Magnetic Proximity Sensors (Hall Effect)
MP1014 Sensors
Digital Hall-effect position sensor
in low-profile flange-mount housing
Description
The MP1 Series sensors are one-piece non-contact solid-state position sensors. The sensors operate through the use of Hall
Effect technology with magnetic fields generated by permanent magnets. They provide a sinking current output.
Features
Typical Applications
Solid state reliability
South pole sensitive
Unipolar device
RoHS compliant
Low profile design
IP65
Door position & interlock
Limit switch
Flow/speed
Home security
Pedal switch
Environmental Specifications
-40 °C to 85 ⁰C (-40 ⁰F to 185 ⁰F)
-40 °C to 100 ⁰C (-40 ⁰F to 212 ⁰F)
IP65
Operating Temperature
StorageTemperature
Ingress Protection
Electrical Specifications
Operating Supply Voltage (MP101401)
Operating Supply Voltage (MP101402)
Supply Current
Output Current (Sink)
Maximum Reverse Voltage (MP101401)
Maximum Reverse Voltage (MP101402)
Pull-Up Resistor
4.5 to 18 VDC
4.5 to 24 VDC
3.0 mA typ., 5.2 mA max.
20 mA max.
18 VDC
15 VDC
See chart
Mechanical Specifications
Housing Material
Glass-reinforced nylon plastic
Products
Part Number
MP101401
MP101402*
*Not commonly stocked
Leads
24 AWG x 314 mm
24 AWG x 314 mm
Note: An external pull-up resistor is required, the value of which is dependent on the supply voltage. The resistor should be
connected between the output and Vcc. Refer to the wiring diagram for lead colors or pin numbering as applicable.
Recommended External Pull-Up Resistor
Volts DC
Ohms
5
1k
9
1.8k
www.cherryswitches.com
Page 1 of 2, last update 2014-10-29, Specifications subject to change without notice.
12
2.4k
15
3k
24
3k
Open Collector Sinking Block Diagram
Dimensions mm (inches)
Page 2 of 2, last update 2014-10-29, Specifications subject to change without notice.
