HSS-L2D-800
HSS-L2D-800
    MAGNASPHERECORP
    Module
HSS-L2D-800 数据手册
1 L2X-800 SERIES Magnasphere has created NEW L2X-800 ‘High Security 2 Sensor” -The Next Generation Sensors That Meet UL634 Level 2 High Security Standards for SCIFs. Safes, Vaults and Hazardous Environment Applications ULI HIGH SECURITY LEVEL 2 CUL HIGH SECURITY BP 10350 Magnasphere L2X-800 Technology Simple Apparatus for Intrinsically Safe schemes of Hazardous Locations NFPA 70 500.7 (E) (see page 3) Resistant to External and INTERNAL magnetic defeat Dual 1/2” NPT conduit ports provide top or side connection options Replacement for existing BMS devices No adjustment required for installation MAGNASPHERE switch technology resists permanent contact welding (lightning, power surges, stun guns) Industry’s most secure removal tamper sensor/circuit Single (L2S) and dual (L2D) alarm contacts available American made using awardwinning MAGNASPHERE switch technology Compatible with control panel models that accept contact inputs Built-in EOL resistors available Industry’s most secure removal tamper sensor/circuit © MAGNASPHERE CORP. Competitively priced www.MAGNASPHERE.com 2 L2X-800 SERIES L2X-800 SERIES DIMENSIONS Actuation Gap (recommended for maximum internal magnetic non-defeat characteristics) Magnet Module CONSTRUCTION AND TECHINICAL SPECIFICATIONS PATENTED DESIGN Aluminum Case: Silver-Gray Anodized # 5332992 # 5530428 Wire Lead Type: Solid Color-Coded Lead Wires, 22AWG # 5673021 # 5880659 # 5977873 # 6087936 # 6506987 # 6603378 Hermetically Sealed Switch Contacts Fully Epoxy Potted Assembly # 6803845 # 7023308 Single Alarm Contact Version (L2S): Closed or Open Loop # 7291794 # RE39731 Dual Alarm Contact Version (L2D): Closed Loop # 7944334 # 8228191 Removal Tamper Circuit: Closed Loop & Other Patents Pending Max Current : 0.25 amps Resistive Max Voltage: 30 VDC Max Power: 0.250 W Operating Temperature: -40° C to +80° C Suitable for Indoor and Outdoor Use Intended for connection to UL Listed Compatible Control Panels MAGNASPHERE® Corp. provides superior performing magnetic contact sensor technology for the residential, commercial, and federal government security markets. The HSS’s leading-edge technology aims to set new industry standards for high security sensors while providing an affordable and more effective alternative to reed-based security contacts. To learn more about the MAGNASPHERE® L2 HSS High Security Sensor visit www.M AGNASPHERE.com or call 262-347-0711. © MAGNASPHERE CORP. | L2X-XXX SPEC REV D www.MAGNASPHERE.com 3 L2X-800 SERIES The MAGNASPHERE HSS High Security Sensor conforms to the requirements of UL Standard 913 Standard for Intrinsically Safe Apparatus and Associated Apparatus for Use in Class I, II, III, Division 1, Hazardous (Classified) Locations for use in Hazardous locations as an INTRINSICALLY SAFE SIMPLE APPARATUS*. INTRINSICALLY SAFE The Construction of the HSS devices incorporates robust, hermetically sealed MAGNASPHERE switch technology, complete epoxy encapsulation of all electrical, components and magnetic actuation. The M AGNASPHERE HSS models L2 S and L2 D used as intrinsically safe simple apparatus in hazardous locations M UST be used in conjunction with a Div. 1 Class 1 Group B Intrinsically Safe Barrier listed by a Nationally Recognized Testing Laboratory (NRTL). ! The appropriate use of the apparatus in the hazardous locations is addressed in the instructions for the barrier (or device) providing power to this apparatus and to the hazardous location. * Reference UL Standard 913 (includes UL 60079-11, the US adoption of the IEC 60079-11 standard for intrinsic safety, taking a national deviation [identified in the standards DV or DR] to correspond to the definition in the national electrical code). Sections: 3.1.1, 5.4 and associated DV and DR deviations. ! - or suitably - rated and listed to the according hazardous location. © MAGNASPHERE CORP. www.MAGNASPHERE.com 4 L2X-800 SERIES How the HSS Magnet / Removal Tamper Circuit Works The MAGNASPHERE HSS Incorporates the Most Secure Anti-Tamper Features of Any Device Available. In addition to the sensors inside that will detect the presence of a stronger defeat magnet placed on any surface of the HSS, the removal tamper circuit will alarm BEFORE the HSS can be removed. Once the unit has been mounted, the removal tamper magnet (included) is inserted into this mounting hole. It will be attracted to the mounting screw and will activate the removal tamper switch. The mounting hole cover cap (included) is then inserted and locked into position. You will notice that the mounting hole on the upper right face of the HSS sensor is larger than the other mounting holes and slightly off set towards the center of the sensor. A tamper proof MAGNASPHERE switch is positioned inside the unit facing the bore of this mounting hole. In order to access that mounting screw to remove the sensor, the locking cap must be pried out, and a steel rod or magnet inserted into the hole to extract the tamper magnet. Removal of the tamper magnet will cause the removal tamper switch to alarm. Typical Part Numbers / Wiring Schematics Model L2D-800 Model L2S-800 SC1 Closed Loop WHT SC Closed Loop WHT ALARM CIRCUIT Common SC Open Loop BLK SC2 RED Closed Loop Common BLK TAMPER CIRCUIT ORN Supervised Common Common GRN MT PUR Magnet Tamper PT GRN YEL Magnet/ Pry Tamper MT BLU PT YEL BLU Supervised Common Magnetic Tamper Magnet/ Pry Tamper All Circuits Shown with Magnet Actuator in Secure Position. For Built-in EOL Resistor Configurations and Values (not shown), Visit WWW.MAGNASPHERE.COM. © MAGNASPHERE CORP. www.MAGNASPHERE.com
HSS-L2D-800 价格&库存
很抱歉,暂时无法提供与“HSS-L2D-800”相匹配的价格&库存,您可以联系我们找货
HSS-L2D-800
  • 1+4433.698161+572.35329
