MSS-RFS-100-B
MSS-RFS-100-B
    MAGNASPHERECORP
    Module
    WIRELESS DOOR CONTACT
MSS-RFS-100-B 数据手册
MSS-RFS Introducing the MSS-RFS Series Wireless Security Sensor Designed as a replacement / upgrade for the OEM’s RF sensor, the patent-pending MSS-RFS series provides the strongest FCC allowable output signal while maintaining NEW a 14+ year battery life – IN A NARROW, LOW-PROFILE, AESTHETICALLY APPEALING HOUSING!! Proven Industry History – MAGNASPHERE is the globally recognized High Security switch technology which is quickly becoming the standard for the government’s highest level secure applications. CSI engineers have decades of experience, including the invention of reliable wireless security products. These partner companies have teamed successfully to provide the security systems and components that protect America’s overseas embassies and other high asset locations. Now we can provide the best performing, most secure wireless sensors for all residential and commercial installations. MAGNASPHERE MSS-RFS Technology The MSS-RFS is the only wireless sensor utilizing the award-winning MAGNASPHERE switch technology instead of 70 year-old glass reed switches used by others. The robust all metal MAGNASPHERE switch is impervious to contact welding and resistant to magnetic tamper and defeat. Made in America Smaller / Narrow switch package Higher Security MAGNASPHERE switch technology Superior RF performance even on steel surfaces Simply put, the MSS-RFS series sensors are . . . Ultra-low current draw extends battery life (up to 14+ years) The Most Secure Wireless Sensors Available Anywhere In The World!! Side mounting of magnet Compare these features and benefits and you won’t use any other wireless contact again! COMPATIBLE WITH THESE OEM* FORMATS: Terminals to allow connection of an external input Built-in enclosure tamper Low battery indication MSS-RFS-100 = UTC - INTERLOGIX / ITI / ELK Resistant to internal moisture build-up MSS-RFS-200 = HONEYWELL Easy to install MSS-RFS-300 = 2 GIG Competitively priced *UTC, Interlogix and ITI are registered trademarks of United Technologies Corporation, Elk is a registered trademark of Elk Products, Inc., Honeywell is a registered trademark of Honeywell International, Inc., 2 GIG is a registered trademark of Nortek, Inc. © MAGNASPHERE CORP. www.MAGNASPHERE.com MSS-RFS SPECIFICATIONS Battery: 3VDC, 1.55Ah, CR123A Lithium Battery Operating Temperature: 14˚F (-10˚C) to 140˚F (60˚C) Typical Battery Life: Up to 14+ Years Enclosure: ABS POLYLAC® PA-717C (UL94 HB flame-rating) External Input Sampling Current: 20 µA Weight: 1.6 oz. (51g) Switch Dimensions: 3.2 in (81.3 mm) L x 1.04 in (26.4 mm) W x .96 in (24.4 mm) H Switch Type: MAGNASPHERE – Open Loop Operating Gap: 0.63 in (1.60 cm) Magnet Type: Neodymium Iron Boron (Rare Earth) Magnet Dimensions: 1.3 in (33 mm) L x 0.5 in (1.27 mm) H x 0.43 in (10.9 mm) W Supervisory Interval: 64 minutes Color: White or Brown FCC Standard: Wire Run to External Input: 100 feet (30.5 m) FCC Part 15 SENSOR MAGNET PATENTS #9245431 3.2” #6603378 & Other Patents Pending 1.3” .43” 1.04” .50” .96” MAGNASPHERE® Corp. provides superior performing magnetic contact sensor technology for the residential, commercial, and federal government security markets. The MSS-RFS’ leading-edge technology aims to set new industry standards for wireless security sensors while providing an affordable and more effective alternative to reed-based security contacts. To learn more about the MAGNASPHERE® MSS-RFS Wireless Security Sensor visit www.MAGNASPHERE.com or call 262-347-0711. MSS-RFS 10 Reasons Why the MAGNASPHERE MSS-RFS is Better than Any Other Wireless Sensor ® Secure yet easy to open enclosure Attractive sensor providing both low profile and narrow footprint r q Better antenna design = Better performance t Better tamper switch s u Easy to install and wire z v y New Vapor Corrosion Inhibitor Technology ● Latest technology design: ● w ● Rare earth magnet design: Better, longer lasting performance on steel surfaces! Patent pending inverted board design: ● x MAGNASPHERE® Higher Security BMS switch ● Reduced standby current draw/Longest Life Best protocol management – Reduces wasted current draw during transmissions – extends battery life! ● Protects against condensation that can collect in the tray Improves performance when mounted on a metal door frame Maximum FCC allowable transmissions Made in the United States Warranty: MAGNASPHERE Corporation will provide replacements for products found to be defective in the first three years. FCC Notice: This device complies with Part 15 of the FCC rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) This device must accept any interference that may be received, including interference that may cause undesirable operation. Changes or modifications not expressly approved by MAGNASPHERE Corp. could void the user’s authority to operate this equipment.
MSS-RFS-100-B 价格&库存
很抱歉,暂时无法提供与“MSS-RFS-100-B”相匹配的价格&库存,您可以联系我们找货
