MAGNASPHERE expands its L2
series HSS product line to include
the revolutionary L2C series
of next generation sensors
that meet and exceed UL634
Level 2 High Security Standard
for installations where concealed
sensors are desired for both
security and aesthetics.
ULI HIGH SECURITY LEVEL 2
CUL HIGH SECURITY
THE INSIDER THREAT
IS REAL. Experts agree
that the most devastating
threats to government
and corporate security
have come from employees
who were deemed trusted
insiders. Armed with simple
magnets unscrupulous
insiders can disable even
triple-balanced BMS
magnetic contacts while
the system is unarmed,
and enter undetected at
a later time, leaving no
evidence of tamper.
© MAGNASPHERE CORP.
MAGNASPHERE L2C HSS Technology
Only concealed contact
to meet UL 634 Level 2
Resists permanent contact
welding (power surges, stun
guns, lightning)
Incorporates patented
removal (pry) tamper
circuit
Single and dual alarm
contacts available
Installs in one inch
diameter hole or standard
ANSI door cut out
ANSI model a retrofit /
upgrade to old 2757 / 67
BMS contacts
Compatible with all
control panels
Highest level of security
for every installation
Competitively priced
American made, built
with MAGNASPHERE
switch technology
www.MAGNASPHERE.com
CONSTRUCTION AND TECHNICAL SPECIFICATIONS L2C-XXX-A (ANSI Cut Out)
Housing: Brass
Fully Epoxy Potted Assembly
Max Current: 0.25 A Resistive
Operating Temperature: -40° C to +80°C
Max Power: 0.250 W
Suitable for Indoor Use
Max Voltage: 30 VDC
Max Actuation Gap: 0.125” *
Intended for Connection to UL
Listed Compatible Control Panels
Single or Dual Closed Loop Contacts
Removal Tamper Circuit: Closed Loop
Hermetically Sealed Switch Contacts
PATENTED DESIGN
Wire Lead Type: Solid Color-Coded
Lead Wires, 22 AWG
#RE 39731, #5977873, #6506987, #6603378,
#6803845, #7944334, #8487726
& Other Patents Pending
TAMPER BRACKET
SWITCH MODULE
.62 "
2.5 "
MAGNET MODULE
4.125 "
4 7/8 "
2x #8
3.374
.9 "
1 1/8 "
1 1/4 "
3 1/2 "
2x #8
.08 " TYP.
1 1/8 "
B
.9 "
* 0.0625” for UL624 Level 2 installation
1 1/4 "
1/32" SPACER(s) AS NEEDED
P/N: 1317
Detail B
MAGNASPHERE® Corp. provides superior performing magnetic contact sensor technology for the residential, commercial,
and federal government security markets. The HSS’s leading-edge technology aims to set new industry standards for
high security sensors while providing an affordable and more effective alternative to reed-based security contacts.
To learn more about the MAGNASPHERE® L2 HSS High Security Sensor visit www.MAGNASPHERE.com or call 262-347-0711.
© MAGNASPHERE CORP.
03-2012 L2S-XXX-A-SCHM DRAFT
www.MAGNASPHERE.com
CONSTRUCTION AND TECHNICAL SPECIFICATIONS L2C-XXX (1” Diameter Concealed)
Housing: Switch – ABS, Magnet - Brass
Max Power: 0.250 W
Max Voltage: 30 VDC
PATENTED DESIGN
Lead Wires, 22 AWG
1 3/4
2 X #8 FLAT HEAD
(UNDERCUT SCREWS)
#22 AWG x 12" (6 WIRES MAX)
TAMPER BRACKET
SWITCH MODULE
MAGNET MODULE
.98
SIZED TO FIT 1” HOLE
1.02
1 1/4
.08
1 1/8
A
2 5/8
.94
1 1/4
1/32" SPACER(s) AS
NEEDED P/N: 1221
Detail A
© MAGNASPHERE CORP.
www.MAGNASPHERE.com
How the HSS L2C
Removal Tamper
Circuit Works
The MAGNASPHERE HSS L2C Series are the only
concealed devices available on the market that
incorporate a secure anti-tamper circuit. This
patented feature is available on both the ANSI cut
out and the 1” diameter recessed versions of the L2C.
L2C-XXX-A Models for Use in Standard ANSI Door Cut Out
(Refer to product sheet for visual graphics)
The Tamper bracket, containing the tamper switch
actuating magnet is inserted into the ANSI cutout first,
and secured with screws to the ANSI mounting tabs.
The Switch module is incorporated into the brass cover
plate and contains the Magnasphere alarm switch(es)
which are oriented toward the face of the Switch cover
plate towards the corresponding actuation magnet
mounted in the door, and the Magnasphere tamper
switch which is oriented in the opposite direction toward
the magnet in the Tamper bracket.
The cover plate is secured to the Tamper bracket via
mounting holes that are inboard on the cover and is
secured to corresponding mounting holes in the
Tamper bracket.
Any attempt to access the switch or wiring will require
removing the Switch module/cover plate. As this is
removed, the Tamper switch is moved away from magnet
in the stationary tamper bracket, which results in an
alarm condition.
This Tamper bracket – Switch module/cover plate
arrangement is also ideal when the device requires a
periodic test of the tamper circuit. The tester need only
loosen the mounting screws on the Switch module / cover
plate, pull the module out from its seated position and the
alarm switch will activate for the test.
L2C-XXX Models for 1” Diameter Recessed Installation
NOTE:
The Tamper device, containing the tamper switch
actuating magnet is a tapered “cap” that adheres to the
switch housing via double sided tape pads, and aligns the
tamper magnet opposite the tamper switch. The taper
allows the switch / tamper assembly to be inserted into
the 1” diameter mounting hole. Attempts to remove the
switch assembly, will result in the reverse taper “barbs” of
the tamper cap engaging the inside edge of the door
frame, and pulling the tamper cap tape pads loose from
the switch module. As this tamper cap / magnet releases
from the switch module, an alarm signal is generated.
The L2C switch module has locking side clips that make it
extremely difficult to remove the switch module without
damaging it. Therefore, removal of the switch to test the
tamper circuit is not recommended. If the L2C is used in
wood or aluminum door frame installations that require a
test of the tamper circuit, this can be accomplished by
using a specially magnetized L2C Tamper Test Magnet
(Magnasphere part number 1384). Simply open the door
(which removes the L2C actuating magnet) and place the
Tamper Test Magnet beneath the switch – this will cause
activation of the tamper switch for the test.
© MAGNASPHERE CORP.
www.MAGNASPHERE.com
BLK
Closed
Loop
BLK
PRY TAMPER
BLU
Closed
Loop
BLU
Model L2C-111-A
Contact State Shown
with Magnet in Place
Model L2C-101-A
L2C-A Wiring
Schematics
ALARM
ALARM
BLK
Closed
Loop
BLK
AUX
WHT
PRY TAMPER
Closed
Loop
WHT
BLU
Closed
Loop
BLU
ALARM
BLK
Closed
Loop
BLK
PRY TAMPER
YEL
YEL
Closed
Loop
Model L2C-111
Contact State Shown
Model L2C-101
L2C Wiring
Schematics
ALARM
BLK
Closed
Loop
BLK
AUX
WHT
PRY TAMPER
Closed
Loop
WHT
YEL
Closed
Loop
YEL
© MAGNASPHERE CORP.
www.MAGNASPHERE.com
很抱歉,暂时无法提供与“HSS-L2C-101-A”相匹配的价格&库存,您可以联系我们找货
