TD Over Current Detector
Description
Hall effect type current sensor with a single digital output factory
programmed to go low when a given current threshold is exceeded. The TD Series is able to operate within a temperature range of
-40o C to 125o C and has a fast response time of 1!s (typical). The
miniature package size allows the TD series to be mounted on
printed circuit boards and is integrated with an open collector digital output which is ideal for interfacing to control circuitry.
Typical Applications
Welding equipment, servo drives, treadmills, automotive power
conversion, power supplies, home audio, MRI equipment
Series TD
Ordering Information
Technical Data
Type No
TD
Trip Point
015
15 Amp
020
20 Amp
025
25 Amp
030
30 Amp
035
35 Amp
040
40 Amp
045
45 Amp
050
50 Amp
055
55 Amp
060
60 Amp
065
65 Amp
070
70 Amp
075
75 Amp
080
80 Amp
085
85 Amp
090
90 Amp
095
95 Amp
100
100 Amp
105
105 Amp
110
110 Amp
115
115 Amp
120
120 Amp
125
125 Amp
TD 025 = ordering example
Absolute Maximum Ratings
Supply Voltage
Voltage Externally Applied to
Output
Output ON current (sink)
Operating Temp Range
Sensed Current
RMS voltage for AC isolation
test, 50/60 Hz, 1 minute
-1.0 to +25 VDC
+25 VDC max (Output high, current
below Itrip)
-0.5 VDC min (Output high or low)
50 mA
-40o C to +125o C
+/- 500 Amp peak
2.5 kVac
Absolute maximum ratings are the extreme limits that the detector will withstand without damage. Electrical operation and characteristics are not guaranteed as the maximum limits are
approached. Proper application of the detector must ensure that the detector operates within
the operating characteristics below.
Operating Characteristics
Supply Voltage
Supply Current
Operating Temperature
Output Trip Time
Output ON Voltage
Output ON Current
Symbol
Vs
Is
Is
Ttrip
Min
Typ.
3.8
-40
1.0
0.15
Vos
Ios
Max
24.0
10.0
125
2.5
0.40
Notes
VDC
mA
o
C
!S, di/dt=Itrip/!S
VDC sinking 20 mA
mA
Note 1: Detector sensitive to unidirectional current as defined in mechanical dimension drawing
01/2009
www.e-t-a.com
1551 Bishop Ct.; Mt. Prospect , IL 60056
P: (847) 827-7600 F: (847) 827-7655
!D 8ver Current Detector
!rip Currents 0Amps 2 34o C6
!rip Current
15
30
35
40
45
50
55
60
65
70
75
:in
13.2
17.6
22
26.4
30.8
35.2
39.6
44
48.4
52.8
57.2
61.6
66
:a;
16.8
22.4
28
33.6
39.2
44.8
50.4
56
61.6
67.2
72.8
78.4
84
!rip Current
80
85
90
95
100
105
110
115
120
125
:in
70.4
74.8
79.2
83.6
88
92.4
96.8
101.2
105.6
110
:a;
89.6
95.2
100.8
106.4
112
117.6
123.2
128.8
134.4
140
!rip Current vs. !emperature
Figure 2 - TD-030
35
40
30
35
30
25
Trip Point (Amps)
Trip Point (Amps)
Figure 1 - TD-025
10
25
10
5
40 20 0
20 40 60 80 100 120
Temperature (C)
Figure 4 - TD-040
Figure 3 - TD-035
60
50
50
Trip Point (Amps)
Trip Point (Amps)
40
30
40
30
40 20 0
20 40 60 80 100 120
Temperature (C)
40 20 0
20 40 60 80 100 120
Temperature (C)
Maximum
Typical
Minimum
Maximum
Typical
Minimum
01/200%
20 40 60 80 100 120
Temperature (C)
Maximum
Typical
Minimum
Maximum
Typical
Minimum
www.e-t-a.com
1551 Bishop Ct.1 Mt. Prospect , IL 60056
P: (=47) =27-7600 F: (=47) =27-7655
!0 1+er &'rrent 0ete2tor
!ri$ &'rrent +,. !e.$erat're
!i#ure 6 - FGA!&!
60
70
50
60
40
50
Trip Point (Amps)
Trip Point (Amps)
!i#ure 5 - FGA!>&
30
30
40 20 0
20 40 60 80 100 120
Temperature (C)
40
60
80
100 120
Maximum
Typical
Minimum
!i#ure 8 - FGA"!!
!i#ure 7 - FGA!?&
140
100
90
120
80
70
Trip Point (Amps)
Trip Point (Amps)
Temperature (C)
Maximum
Typical
Minimum
60
50
40
30
80
60
40
60
80
40 20
60
80
100 120
Temperature (C)
Temperature (C)
Maximum
Typical
Minimum
Maximum
Typical
Minimum
!i#ure 9 - FGA"$&
160
140
Trip Point (Amps)
120
100
80
60
40
60
80
100 120
Temperature (C)
Maximum
Typical
Minimum
CCC05A/AD06,E
"&&" ()*+,- ./01 2/0 34,*-56/ 7 89 :!!&:
3; ?@ =$?A?:!! B; ?@ =$?A?:&&
=* >?er 6urre&4 *e4e#4-r
!e#$%&i#%( *i+e&,i-&, - / 0%#1%ge
0.660"
TD50
R 0.047"
0.253"
R 0.250"
Dimensions are in inches
Dimensional tolerances unless otherwise
specified: +/- 0.010”
R 0.085"
0.160" MAX
0.363"
Pin
1
2
3
4
5
0.535" MAX
0.313"
0.112" +/- 0.025"
0.015" +/- 0.002" SQUARE
0.104"
Desc.
Vo
GND
Vs
Iin
Iout
4
0.275"
0.160"
0.325"
1
2
3
0.050" X 2
0.660"
CURRENT CONVENTION: CURRENT TO BE
DETECTED FLOWS INTO TERMINAL 4 AND
OUT OF TERMINAL 5.
5
0ri&4e5 6ir#ui4 8-%r5 !-u&4i&g F--4:ri&4
Solder side
(component side view)
Component side
C1
C1
A1
A2
A3
A1
A2
A3
C2
C2
;-(e *e,#ri:4i-& 6$%r4
;-(e
很抱歉,暂时无法提供与“TD-100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 36+94.5616936+12.12944
