TD-065
TD-065
    E-T-A
    TD-065
TD-065 数据手册
TD Over Current Detector Description Hall effect type current sensor with a single digital output factory programmed to go low when a given current threshold is exceeded. The TD Series is able to operate within a temperature range of -40o C to 125o C and has a fast response time of 1!s (typical). The miniature package size allows the TD series to be mounted on printed circuit boards and is integrated with an open collector digital output which is ideal for interfacing to control circuitry. Typical Applications Welding equipment, servo drives, treadmills, automotive power conversion, power supplies, home audio, MRI equipment Series TD Ordering Information Technical Data Type No TD Over Current Detector Trip Point 015 15 Amp 020 20 Amp 025 25 Amp 030 30 Amp 035 35 Amp 040 40 Amp 045 45 Amp 050 50 Amp 055 55 Amp 060 60 Amp 065 65 Amp 070 70 Amp 075 75 Amp 080 80 Amp 085 85 Amp 090 90 Amp 095 95 Amp 100 100 Amp 105 105 Amp 110 110 Amp 115 115 Amp 120 120 Amp 125 125 Amp TD 025 = ordering example Absolute Maximum Ratings Supply Voltage Voltage Externally Applied to Output Output ON current (sink) Operating Temp Range Sensed Current RMS voltage for AC isolation test, 50/60 Hz, 1 minute -1.0 to +25 VDC +25 VDC max (Output high, current below Itrip) -0.5 VDC min (Output high or low) 50 mA -40o C to +125o C +/- 500 Amp peak 2.5 kVac Absolute maximum ratings are the extreme limits that the detector will withstand without damage. Electrical operation and characteristics are not guaranteed as the maximum limits are approached. Proper application of the detector must ensure that the detector operates within the operating characteristics below. Operating Characteristics Supply Voltage Supply Current Operating Temperature Output Trip Time Output ON Voltage Output ON Current Symbol Vs Is Is Ttrip Min Typ. 3.8 -40 1.0 0.15 Vos Ios Max 24.0 10.0 125 2.5 0.40 20 Notes VDC mA o C !S, di/dt=Itrip/!S VDC sinking 20 mA mA Note 1: Detector sensitive to unidirectional current as defined in mechanical dimension drawing 01/2009 www.e-t-a.com 1551 Bishop Ct.; Mt. Prospect , IL 60056 P: (847) 827-7600 F: (847) 827-7655 !D 8ver Current Detector !rip Currents 0Amps 2 34o C6 !rip Current 15 20 25 30 35 40 45 50 55 60 65 70 75 :in 13.2 17.6 22 26.4 30.8 35.2 39.6 44 48.4 52.8 57.2 61.6 66 :a; 16.8 22.4 28 33.6 39.2 44.8 50.4 56 61.6 67.2 72.8 78.4 84 !rip Current 80 85 90 95 100 105 110 115 120 125 :in 70.4 74.8 79.2 83.6 88 92.4 96.8 101.2 105.6 110 :a; 89.6 95.2 100.8 106.4 112 117.6 123.2 128.8 134.4 140 !rip Current vs. !emperature Figure 2 - TD-030 35 40 30 35 30 25 Trip Point (Amps) Trip Point (Amps) Figure 1 - TD-025 20 15 10 25 20 15 10 5 0 5 40 20 0 0 20 40 60 80 100 120 Temperature (C) Figure 4 - TD-040 Figure 3 - TD-035 60 50 50 Trip Point (Amps) Trip Point (Amps) 40 30 20 10 40 30 20 10 40 20 0 0 20 40 60 80 100 120 Temperature (C) 40 20 0 20 40 60 80 100 120 Temperature (C) Maximum Typical Minimum Maximum Typical Minimum 01/200% 20 40 60 80 100 120 Temperature (C) Maximum Typical Minimum Maximum Typical Minimum 0 40 20 0 www.e-t-a.com 1551 Bishop Ct.1 Mt. Prospect , IL 60056 P: (=47) =27-7600 F: (=47) =27-7655 !0 1+er &'rrent 0ete2tor !ri$ &'rrent +,. !e.$erat're !i#ure 6 - FGA!&! 60 70 50 60 40 50 Trip Point (Amps) Trip Point (Amps) !i#ure 5 - FGA!>& 30 20 40 30 20 10 0 10 40 20 0 0 20 40 60 80 100 120 Temperature (C) 40 20 40 60 80 100 120 Maximum Typical Minimum !i#ure 8 - FGA"!! !i#ure 7 - FGA!?& 140 100 90 120 80 70 Trip Point (Amps) Trip Point (Amps) 0 Temperature (C) Maximum Typical Minimum 60 50 40 30 20 100 80 60 40 20 10 0 20 40 20 0 20 40 60 80 0 100 120 40 20 0 20 40 60 80 100 120 Temperature (C) Temperature (C) Maximum Typical Minimum Maximum Typical Minimum !i#ure 9 - FGA"$& 160 140 Trip Point (Amps) 120 100 80 60 40 20 0 40 20 0 20 40 60 80 100 120 Temperature (C) Maximum Typical Minimum !"#$!!% CCC05A/AD06,E "&&" ()*+,- ./01 2/0 34,*-56/ 7 89 :!!&: 3; ?@ =$?A?:!! B; ?@ =$?A?:&& =* >?er 6urre&4 *e4e#4-r !e#$%&i#%( *i+e&,i-&, - / 0%#1%ge 0.660" TD50 R 0.047" 0.253" R 0.250" Dimensions are in inches Dimensional tolerances unless otherwise specified: +/- 0.010” R 0.085" 0.160" MAX 0.363" Pin 1 2 3 4 5 0.535" MAX 0.313" 0.112" +/- 0.025" 0.015" +/- 0.002" SQUARE 0.104" Desc. Vo GND Vs Iin Iout 4 0.275" 0.160" 0.325" 1 2 3 0.050" X 2 0.660" CURRENT CONVENTION: CURRENT TO BE DETECTED FLOWS INTO TERMINAL 4 AND OUT OF TERMINAL 5. 5 0ri&4e5 6ir#ui4 8-%r5 !-u&4i&g F--4:ri&4 Solder side (component side view) Component side (component side view) C1 C1 A1 A2 A3 A1 A2 A3 C2 C2 ;-(e *e,#ri:4i-& 6$%r4 ;-(e
TD-065 价格&库存
很抱歉,暂时无法提供与“TD-065”相匹配的价格&库存,您可以联系我们找货
TD-065
  • 36+94.4002236+12.22813
