1
L2X-800 SERIES
Magnasphere has created
NEW
L2X-800 ‘High Security
2
Sensor” -The Next Generation
Sensors That Meet UL634 Level 2
High Security Standards for SCIFs.
Safes, Vaults and Hazardous
Environment Applications
ULI HIGH SECURITY LEVEL 2
CUL HIGH SECURITY
BP 10350
Magnasphere L2X-800 Technology
Simple Apparatus for Intrinsically
Safe schemes of Hazardous
Locations NFPA 70 500.7 (E)
(see page 3)
Resistant to External and
INTERNAL magnetic defeat
Dual 1/2” NPT conduit ports
provide top or side connection
options
Replacement for existing
BMS devices
No adjustment required
for installation
MAGNASPHERE switch technology
resists permanent contact welding
(lightning, power surges, stun guns)
Industry’s most secure removal
tamper sensor/circuit
Single (L2S) and dual (L2D) alarm
contacts available
American made using awardwinning MAGNASPHERE
switch technology
Compatible with control panel
models that accept contact inputs
Built-in EOL resistors available
© MAGNASPHERE CORP.
Competitively priced
www.MAGNASPHERE.com
2
L2X-800 SERIES
L2X-800 SERIES DIMENSIONS
Actuation Gap
(recommended for
maximum internal
magnetic non-defeat
characteristics)
Magnet Module
CONSTRUCTION AND TECHINICAL SPECIFICATIONS
PATENTED DESIGN
Aluminum Case: Silver-Gray Anodized
# 5332992
# 5530428
Wire Lead Type: Solid Color-Coded Lead Wires, 22AWG
# 5673021
# 5880659
# 5977873
# 6087936
# 6506987
# 6603378
Hermetically Sealed Switch Contacts
Fully Epoxy Potted Assembly
# 6803845
# 7023308
Single Alarm Contact Version (L2S): Closed or Open Loop
# 7291794
# RE39731
Dual Alarm Contact Version (L2D): Closed Loop
# 7944334
# 8228191
Removal Tamper Circuit: Closed Loop
& Other Patents Pending
Max Current : 0.25 amps Resistive
Max Voltage: 30 VDC
Max Power: 0.250 W
Operating Temperature: -40° C to +80° C
Suitable for Indoor and Outdoor Use
Intended for connection to UL Listed Compatible
Control Panels
MAGNASPHERE® Corp. provides superior performing magnetic contact sensor technology for the residential, commercial,
and federal government security markets. The HSS’s leading-edge technology aims to set new industry standards for
high security sensors while providing an affordable and more effective alternative to reed-based security contacts.
To learn more about the MAGNASPHERE® L2 HSS High Security Sensor visit www.M AGNASPHERE.com or call 262-347-0711.
© MAGNASPHERE CORP.
L2X-XXX SPEC REV D
www.MAGNASPHERE.com
3
L2X-800 SERIES
The MAGNASPHERE HSS High Security Sensor conforms to the requirements of
UL Standard 913
Standard for Intrinsically Safe Apparatus and Associated Apparatus
for Use in Class I, II, III, Division 1, Hazardous (Classified) Locations
for use in Hazardous locations as an INTRINSICALLY SAFE SIMPLE APPARATUS*.
INTRINSICALLY SAFE
The Construction of the HSS devices
incorporates robust, hermetically sealed
MAGNASPHERE switch technology,
complete epoxy encapsulation of all
electrical, components and magnetic
actuation.
The M AGNASPHERE HSS models
L2 S and L2 D used as intrinsically
safe simple apparatus in hazardous
locations M UST be used in conjunction
with a Div. 1 Class 1 Group B Intrinsically
Safe Barrier listed by a Nationally
Recognized Testing Laboratory (NRTL). !
The appropriate use of the apparatus in the
hazardous locations is addressed in the
instructions for the barrier (or device)
providing power to this apparatus and
to the hazardous location.
* Reference UL Standard 913 (includes
UL 60079-11, the US adoption of the IEC
60079-11 standard for intrinsic safety,
taking a national deviation [identified in
the standards DV or DR] to correspond
to the definition in the national electrical
code). Sections: 3.1.1, 5.4 and associated
DV and DR deviations.
! - or suitably - rated and listed
to the according hazardous location.
© MAGNASPHERE CORP.
www.MAGNASPHERE.com
4
L2X-800 SERIES
How the HSS Magnet / Removal Tamper Circuit Works
The MAGNASPHERE HSS Incorporates the Most
Secure Anti-Tamper Features of Any Device Available.
In addition to the sensors inside that will detect the
presence of a stronger defeat magnet placed on any
surface of the HSS, the removal tamper circuit will
alarm BEFORE the HSS can be removed.
Once the unit has been mounted, the removal
tamper magnet (included) is inserted into this
mounting hole. It will be attracted to the mounting
screw and will activate the removal tamper switch.
The mounting hole cover cap (included) is then
inserted and locked into position.
You will notice that the mounting hole on the upper
right face of the HSS sensor is larger than the other
mounting holes and slightly off set towards the center
of the sensor. A tamper proof MAGNASPHERE
switch is positioned inside the unit facing the bore
of this mounting hole.
In order to access that mounting screw to remove
the sensor, the locking cap must be pried out, and
a steel rod or magnet inserted into the hole to
extract the tamper magnet. Removal of the tamper
magnet will cause the removal tamper switch
to alarm.
Typical Part Numbers / Wiring Schematics
Model L2D-800
Model L2S-800
SC1
Closed Loop
WHT
SC
Closed Loop
WHT
ALARM
CIRCUIT
Common
SC
Open Loop
BLK
SC2
RED
Closed Loop
Common
BLK
TAMPER
CIRCUIT
ORN
Supervised
Common
Common
GRN
MT
PUR
Magnet
Tamper
PT
GRN
YEL
Magnet/ Pry
Tamper
MT
BLU
PT
YEL
BLU
Supervised
Common
Magnetic
Tamper
Magnet/ Pry
Tamper
All Circuits Shown with Magnet Actuator in Secure Position. For Built-in EOL Resistor Configurations and
Values (not shown), Visit WWW.MAGNASPHERE.COM.
© MAGNASPHERE CORP.
www.MAGNASPHERE.com
很抱歉,暂时无法提供与“HSS-L2D-810”相匹配的价格&库存,您可以联系我们找货
