375
    ADAFRUIT
    ROUND SPACER #8 PHENOLIC 2"
375 数据手册
  Magnetic contact switch (door sensor) PRODUCT ID: 375      Description This sensor is essentially a reed switch, encased in an ABS plastic shell. Normally the reed is 'open' (no connection between the two wires). The other half is a magnet. When the magnet is less than 13mm (0.5") away, the reed switch closes. They're often used to detect when a door or drawer is open, which is why they have mounting tabs and screws. You can also pick up some double-sided foam tape from a hardware store to mount these, that works well without needing screws.  Technical Details o o o o o Normally open reed switch ABS enclosure Rated current: 100 mA max Rated voltage: 200 VDC max Distance: 15mm max Dimensions: o o o Box size (each side): 29mm x 14mm x 9mm / 1.1" x 0.6" x 0.4" Cable Length: 305mm ± 12mm / 12" ± 0.5" Weight (per side): 5.4g        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“375”相匹配的价格&库存,您可以联系我们找货
