MP1-L-0400-203-5%-RH
    SPECTRASYMBOL
MP1-L-0400-203-5%-RH 数据手册
Features - Contactless Linear Sensor - IP64 Debris Proof, Splash Proof - Ideal for Hydraulic and Pneumatic Position Sensing - Liquid Level Capability - Upon request - Male or Female Nicomatic Connectors - Corresponding Exterior Magnet Mechanical Specifications Electrical Specifications -Life Cycle: >1 million -Height: 3.50mm (0.138") -Actuation Force: 0.09 to 0.11 lbs pull force at desired distance (pull force rating is for the exterior magnet using a test plate of cold rolled steel). -Resistance - Standard: 10k Ohms (lengths >300mm = 20k Ohms) -Resistance - Custom: 5k to 500k Ohms -Resistance Tolerance: ±20% -Effective Electrical Travel: 8 to 1200mm -Resolution: Depends on the exterior magnet strength and distance to the MagnetoPot -Power Rating: 0.50 Watt continuous, 1 Watt Peak -Dielectric Value: No affect @ 500VAC for 1 minute -Independant Linearity: ±5% (±1% available) -Hysteresis: 3mm* Environmental Specifications -Operating Temperature: up to +85°C -IP Rating of Active Area: IP64 *Please note that the hysteresis is directly affected by the drive magnet size, strength, and distance from the internal magnet. Dimensional Diagram - Stock Linear MagnetoPots PART LENGTH [P] 10.16 [0.400] TAIL WIDTH ACTIVE LENGTH [A] PIN 1 20.32 [0.800] 8.24 [0.325] TAIL LENGTH [T] 3.81 [0.150] ACTIVE WIDTH 7.93 [0.312] A 12.50mm 0.492" 25.00mm 0.984" 50.00mm 100.00mm 150.00mm 171.89mm 200.00mm 300.00mm 400.00mm 500.00mm 750.00mm 1000.00mm 6.768" 29.528" 39.370" 1.969" 3.937" 5.906" 7.874" 11.811" 15.748" 19.685" P 28.36mm 1.117" 40.86mm 1.609" 65.86mm 2.593" T 12.70mm 0.500" spectrasymbol.com 115.86mm 4.562" 165.86mm 6.531" 185.86mm 7.318" 215.86mm 8.499" 315.86mm 12.436" 415.86mm 16.373" 515.86mm 20.310" 765.86mm 30.153" 1015.86mm 39.995" 24.89mm 0.980" Rev G1 - Page 1 (888) 795-2283 Electrical Schematic Material Cross-Section PIN 3 (GND) 3.28 [0.129] CIRCUIT (LEFT BUS BAR) 10K PIN 2 (V+) (RIGHT BUS BAR) 0.05 [0.002] 3M ADHESIVE PIN 1 3.33 [0.131] TOTAL (±10%) (COLLECTOR) How to Order - MagnetoPots 0050 103 Model Active Length Resistance L = Linear 0012 = 12,5mm 0025 = 25mm 0050 = 50mm 0100 = 100mm 0150 = 150mm 0172 = 172mm 0200 = 200mm 0300 = 300mm 0400 = 400mm 0500 = 500mm 0750 = 750mm 1000 = 1000mm MP1 L Series MP1 = MagnetoPot Active Lengths < 300mm 103 = 10 KOhm Active Lengths > 300mm 203 = 20 KOhm Ind. Linearity 5% = ±5% 5% ST Connectors ST = Solder Tab MP = Male Pins RH = Receptacles w/Plain Housing RL = Receptacles w/Latch* Housing RD = Receptacles w/Detent* Housing * Please note that the RL and RD style connectors are only available in one orientation. Please contact Spectra Symbol for more infomation. Standard Connector Options Crimpflex Solder Tab (ST) Crimpflex Short Male Pins (MP) Crimpflex Female Receptacles with a Plain Housing (RH) Crimpflex Female Receptacles with a Latch Housing (RL) Crimpflex Female Receptacles with a Detent Housing (RD) spectrasymbol.com Page 2 (888) 795-2283 Customization Customize the size and shape. Such custom requests, for example, can be: custom lengths 10mm-1200mm; custom rotary diameters, etc. Spectra Symbol would be glad to quote your custom application, just contact us at sales@spectrasymbol.com or (888)795-2283. How It Works The MagnetoPot is simple, yet elegant in its ability to track motion in a contactless manner. A magnet on the inside of a cylinder, or a magnet on the opposing side of a motion device will guide the built-in magnetics of the MagnetoPot for position location through a potentiometric output. The MagnetoPot is a sealed potentiometer, in the membrane potentiometer tradition, yet it does not require a wiper/actuator to connect the collector and the resistor. Instead, the MagnetoPot is controlled by an outside magnet, which attracts the magnetic forces within the MagnetoPot to connect to the linear resistor and give linear potentiometer feedback. The wiper inside the sealed pot is magnetic or ferromagnetic, and will only perform if connected with an exterior magnet. As opposed to a magnetically-based Reed Switch, which gives simply “open” or “close” signals, the MagnetoPot gives the full linear travel of a hydraulic or pneumatic cylinder. In liquid level applications, the MagnetoPot can attach to the outside of a liquid tank and give position of the magnet inside the float. No water ingress, no wearing of the part by environment, because the MagnetoPot is outside of the tank. Design and Contruction The MagnetoPot is made of polyester, fiberglass and kapton, depending on the specification required. It functions as a voltage divider, a resistor or rheostat, as desired by the end-user. By bringing the exterior magnet into a proximity necessary to connect with the internal magnetic attractors, the operator can obtain linear position sensing based on the location of the exterior magnet. As the exterior magnet moves, so does the electrical output of the MagnetoPot. The MagnetoPot should not be mounted to a ferromagnetic surface. spectrasymbol.com Page 3 (888) 795-2283 Diagram - Stock Rotary MagnetoPot R32.87 [R1.294] OUTER DIAMETER 2xR1.59 [R0.062] R12.70 [R0.500] THRU 4.83 [0.190] ACTIVE WIDTH Ø45.57 [Ø1.794] CENTER OF TRACK 10.16 [0.400] 353° ACTIVE ANGLE PIN 1 6.08 [0.239] (TYP) 79.01 [3.111] Electrical Schematic Material Cross-Section PIN 3 (GND) 3.28 [0.129] CIRCUIT (LEFT BUS BAR) PIN 2 (COLLECTOR) 0.05 [0.002] 3M ADHESIVE PIN 1 (V+) 10K 3.33 [0.131] TOTAL (±10%) (RIGHT BUS BAR) How to Order - Rotary MagnetoPot MP1 R Series Model MP1 = MagnetoPot R = Rotary 0046 Center of Active Track 0046 = 45.57mm 0353 103 Active Angle Resistance 0353 = 353° 103 = 10 KOhm Ind. Linearity 5% = ±5% spectrasymbol.com Page 4 5% ST Connectors ST = Solder Tab MP = Male Pins RH = Receptacles w/Plain Housing RL = Receptacles w/Latch Housing RD = Receptacles w/Detent Housing (888) 795-2283
MP1-L-0400-203-5%-RH 价格&库存
很抱歉,暂时无法提供与“MP1-L-0400-203-5%-RH”相匹配的价格&库存,您可以联系我们找货
  • 100+366.86451100+47.46372
