a Frequency Transducer DIN RAIL / PANEL MOUNT The CR6600 Series, Frequency Transducers and Transmitters are designed to give a DC output that is proportional to an input frequency value. These devices are especially suited to variable frequency systems. Applications • • • • Applications monitor generator sets Multi-frequency control and monitoring Inverter drives and systems Power quality monitoring Features • • • • • CR6610 CR6611 CR6612 Outputs isolated from inputs Ranges available for any application Sine, square and zero crossover waveforms 35 DIN rail or panel mount Connection diagram printed on case CR6620 CR6621 CR6622 Internet Resources http://www.crmagnetics.com/ Pricing: pricing/6600.html Part Numbers CR6610 CR6611 CR6612 CR6620 CR6621 CR6622 - ❑ ❑ ❑ ❑ ❑ ❑ Sine wave sensing with 0 - 5 Vdc Output Square wave sensing with 0 - 5 Vdc Output Zero crossover sensing with 0 - 5 Vdc Output Sine wave sensing with 4 - 20 mAdc Output Square wave sensing with 4 - 20 mAdc Output Zero crossover sensing with 4 - 20 mAdc Output ❑ Add suffix for input range 100 500 5000 - 0-100 Hz 0-500 Hz 0-5000 Hz Other Ranges Available 34 transducer03a Frequency Transducer Specifications Basic Accuracy:...................... 0.5% Thermal Drift:.......................... 500 PPM/°C Operating Temperature:.......... 0°C to +50°C Response Time: ..................... 250 ms. max, 0-90 % FS Insulation Voltage:................... 1500 Vdc MTBF:............................. Greater than 100 K hours Supply Voltage:........ 24 Vdc ±10% Output Load:.............. 4-20 mAdc - 0 to 300 Ω 0-5 Vdc - 2K Ω or Greater Input Voltage:............ 20 to 250 V Peak, (other voltage ranges available) Connection Drawings CR6610 CR6620 0 - 5 Vdc Output 4 - 20 mAdc Output Outline Drawing inch (mm) CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 35 transducer03a Typical Applications This illustrates a typical application for monitoring current to a 3-Phase motor. External current transformers are attached to each of the three incoming power lines. The secondary leads from each current transformer are routed through the window openings in the CR4170 True RMS Current Transducer. A standard 5 Amp secondary current transformer is recommended to be attached to a transducer rated for 5 Amp input. With the transducer attached to a PLC, the over/under current and phase loss conditions can be monitored. OVER/UNDER CURRENT MONITORING Looping the primary current-carrying wire several times through the window opening may change the scaling factor. The “actual” measurement range will be the nameplate rating of the transducer divided by the number of wire passes. For example, the CR4220-30 has a nameplate rating of 0-30 Aac. Three passes of the wire through the window opening will then provide an effective range of 0-10 Aac (30/3). LOOP-POWERED AC CURRENT TRANSMITTER DC current may be monitored by using the voltage transducer attached to a resistive shunt. The illustration shows a CR5310-.05 transducer with an input range of 0-50 mv attached to a standard 50 mv resistive shunt. The output is attached to a standard 0-5 Vdc panel meter. DC CURRENT MONITORING 36 transducer03a Typical Applications This illustrates a typical application for monitoring the voltage supply to a motor. The transmitter is attached to the incoming voltage supply leads. Use the CR4600 or CR4700 series for an AC supply and the CR5300 series for a DC supply. The transmitter output is attached to standard 4-20 ma, loop-powered panel meter. The transmitter may also be attached to a PLC to monitor for over/under voltage and phase loss. VOLTAGE MONITORING A plant manager needs to record the total charge to a bank of batteries. A CR5210 DC Current Transducer is attached to one of the incoming current lead and a CR5310 is attached to the incoming voltage lines. The output from each transducer is attached to a 0-5 Vdc analog input module on a PLC. The PLC computates the product of the current and voltage for the total power useage. DC POWER MEASUREMENT CR Magnetics, Inc. 544 Axminister Dr. Fenton MO USA 63026 V: 636.343.8518 F: 636.343.5119 Web: http://www.crmagnetics.com E-mail: sales@crmagnetics.com 37 transducer03a 3-Phase Balanced Circuits 3-Phase Delta A 3-Phase WYE IL IL IP E L-L Z C E L-L Z Z A E L-L IL B Z IL E L-N E L-N Z E L-L B IL E L-L E L-L Z 2 P=1.73 EL-L IL cos 0 = 3(EL-L) Z 1.73 E L-L Z= IL L I IP = 1.73 E L-N IL C P = 3 EL-N IL cos 0 = 1.73 EL-L IL cos 0 IL= EL-N = EL-L Z 1.73 Z Z = EL-L 1.73 IP EL-N = EL-L 1.73 • The current in each element is equal to the line current I L divided by 3. • The voltage across each element is equal to the line voltage EL-L. • The current in each element is equal to the line current I. • The impedance of each element is equal to 3 times the voltage across each element divided by the line current. • The voltage across each element E L-N is equal to the line voltage EL-L divided by 3 • The voltage across the elements are 120° out of phase. • The currents in the elements are 120° out of phase. • The impedance of each element is equal to line voltage EL-L divided by 3 times the line current. • The power is equal to 3 times voltage across each element times the • The voltages across the elements are 120° out of phase. current I L times COS O. • The currents in the elements are 120° out of phase. • The power is equal to 3 times line voltage E L-N times line current times COS O. P = power in watts O = phase angle in degrees • For a balanced load the current in the neutral is equal to zero. 3-Phase Open Leg Circuits 3-Phase WYE (No neutral) 3-Phase Delta A IA IL I A-C C E L-L Z Z I C-B IB B IC E L-L E L-L A B Z E L-L IL Z E L-L E L = E L-L 2 2 P= 2(EL-L) Z EL-L IA-C = IC-B = IA = IB = Z IC = 1.73 IA = 1.73 IB E L-L C I L= 0 P= EL-L IL COS 0 EL-L IL= 2 Z • The current in each non-open element is equal. • The current in the connecting leg of the non-open elements is 3 times the current in any other leg. • The current in each non-open element is equal to the line current. • The voltage across each non-open element is equal to the line voltage divided by 2. • The power is equal to the line voltage times the line current times COS O. 38 transducer03a Manufacturers & Designers Of Electrical Current & Power Monitoring Products For Industrial Market Applications Throughout The World CR MAGNETICS, INC. 544 Axminister Drive Fenton, MO 63026 USA PHONE: 636 343-8518 FAX: 636 343-5119 E-MAIL: sales@crmagnetics.com WEB SITE: www.crmagnetics.com Code TRANSDUCER 03A
CR4320-30 价格&库存
很抱歉,暂时无法提供与“CR4320-30”相匹配的价格&库存,您可以联系我们找货
