MAGNASPHERE
HS L1.5
MAGNASPHERE Introduces
the HS L1.5 Series High Security
Sensor – The Next Generation
MAGNASPHERE Technology –
Listed to UL 634 Level 1 High
Security. The L1.5 Sets the New
Standard for Safes, Vaults and
Other High Security Applications.
NEW LOWER COST
single alarm contact models
MAGNASPHERE HS L1.5 TECHNOLOGY
Tested to 9th edition UL 634 Level 1 high security
(both in-swing and out-swing doors)
Solid color-coded lead wires
Made with MAGNASPHERE® switch technology
Integrated removal/pry
tamper (no back plates)
Single and Dual alarm contacts
Low profile
NO adjustment required for installation
Two hole mounting
NO brackets needed for most out-swing door
installations
Low cost
Made in America
MAGNASPHERE® Corp. provides superior performing magnetic contact sensor technology for the residential, commercial,
and federal government security markets. This leading-edge technology aims to set new industry standards for high
security sensors while providing an affordable and more effective alternative to reed-based security contacts.
To learn more about the MAGNASPHERE® HS L1.5 High Security Sensor visit www.MAGNASPHERE.com or call 262-347-0711.
MAGNASPHERE
SENSOR
HS L1.5
18" [457.2 mm] x 0.3" [7.6mm] Standard
Stainless Steel Cable
4.25" [107.9mm] Typ.
0.5" [12.7mm]
0.25" [6.3mm]
Max Actuation Gap
Clearance for Pry-tamper
Magnet and #8
Pan-Head Screw
3.03"
[76.9mm]
1.0" [25.4mm] Sq.
MAGNET
Clearance for
#8 Flat-Head Screw
0.82"
[20.8mm]
1.0" [25.4mm] Sq.
3.45" [87.6mm]
0.4" [10.1mm]
NEW SINGLE ALARM CONTACT MODELS
WIRING SCHEMATICS
CONSTRUCTION AND TECHNICAL SPECIFICATIONS
Aluminum Case: Silver-Gray
Wire Lead Type: Solid Color-Coded, 22 AWG
Hermetically Sealed Switch Contacts
Fully Epoxy Potted Assembly
Single Alarm Contacts: One Closed Loop or One Open Loop
Integrated Removal Tamper Circuit: Closed Loop
Max Current: 0.25 A Resistive
Max Voltage: 30 VDC
Max Power: 0.250 W
Operating Temperature: -40° C to +80°C
Intended for Connection to UL Listed Compatible
Control Panels
PATENTED DESIGN
#5977873
#6087936
#6506987
#6603378
#6803845
#7023308
#7291794
#RE39731
#7944334
#8228191
#8314698
#8648720
& Other Patents Pending
© MAGNASPHERE CORP.
L1_5-XXX-SPEC DRAFT
www.MAGNASPHERE.com
MAGNASPHERE
HS L1.5
DUAL ALARM CONTACT MODELS
WIRING SCHEMATICS
Dual Alarm Contacts: Two Closed Loop, One Open Loop + One
Closed Loop, or Two Open Loop
Max Voltage: 30 VDC
Max Power: 0.250 W
Control Panels
PATENTED DESIGN
L1.5-221
SC
ALARM 1
CIRCUIT
WHT
Open Loop
#5977873
#6087936
#6506987
#6603378
#6803845
#7023308
#7291794
#RE39731
#7944334
#8228191
#8314698
#8648720
WHT
SC
ALARM 2
CIRCUIT
RED
Open Loop
RED
PT
TAMPER
CIRCUIT
BLU
Closed Loop
GRN
© MAGNASPHERE CORP.
L1_5-XXX-SPEC DRAFT
www.MAGNASPHERE.com
很抱歉,暂时无法提供与“HS-L1.5-121”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1738.621731+224.68574
