HS-L1.5-111
HS-L1.5-111
    MAGNASPHERECORP
    Module
HS-L1.5-111 数据手册
MAGNASPHERE ® ® HS L1.5 MAGNASPHERE Introduces the HS L1.5 Series High Security Sensor – The Next Generation MAGNASPHERE Technology – Listed to UL 634 Level 1 High Security. The L1.5 Sets the New Standard for Safes, Vaults and Other High Security Applications. NEW LOWER COST single alarm contact models MAGNASPHERE HS L1.5 TECHNOLOGY Tested to 9th edition UL 634 Level 1 high security (both in-swing and out-swing doors) Solid color-coded lead wires Made with MAGNASPHERE® switch technology Integrated removal/pry tamper (no back plates) Single and Dual alarm contacts Low profile NO adjustment required for installation Two hole mounting NO brackets needed for most out-swing door installations Low cost Made in America MAGNASPHERE® Corp. provides superior performing magnetic contact sensor technology for the residential, commercial, and federal government security markets. This leading-edge technology aims to set new industry standards for high security sensors while providing an affordable and more effective alternative to reed-based security contacts. To learn more about the MAGNASPHERE® HS L1.5 High Security Sensor visit www.MAGNASPHERE.com or call 262-347-0711. MAGNASPHERE SENSOR ® HS L1.5 ® 18" [457.2 mm] x 0.3" [7.6mm] Standard Stainless Steel Cable 4.25" [107.9mm] Typ. 0.5" [12.7mm] 0.25" [6.3mm] Max Actuation Gap Clearance for Pry-tamper Magnet and #8 Pan-Head Screw 3.03" [76.9mm] 1.0" [25.4mm] Sq. MAGNET Clearance for #8 Flat-Head Screw 0.82" [20.8mm] 1.0" [25.4mm] Sq. 3.45" [87.6mm] 0.4" [10.1mm] NEW SINGLE ALARM CONTACT MODELS WIRING SCHEMATICS CONSTRUCTION AND TECHNICAL SPECIFICATIONS Aluminum Case: Silver-Gray Wire Lead Type: Solid Color-Coded, 22 AWG Hermetically Sealed Switch Contacts Fully Epoxy Potted Assembly Single Alarm Contacts: One Closed Loop or One Open Loop Integrated Removal Tamper Circuit: Closed Loop Max Current: 0.25 A Resistive Max Voltage: 30 VDC Max Power: 0.250 W Operating Temperature: -40° C to +80°C Intended for Connection to UL Listed Compatible Control Panels PATENTED DESIGN #5977873 #6087936 #6506987 #6603378 #6803845 #7023308 #7291794 #RE39731 #7944334 #8228191 #8314698 #8648720 & Other Patents Pending © MAGNASPHERE CORP. | L1_5-XXX-SPEC DRAFT www.MAGNASPHERE.com MAGNASPHERE ® HS L1.5 ® DUAL ALARM CONTACT MODELS WIRING SCHEMATICS CONSTRUCTION AND TECHNICAL SPECIFICATIONS Aluminum Case: Silver-Gray Wire Lead Type: Solid Color-Coded, 22 AWG Hermetically Sealed Switch Contacts Fully Epoxy Potted Assembly Dual Alarm Contacts: Two Closed Loop, One Open Loop + One Closed Loop, or Two Open Loop Integrated Removal Tamper Circuit: Closed Loop Max Current: 0.25 A Resistive Max Voltage: 30 VDC Max Power: 0.250 W Operating Temperature: -40° C to +80°C Intended for Connection to UL Listed Compatible Control Panels PATENTED DESIGN L1.5-221 SC ALARM 1 CIRCUIT WHT Open Loop #5977873 #6087936 #6506987 #6603378 #6803845 #7023308 #7291794 #RE39731 #7944334 #8228191 #8314698 #8648720 & Other Patents Pending WHT SC ALARM 2 CIRCUIT RED Open Loop RED PT TAMPER CIRCUIT BLU Closed Loop GRN © MAGNASPHERE CORP. | L1_5-XXX-SPEC DRAFT www.MAGNASPHERE.com
HS-L1.5-111 价格&库存
很抱歉,暂时无法提供与“HS-L1.5-111”相匹配的价格&库存,您可以联系我们找货
HS-L1.5-111
  • 1+1738.621731+224.68574
  • 10+1444.9962110+186.73990
  • 25+1352.3367525+174.76532
库存:29
