MP100701
MP100701
    ZF
    Magnetic Hall Effect Sensor Magnet, South Pole Digital Wire Leads Barrel, Aluminum
MP100701 数据手册
Magnetic Proximity Sensors (Hall Effect) MP1005 - MP1007 Sensors Solid state magnetic proximity sensor with electrical immunity protection Description The MP1 Series sensors are one-piece non-contact solid-state position sensors. The sensors operate through the use of Hall Effect technology with magnetic fields generated by permanent magnets. They provide a sinking current output. Features        Typical Applications Solid state reliability Stable output over operating temperature range Compatible with unregulated power supply South pole activated Open collector (sinking or NPN) output can be used with bipolar or CMOS logic circuits with suitable pull-up resistor RoHS compliant IP67      Door position & interlock Limit switch Flow/speed Home security Pedal switch Environmental Specifications -40 °C to 85 ⁰C (-40 ⁰F to 185 ⁰F) -40 °C to 150 ⁰C (-40 ⁰F to 302 ⁰F) -40 °C to 85 ⁰C (-40 ⁰F to 185 ⁰F) -40 °C to 150 ⁰C (-40 ⁰F to 302 ⁰F) IP67 Operating Temperature (MP100502) Operating Temperature (MP100701) Storage Temperature (MP100502) Storage Temperature (MP100701) Ingress Protection Electrical Specifications Operating Supply Voltage Supply Current Output Current (Sink) Output Off Voltage Maximum Input Voltage Maximum Reverse Voltage Pull-up Resistor 5 to 24 VDC 4.1 mA typ., 7.5 mA max. 25 mA max. 30 VDC 30 VDC 30 VDC See chart Mechanical Specifications Housing Material Maximum Installation Torque Limit Aluminium 50 in lbs on threads Products Part Number MP100502 MP100701 Housing Color Red Black Termination 20 AWG x 1 m 20 AWG x 1 m Note: An external pull-up resistor is required, the value of which is dependent on the supply voltage. The resistor should be connected between the output and Vcc. Refer to the wiring diagram for lead colors or pin numbering as applicable. www.cherryswitches.com Page 1 of 2, last update 2015-01-12, Specifications subject to change without notice. Recommended External Pull-Up Resistor Volts DC Ohms 5 1k 9 1.8k Open Collector Sinking Block Diagram Dimensions mm (inches) MP100502 MP100701 www.cherryswitches.com Page 2 of 2, last update 2015-01-12, Specifications subject to change without notice. 12 2.4k 15 3k 24 3k
MP100701 价格&库存
很抱歉,暂时无法提供与“MP100701”相匹配的价格&库存,您可以联系我们找货
