L07P015S05
L07P015S05
    TAMURA
    Module
L07P015S05 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L07P***S05 Series Features: Advantage:              Open Loop type Dual integrated primary Unipolar power supply Printed circuit board mounting Insulated plastic case according to UL94V0  UL Recognition Excellent accuracy and linearity Wide nominal current range Low temperature drift Wide frequency bandwidth No insertion loss High Immunity To External Interference Optimised response time Current overload capability Specifications TA=25ºC, VCC=+5V, RL=10kΩ Parameters Symbol L07P003S05 L07P005S05 L07P010S05 L07P015S05 L07P020S05 L07P025S05 L07P030S05 If Primary nominal current 3A 5A 10A 15A 20A 25A 30A Ifmax ≥ ± If x 1.5 Rated output voltage Vo Vof + 1.250V ± 0.040V (at If) Offset Voltage1 Vof Vref 1± 0.040V (at If = 0A) Output Linearity2(0A~If) εL ≤ ±1% (at If) Power supply voltage VCC + 5V ± 5% Consumption Current IC ≤ ±30mA Response Time3 tr ≤ 5μs (at di/dt = If / µs) Thermal drift of gain4 TcVo ≤ ±2.0mV / ºC Thermal drift of offset TcVof ≤ ±2mV / ºC VOH ≤ 15mV (at If = 0A→If →0A) Insulation voltage Vd AC2000V for 1minute (sensing current 0.5mA), primary  secondary Insulation Resistance RIS ≥ 500MΩ (at DC500V), primary  secondary TA -30ºC ~ +80ºC TS -40C ~ +85ºC Saturation current Hysteresis error Ambient operation temperature Ambient storage temperature 1 VREF = VCC /2 (ratiometric) . After removal of core hysteresis— 2 Without offset — 3 Time between 10% input current full scale and 90% of sensor output full scale. each channel's value,non-measured circuit is set to 0A. — 4 Without Thermal drift of offset Electrical Performances Saturation characteristic Frequency characteristic(L07P020S05) 5.0 6 4.5 TA=25ºC Pulsed 4.0 2 Output voltage (V) Attenuation (dB) 4 0 -2 -4 -6 3.5 3.0 2.5 L07P003S05 2.0 1.5 L07P015S05 1.0 -8 L07P025S05 0.5 -10 0.1 1 10 Frequency characteristic(kHz) @ If=3(Arms) L07PXXXS05revD, March 2012 100 0.0 -60 -40 -20 0 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 20 40 60 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L07P***S05 Series Mechanical dimensions 11.2 12 NOTES 1. Unit is mm 2. Tolerance is 0.5mm 25 φD φ0.6 φ0.8 φ1.4 φ1.6 7 6 3.6 UL Standard +If1 UL 508 , CSA C22.2 No.14 (UL FILE No.E243511) -If1 +VCC VOUT1 VOUT2 +VCC(+5V) 2 NC 3 VOUT1 4 VOUT2 5 GND 6 Primary input current1 (+) 7 Primary input current1 (-) 8 Primary input current2 (+) 9 Primary input current2 (-) • For use in Pollution Degree 2 Environment. • Maximum Surrounding air temperature rating, 80˚C. 8 +If2 54321 Electrical connection diagram NC 1 5 rectangular pins 0.25x0.5 6 7.2 Function 1.5 5 4 3 2 1 7 A 3A 5A 10~15A 20~30A 8 4.75 16 9 9.4 11.2 4.75 Terminal RL = 10kΩ 9 -If2 GND Package & Weight Information Weight Pcs/box Pcs/carton Pcs/pallet 12g 100 400 9600 L07PXXXS05revD, March 2012 Tamura reserve the right to modify its products in order to improve them without prior notice
L07P015S05 价格&库存
很抱歉,暂时无法提供与“L07P015S05”相匹配的价格&库存,您可以联系我们找货
