GS102301
GS102301
    ZF
    SENSOR HALL DIGITAL CONNECTOR
GS102301 数据手册
Gear Tooth Speed Sensors GS102301 Sensors Threaded, straight connector gear tooth speed sensor rated to 140 °C Description The GS1023 series gear tooth speed sensors are Hall Effect devices designed for use in applications where ferrous edge detection/near zero speed sensing is needed. The single Hall design is immune to alignment issues allowing unlimited mounting positions. They provide a sinking current output. Features        From near zero speed up to 15 kHz sensing capability Resistant to fuels, solvents, and lubricants associated with engines, transmissions, brakes and chassis systems Supplied with installed Viton O-ring Installs into a standard M20 x 1.5 O-ring port RoHS compliant IP67 Typical air gap of 1.5 mm* Typical Applications     Speedometers Anti-lock braking systems Exercise equipment CNC machine tools Environmental Specifications Vibration Mechanical Shock Resistance Maximum Speed Detection Operating Temperature Storage Temperature Ingress Protection Sinusoidal, 15 g max from 40 Hz to 2 kHz 50 g 15 kHz -40 ⁰C to 140 ⁰C (-40 ⁰F to 284 ⁰F) -40 ⁰C to 150 ⁰C (-40 ⁰F to 302 ⁰F) IP67 Electrical Specifications Operating Supply Voltage Maximum Input Voltage Maximum Reverse Voltage Supply Current Output Sink Current Recommended Pull-Up Resistor 5 to 24 VDC 30 VDC 26.5 VDC 3 mA typ., 6 mA max 25 mA max See chart Mechanical Specifications Housing Material Maximum Installation Torque Limit Operating Air Gap / Sensing Distance* * With recommended target type; see drawing Sensor Orientation Glass Reinforced Thermoplastic 68.0 Nm (50 ft lb) on threads 1.5 mm (0.06") Not sensitive Products Part Number GS102301 Connector** Delphi Metri-Pack 150 **Mates to Delphi connector 12162280 www.cherryswitches.com Page 1 of 2, Last saved by 2014-11-05, Specifications subject to change without notice. Note: An external pull-up resistor is required, the value of which is dependent on the supply voltage. The resistor should be connected between the output and Vcc. Refer to the wiring diagram for lead colors or pin numbering as applicable. Recommended External Pull-Up Resistor Volts DC Ohms 5 1k 9 1.8k 12 2.4k 15 3k 24 3k Open Collector Sinking Block Diagram Dimensions mm (inches) Installation For best results, we recommend targets made from low carbon cold rolled steel. Other factors that influence sensor performance include gear tooth height and width, space between the teeth, shape of the teeth and thickness of the target. As a general guideline, consider a target with minimum parameters as shown below. Note that smaller dimensions may work, but testing for the application is required. Tooth Height 5.0 mm (.200") Tooth Width Distance between Teeth 2.5 mm (.100") 10 mm (.400") www.cherryswitches.com Page 2 of 2, Last saved by 2014-11-05, Specifications subject to change without notice. Target Thickness 6.35 mm (.250")
GS102301 价格&库存
很抱歉,暂时无法提供与“GS102301”相匹配的价格&库存,您可以联系我们找货
GS102301
    库存:5
    GS102301
