VN101504
VN101504
    ZF
    Module
    DIGITAL VANE SENSOR 3-PIN
VN101504 数据手册
Digital Vane Sensor VN1015 Sensors Magnetically activated digital vane sensor in a rugged, overmolded plastic housing with three pins or 3-wire flying leads Description The VN1015 sensors employ a Hall Effect digital vane sensor and a permanent magnet in two small towers, separated by a 3.4 mm (0.135”) air gap. The output switches when a ferrous target passes between the towers. Typical targets are linear or rotary vanes using a square saw tooth or an open slot in a solid disk or band. Features • • • • • Mechanically interchangeable with typical slotted optical switches Robust, high speed sensing in dirty/dusty environments No mechanical contacts to wear out Open collector (sinking or NPN) output can be used with bipolar or CMOS logic circuits with suitable pull-up resistor RoHS compliant Typical Applications • • • Door/gate position control Exercise equipment Printers Environmental Specifications Operating Temperature (VN101501, VN101503) Operating Temperature (VN101502, VN101504) Storage Temperature (VN101501, VN101503) Storage Temperature (VN101502, VN101504) -40 °C to 85 °C (-40 °F to 185 °F) -40 °C to 150 °C (-40 °F to 302 °F) -40 °C to 85 °C (-40 °F to 185 °F) -40 °C to 150 °C (-40 °F to 302 °F) Electrical Specifications Supply Voltage Maximum Input Voltage Maximum Reverse Voltage Supply Current Output (Sink) Current Recommended Pull-Up Resistor 3.8 to 24 VDC 30 VDC 30 VDC 4.1 mA typ., 7.5 mA max. 25 mA max. See Chart Mechanical Specifications Housing Material Sensor Orientation Recommended Vane Parameters Over-molded plastic Sensitive; see drawing Low carbon material at least 1.016 mm (0.04") thick, should penetrate to a depth < 3.05 mm (0.12") from bottom of sensor slot Part Number VN101501 VN101502* VN101503 VN101504* *Not commonly stocked; please contact the factory or your distributor Termination pins pins 24 AWG x 150 mm leads 24 AWG x 150 mm leads www.cherryswitches.com Page 1 of 2, Last update 2016-01-12, Specifications subject to change without notice. Note: An external pull-up resistor is required, the value of which is dependent on the supply voltage. The resistor should be connected between the output and Vcc. Refer to the wiring diagram for lead colors or pin numbering as applicable. Recommended External Pull-Up Resistor Volts DC Ohms 5 1k 9 1.8k Open Collector Sinking Block Diagram Dimensions mm (inches) www.cherryswitches.com Page 2 of 2, Last update 2016-01-12, Specifications subject to change without notice. 12 2.4k 15 3k 24 3k
VN101504 价格&库存
很抱歉,暂时无法提供与“VN101504”相匹配的价格&库存,您可以联系我们找货
