MP101301
MP101301
    ZF
    Magnetic Hall Effect Sensor Magnet, South Pole Digital Wire Leads Module, Non-Standard
MP101301 数据手册
Magnetic Proximity Sensors (Hall Effect) MP1013 Sensors Hall-effect position sensor with convenient snap-fit mounting Description The MP1 Series sensors are one-piece non-contact solid-state position sensors. The sensors operate through the use of Hall Effect technology with magnetic fields generated by permanent magnets. They provide a sinking current output. Features • • • • • • • • • Solid state reliability Stable output over operating temperature range Open collector (NPN) output can be used with bipolar or CMOS logic circuits with suitable pull-up resistor South pole sensitive Unipolar device (MP101301, MP101302) Latching version available (MP101303) RoHS compliant Fastener-less design IP67 Typical Applications • • • • • Door position & interlock Limit switch Flow/speed Home security Pedal switch Environmental Specifications Operating / Storage Temperature (MP101301, MP101303) Operating / Storage Temperature (MP101302) Ingress Protection -40 °C to 85 ⁰C (-40 ⁰F to 185 ⁰F) -40 ⁰C to 125 °C (-40 ⁰F to 257 ⁰F) IP67 Electrical Specifications Operating Supply Voltage Supply Current (MP101301, MP101302) Supply Current (MP101303) Output Current (Sink) (MP101301, MP101302) Output Current (Sink) (MP101303) Maximum Input Voltage (MP101301, MP101302) Maximum Input Voltage (MP101303) Maximum Reverse Voltage (MP101301, MP101302) Maximum Reverse Voltage (MP101303) Recommended Pull-Up Resistor 5 to 24 VDC 4.1 mA typ., 7.5 mA max. 2.6 mA typ., 5 mA max. 25 mA max. 20 mA max. 30 VDC 28 VDC 30 VDC None See chart Mechanical Specifications Housing Material Glass-reinforced nylon plastic Turn on / off (MP101301, MP101302) 245 Gauss / 60 Gauss Turn on / off (MP101303)* 60 Gauss / 60 Gauss *MP101303 is a latching sensor and releases when 60 Gauss is applied to the north pole www.cherryswitches.com Page 1 of 2, Last update 2016-01-05, Specifications subject to change without notice. Products Part Number MP101301 MP101302* MP101303* *Not commonly stocked Leads 24 AWG x 150 mm 24 AWG x 150 mm 24 AWG x 150 mm Note: An external pull-up resistor is required, the value of which is dependent on the supply voltage. The resistor should be connected between the output and Vcc. Refer to the wiring diagram for lead colors or pin numbering as applicable. Recommended External Pull-Up Resistor Volts DC Ohms 5 1k 9 1.8k Open Collector Sinking Block Diagram Dimensions mm (inches) www.cherryswitches.com Page 2 of 2, Last update 2016-01-05, Specifications subject to change without notice. 12 2.4k 15 3k 24 3k
MP101301 价格&库存
很抱歉,暂时无法提供与“MP101301”相匹配的价格&库存,您可以联系我们找货
