MP1-L-0012-103-5%-RH 数据手册
Features
- Contactless Linear Sensor
- IP64 Debris Proof, Splash Proof
- Ideal for Hydraulic and Pneumatic Position
Sensing
- Liquid Level Capability
- Upon request
- Male or Female Nicomatic Connectors
- Corresponding Exterior Magnet
Mechanical Specifications
Electrical Specifications
-Life Cycle: >1 million
-Height: 3.50mm (0.138")
-Actuation Force: 0.09 to 0.11 lbs pull force at
desired distance (pull force rating is for the
exterior magnet using a test plate of cold rolled
steel).
-Resistance - Standard: 10k Ohms
(lengths >300mm = 20k Ohms)
-Resistance - Custom: 5k to 500k Ohms
-Resistance Tolerance: ±20%
-Effective Electrical Travel: 8 to 1200mm
-Resolution: Depends on the exterior magnet
strength and distance to the MagnetoPot
-Power Rating: 0.50 Watt continuous, 1 Watt Peak
-Dielectric Value: No affect @ 500VAC for 1
minute
-Independant Linearity: ±5% (±1% available)
-Hysteresis: 3mm*
Environmental Specifications
-Operating Temperature: up to +85°C
-IP Rating of Active Area: IP64
*Please note that the hysteresis is directly affected
by the drive magnet size, strength, and distance
from the internal magnet.
Dimensional Diagram - Stock Linear MagnetoPots
PART LENGTH [P]
10.16 [0.400]
TAIL WIDTH
ACTIVE LENGTH [A]
PIN 1
20.32 [0.800]
8.24 [0.325]
TAIL LENGTH [T]
3.81 [0.150]
ACTIVE WIDTH
7.93 [0.312]
A
12.50mm
0.492"
25.00mm
0.984"
50.00mm 100.00mm 150.00mm 171.89mm 200.00mm 300.00mm 400.00mm 500.00mm 750.00mm 1000.00mm
6.768"
29.528"
39.370"
1.969"
3.937"
5.906"
7.874"
11.811"
15.748"
19.685"
P
28.36mm
1.117"
40.86mm
1.609"
65.86mm
2.593"
T
12.70mm
0.500"
spectrasymbol.com
115.86mm
4.562"
165.86mm
6.531"
185.86mm
7.318"
215.86mm
8.499"
315.86mm
12.436"
415.86mm
16.373"
515.86mm
20.310"
765.86mm
30.153"
1015.86mm
39.995"
24.89mm
0.980"
Rev G1 - Page 1
(888) 795-2283
Electrical Schematic
Material Cross-Section
PIN 3 (GND)
3.28 [0.129] CIRCUIT
(LEFT BUS BAR)
10K
PIN 2 (V+)
(RIGHT BUS BAR)
0.05 [0.002] 3M ADHESIVE
PIN 1
3.33 [0.131] TOTAL (±10%)
(COLLECTOR)
How to Order - MagnetoPots
0050
103
Model
Active Length
Resistance
L = Linear
0012 = 12,5mm
0025 = 25mm
0050 = 50mm
0100 = 100mm
0150 = 150mm
0172 = 172mm
0200 = 200mm
0300 = 300mm
0400 = 400mm
0500 = 500mm
0750 = 750mm
1000 = 1000mm
MP1
L
Series
MP1 = MagnetoPot
Active Lengths < 300mm
103 = 10 KOhm
Active Lengths > 300mm
203 = 20 KOhm
Ind. Linearity
5% = ±5%
5%
ST
Connectors
ST = Solder Tab
MP = Male Pins
RH = Receptacles w/Plain Housing
RL = Receptacles w/Latch* Housing
RD = Receptacles w/Detent* Housing
* Please note that the RL and RD style
connectors are only available in one
orientation. Please contact Spectra Symbol
for more infomation.
Standard Connector Options
Crimpflex Solder Tab (ST)
Crimpflex Short Male Pins (MP)
Crimpflex Female Receptacles with a
Plain Housing (RH)
Latch Housing (RL)
with a Detent Housing (RD)
spectrasymbol.com
Page 2
(888) 795-2283
Customization
Customize the size and shape. Such custom requests, for example, can be: custom lengths 10mm-1200mm;
custom rotary diameters, etc. Spectra Symbol would be glad to quote your custom application, just contact us at
sales@spectrasymbol.com or (888)795-2283.
How It Works
The MagnetoPot is simple, yet elegant in its ability to track motion in a contactless manner. A magnet on the
inside of a cylinder, or a magnet on the opposing side of a motion device will guide the built-in magnetics of the
MagnetoPot for position location through a potentiometric output.
The MagnetoPot is a sealed potentiometer, in the membrane potentiometer tradition, yet it does not require a
wiper/actuator to connect the collector and the resistor. Instead, the MagnetoPot is controlled by an outside
magnet, which attracts the magnetic forces within the MagnetoPot to connect to the linear resistor and give linear
potentiometer feedback.
The wiper inside the sealed pot is magnetic or ferromagnetic, and will only perform if connected with an exterior
magnet.
As opposed to a magnetically-based Reed Switch, which gives simply “open” or “close” signals, the MagnetoPot
gives the full linear travel of a hydraulic or pneumatic cylinder.
In liquid level applications, the MagnetoPot can attach to the outside of a liquid tank and give position of the
magnet inside the float. No water ingress, no wearing of the part by environment, because the MagnetoPot is
outside of the tank.
Design and Contruction
The MagnetoPot is made of polyester, fiberglass and kapton, depending on the specification required. It functions
as a voltage divider, a resistor or rheostat, as desired by the end-user. By bringing the exterior magnet into a
proximity necessary to connect with the internal magnetic attractors, the operator can obtain linear position
sensing based on the location of the exterior magnet. As the exterior magnet moves, so does the electrical output
of the MagnetoPot.
The MagnetoPot should not be mounted to a ferromagnetic surface.
spectrasymbol.com
Page 3
(888) 795-2283
Diagram - Stock Rotary MagnetoPot
R32.87 [R1.294]
OUTER DIAMETER
2xR1.59 [R0.062]
R12.70 [R0.500]
THRU
4.83 [0.190]
ACTIVE WIDTH
Ø45.57 [Ø1.794]
CENTER OF TRACK
10.16 [0.400]
353°
ACTIVE
ANGLE
PIN 1
6.08 [0.239]
(TYP)
79.01 [3.111]
PIN 3 (GND)
(LEFT BUS BAR)
PIN 2
(COLLECTOR)
PIN 1 (V+)
10K
(RIGHT BUS BAR)
How to Order - Rotary MagnetoPot
MP1
R
Series
Model
MP1 = MagnetoPot
R = Rotary
0046
Center of
Active Track
0046 = 45.57mm
0353
103
Active Angle
Resistance
0353 = 353°
103 = 10 KOhm
Ind. Linearity
5% = ±5%
spectrasymbol.com
Page 4
5%
ST
Connectors
ST = Solder Tab
MP = Male Pins
RL = Receptacles w/Latch Housing
RD = Receptacles w/Detent Housing
(888) 795-2283
MP1-L-0012-103-5%-RH 价格&库存
很抱歉,暂时无法提供与“MP1-L-0012-103-5%-RH”相匹配的价格&库存,您可以联系我们找货
