SIT8918BA-23-33E-100.000000D
    SITIME(赛特时脉)
    SMD3225_4P
    有源晶振 100MHz SMD3225_4P
SIT8918BA-23-33E-100.000000D 数据手册
SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice Features Applications  Frequencies between 1 MHz and 110 MHz accurate to 6 decimal places  Industrial, medical, non AEC-Q100 automotive, avionics and other high temperature applications  Operating temperature from -40°C to 125°C. For -55°C option, refer to SiT8920 and SiT8921  Industrial sensors, PLC, motor servo, outdoor networking equipment, medical video cam, asset tracking systems, etc.  Supply voltage of 1.8V or 2.5V to 3.3V  Excellent total frequency stability as low as ±20 ppm  Low power consumption of 3.5 mA typical at 1.8V  LVCMOS/LVTTL compatible output  Industry-standard packages: 2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm  Instant samples with Time Machine II and field programmable oscillators  RoHS and REACH compliant, Pb-free, Halogen-free and Antimony-free  For AEC-Q100 oscillators, refer to SiT8924 and SiT8925 Electrical Specifications Table 1. Electrical Characteristics All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated. Typical values are at 25°C and nominal supply voltage. Parameters Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 1 – 110 MHz F_stab -20 – +20 ppm -25 – +25 ppm -30 – +30 ppm -50 – +50 ppm Refer to Table 13 for the exact list of supported frequencies list of supported frequencies Frequency Stability and Aging Frequency Stability Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, rated power supply voltage and load (15 pF ± 10%). Operating Temperature Range Operating Temperature Range (ambient) T_use -40 – +105 °C Extended Industrial -40 – +125 °C Automotive Supply Voltage and Current Consumption Supply Voltage Current Consumption OE Disable Current Standby Current Vdd Idd I_od I_std 1.62 1.8 1.98 V 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V 2.25 – 3.63 V – 3.8 4.7 mA No load condition, f = 20 MHz, Vdd = 2.8V, 3.0V or 3.3V – 3.6 4.5 mA No load condition, f = 20 MHz, Vdd = 2.5V – 3.5 4.5 mA No load condition, f = 20 MHz, Vdd = 1.8V – – 4.5 mA Vdd = 2.5V to 3.3V, OE = Low, Output in high Z state. – – 4.3 mA Vdd = 1.8V, OE = Low, Output in high Z state. – 2.6 8.5 A Vdd = 2.8V to 3.3V, ST = Low, Output is weakly pulled down – 1.4 5.5 A Vdd = 2.5V, ST = Low, Output is weakly pulled down 0.6 4.0 A Vdd = 1.8V, ST = Low, Output is weakly pulled down – LVCMOS Output Characteristics Duty Cycle Rise/Fall Time DC 45 – 55 % Tr, Tf – 1.0 2.0 ns All Vdds Vdd = 2.5V, 2.8V, 3.0V or 3.3V, 20% - 80% – 1.3 2.5 ns Vdd =1.8V, 20% - 80% Vdd = 2.25V - 3.63V, 20% - 80% – 1.0 3 ns Output High Voltage VOH 90% – – Vdd IOH = -4 mA (Vdd = 3.0V or 3.3V) IOH = -3 mA (Vdd = 2.8V or 2.5V) IOH = -2 mA (Vdd = 1.8V) Output Low Voltage VOL – – 10% Vdd IOL = 4 mA (Vdd = 3.0V or 3.3V) IOL = 3 mA (Vdd = 2.8V or 2.5V) IOL = 2 mA (Vdd = 1.8V) SiTime Corporation Rev. 1.01 990 Almanor Avenue, Sunnyvale, CA 94085 (408) 328-4400 www.sitime.com Revised June 18, 2015 SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice Table 1. Electrical Characteristics (continued) Parameters Symbol Min. Typ. Max. Unit Condition Input Characteristics Input High Voltage VIH 70% – – Vdd Input Low Voltage VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedence Z_in 50 87 150 k Pin 1, OE logic high or logic low, or ST logic high – – M Pin 1, ST logic low 2 Pin 1, OE or ST Startup and Resume Timing Startup Time T_start – – 5 ms Measured from the time Vdd reaches its rated minimum value T_oe – – 130 ns T_resume – – 5 ms f = 110 MHz. For other frequencies, T_oe = 100 ns + 3 * clock periods Measured from the time ST pin crosses 50% threshold Enable/Disable Time Resume Time Jitter RMS Period Jitter T_jitt Peak-to-peak Period Jitter T_pk RMS Phase Jitter (random) T_phj – 1.6 2.5 ps f = 75MHz, Vdd = 2.5V, 2.8V, 3.0V or 3.3V – 1.9 3 ps f = 75MHz, Vdd = 1.8V – 12 20 ps f = 75MHz, Vdd = 2.5V, 2.8V, 3.0V or 3.3V – 14 25 ps f = 75MHz,Vdd = 1.8V – 0.5 0.8 ps f = 75MHz, Integration bandwidth = 900 kHz to 7.5 MHz – 1.3 2 ps f = 75MHz, Integration bandwidth = 12 kHz to 20 MHz Table 2. Pin Description Pin 1 Symbol OE/ ST/NC Top View Functionality Output Enable H[1]: specified frequency output L: output is high impedance. Only output driver is disabled. Standby H[1]: specified frequency output L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. No Connect Any voltage between 0 and Vdd or Open[1]: Specified frequency output. Pin 1 has no function. 2 GND Power Electrical ground 3 OUT Output Oscillator output 4 VDD Power Power supply voltage[2] OE/ST/NC 1 4 VDD GND 2 3 OUT Figure 1. Pin Assignments Notes: 1. In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the NC option. 2. A capacitor of value 0.1 µF or higher between Vdd and GND is required. Rev. 1.01 Page 2 of 13 www.sitime.com SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice N Table 3. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings of the part may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Min. Max. Unit Storage Temperature Parameter -65 150 °C Vdd -0.5 4 V Electrostatic Discharge – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C Junction Temperature[3] – 150 °C Note: 3. Exceeding this temperature for extended period of time may damage the device. Table 4. Thermal Consideration[4] JA, 4 Layer Board JA, 2 Layer Board JC, Bottom 7050 142 273 30 5032 97 199 24 3225 109 212 27 2520 117 222 26 2016 152 252 36 (°C/W) Package (°C/W) (°C/W) Note: 4. Refer to JESD51-7 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. Table 5. Maximum Operating Junction Temperature[5] Max Operating Temperature (ambient) Maximum Operating Junction Temperature 105°C 115°C 125°C 135°C Note: 5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 6. Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev. 1.01 Page 3 of 13 www.sitime.com SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice Test Circuit and Waveform[6] Vdd Vout 0.1µF tr 3 4 Power Supply Test Point 1 tf 80% Vdd 15pF (including probe and fixture capacitance) 2 50% 20% Vdd High Pulse (TH) Low Pulse (TL) Period Vdd 1k OE/ST Function Figure 2. Test Circuit Figure 3. Waveform Note: 6. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagrams Vdd 90% Vdd Vdd T_start Pin 4 Voltage 50% Vdd T_resume ST Voltage [7] No Glitch during start up CLK Output CLK Output HZ HZ T_start: Time to start from power-off T_resume: Time to resume from ST Figure 4. Startup Timing (OE/ST Mode) Figure 5. Standby Resume Timing (ST Mode Only) u Vdd Vdd OE Voltage 50% Vdd OE Voltage 50% Vdd T_oe T_oe CLK Output CLK Output HZ HZ T_oe: Time to put the output in High Z mode T_oe: Time to re-enable the clock output Figure 6. OE Enable Timing (OE Mode Only) Figure 7. OE Disable Timing (OE Mode Only) Note: 7. SiT8918 has “no runt” pulses and “no glitch” output during startup or resume. Rev. 1.01 Page 4 of 13 www.sitime.com SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice Performance Plots[8] 1.8 V 2.5 V 2.8 V 3V 3.3 V 6.0 DUT1 DUT2 DUT3 DUT4 DUT5 DUT6 DUT7 DUT8 DUT9 DUT10 DUT11 DUT12 DUT13 DUT14 DUT15 DUT16 DUT17 DUT18 DUT19 DUT20 25 5.5 20 15 Frequency (ppm) Idd (mA) 5.0 4.5 4.0 3.5 10 5 0 -5 -10 -15 -20 3.0 0 20 40 60 80 -25 100 ‐55 ‐35 ‐15 Frequency (MHz) Figure 8. Idd vs Frequency 1.8 V 2.5 V 2.8 V 3.0 V 25 45 65 85 105 125 Figure 9. Frequency vs Temperature 3.3 V 1.8 V 2.5 V 2.8 V 3.0 V 3.3 V 55 4.0 54 3.5 53 3.0 52 Duty cycle (%) RMS period jitter (ps) 5 Temperature (°C) 2.5 2.0 1.5 1.0 51 50 49 48 47 0.5 46 0.0 0 20 40 60 80 45 100 0 Frequency (MHz) 2.8 V 3.0 V 3.3 V 1.8 V 2.5 2.5 2.0 2.0 1.5 1.0 80 100 2.5 V 2.8 V 20 40 3.0 V 3.3 V 1.5 1.0 0.5 0.5 0.0 0.0 -40 -20 0 20 40 60 80 100 -40 120 Temperature (°C) -20 0 60 80 100 120 Temperature (°C) Figure 12. 20%-80% Rise Time vs Temperature Rev. 1.01 60 Figure 11. Duty Cycle vs Frequency Fall time (ns) Rise time (ns) 2.5 V 40 Frequency (MHz) Figure 10. RMS Period Jitter vs Frequency 1.8 V 20 Figure 13. 20%-80% Fall Time vs Temperature Page 5 of 13 www.sitime.com SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice Performance Plots[8] 1.8 V 2.5 V 2.8 V 3.0 V 3.3 V 1.8 V 2.5 V 2.8 V 3.0 V 3.3 V 1.0 2.0 1.9 0.9 1.8 0.8 1.6 IPJ (ps) IPJ (ps) 1.7 1.5 1.4 1.3 0.7 0.6 0.5 1.2 0.4 1.1 1.0 0.3 10 20 30 40 50 60 70 80 90 100 110 10 Frequency (MHz) 20 30 40 50 60 70 80 90 100 110 Frequency (MHz) Figure 14. RMS Integrated Phase Jitter Random (12k to 20 MHz) vs Frequency[9] Figure 15. RMS Integrated Phase Jitter Random (900 kHz to 20 MHz) vs Frequency[9] Notes: 8. All plots are measured with 15 pF load at room temperature, unless otherwise stated. 9. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is 12 kHz to 5 MHz for carrier frequencies up to 40 MHz. Rev. 1.01 Page 6 of 13 www.sitime.com SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice Programmable Drive Strength The SiT8918 includes a programmable drive strength feature to provide a simple, flexible tool to optimize the clock rise/fall time for specific applications. Benefits from the programmable drive strength feature are: • Improves system radiated electromagnetic interference (EMI) by slowing down the clock rise/fall time • Improves the downstream clock receiver’s (RX) jitter by decreasing (speeding up) the clock rise/fall time. • Ability to drive large capacitive loads while maintaining full swing with sharp edge rates. For more detailed information about rise/fall time control and drive strength selection, see the SiTime Applications Note section; http://www.sitime.com/support/application-notes. EMI Reduction by Slowing Rise/Fall Time Figure 16 shows the harmonic power reduction as the rise/fall times are increased (slowed down). The rise/fall times are expressed as a ratio of the clock period. For the ratio of 0.05, the signal is very close to a square wave. For the ratio of 0.45, the rise/fall times are very close to near-triangular waveform. These results, for example, show that the 11th clock harmonic can be reduced by 35 dB if the rise/fall edge is increased from 5% of the period to 45% of the period.   trise=0.05 0 Harmonic amplitude (dB) SiT8918 Drive Strength Selection Tables 7 through 11 define the rise/fall time for a given capacitive load and supply voltage. 1. Select the table that matches the SiT8918 nominal supply voltage (1.8V, 2.5V, 2.8V, 3.0V, 3.3V). 2. Select the capacitive load column that matches the application requirement (5 pF to 60 pF) 3. Under the capacitive load column, select the desired rise/fall times. 4. The left-most column represents the part number code for the corresponding drive strength. 5. Add the drive strength code to the part number for ordering purposes. Calculating Maximum Frequency Based on the rise and fall time data given in Tables 7 through 11, the maximum frequency the oscillator can operate with guaranteed full swing of the output voltage over temperature as follows: trise=0.1 trise=0.15 trise=0.2 10 M a x F re q u e n c y = trise=0.25 trise=0.3 trise=0.35 trise=0.4 trise=0.45 -10 -20 1 5 x T rf_ 2 0 /8 0 where Trf_20/80 is the typical value for 20%-80% rise/fall time. -30 -40 Example 1 -50 -60 Calculate fMAX for the following condition: -70 -80 The SiT8918 can support up to 60 pF or higher in maximum capacitive loads with drive strength settings. Refer to the Rise/Tall Time Tables (Table 7 to 11) to determine the proper drive strength for the desired combination of output load vs. rise/fall time 1 3 5 7 9 11 Harm onic num ber Figure 16. Harmonic EMI reduction as a Function of Slower Rise/Fall Time Jitter Reduction with Faster Rise/Fall Time Power supply noise can be a source of jitter for the downstream chipset. One way to reduce this jitter is to speed up the rise/fall time of the input clock. Some chipsets may also require faster rise/fall time in order to reduce their sensitivity to this type of jitter. Refer to the Rise/Fall Time Tables (Table 7 to Table 11) to determine the proper drive strength. • Vdd = 1.8V (Table 7) • Capacitive Load: 30 pF • Desired Tr/f time = 3 ns (rise/fall time part number code = E) Part number for the above example: SiT8918BE12-18E-66.666660 Drive strength code is inserted here. Default setting is “-” High Output Load Capability The rise/fall time of the input clock varies as a function of the actual capacitive load the clock drives. At any given drive strength, the rise/fall time becomes slower as the output load increases. As an example, for a 3.3V SiT8918 device with default drive strength setting, the typical rise/fall time is 1ns for 15 pF output load. The typical rise/fall time slows down to 2.6 ns when the output load increases to 45 pF. One can choose to speed up the rise/fall time to 1.83ns by then increasing the drive strength setting on the SiT8918. Rev. 1.01 Page 7 of 13 www.sitime.com SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice Rise/Fall Time (20% to 80%) vs CLOAD Tables Table 7. Vdd = 1.8V Rise/Fall Times for Specific CLOAD Table 8. Vdd = 2.5V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF 30 pF 45 pF 60 pF Drive Strength \ CLOAD 5 pF 15 pF 30 pF 45 pF 60 pF L A R  B T E U F or "‐": default 6.16 3.19 2.11 1.65 0.93 0.78 0.70 0.65 11.61 6.35 4.31 3.23 1.91 1.66 1.48 1.30 22.00 11.00 7.65 5.79 3.32 2.94 2.64 2.40 31.27 16.01 10.77 8.18 4.66 4.09 3.68 3.35 39.91 21.52 14.47 11.08 6.48 5.74 5.09 4.56 L A R  B T E or "‐": default U F  4.13 2.11 1.45 1.09 0.62 8.25 4.27 2.81 2.20 1.28 12.82 7.64 5.16 3.88 2.27 21.45 11.20 7.65 5.86 3.51 27.79 14.49 9.88 7.57 4.45 0.54 0.43 0.34 1.00 0.96 0.88 2.01 1.81 1.64 3.10 2.79 2.54 4.01 3.65 3.32 Table 9. Vdd = 2.8V Rise/Fall Times for Specific CLOAD Table 10. Vdd = 3.0V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF 30 pF 45 pF 60 pF Drive Strength \ CLOAD 5 pF 15 pF 30 pF 45 pF 60 pF L A R  B T 3.77 1.94 1.29 0.97 0.55 7.54 3.90 2.57 2.00 1.12 12.28 7.03 4.72 3.54 2.08 19.57 10.24 7.01 5.43 3.22 25.27 13.34 9.06 6.93 4.08 E or "‐": default U F 0.44 0.34 0.29 1.00 0.88 0.81 1.83 1.64 1.48 2.82 2.52 2.29 3.67 3.30 2.99 L A R  B T or "‐": default E U F 3.60 1.84 1.22 0.89 0.51 0.38 0.30 0.27 7.21 3.71 2.46 1.92 1.00 0.92 0.83 0.76 11.97 6.72 4.54 3.39 1.97 1.72 1.55 1.39 18.74 9.86 6.76 5.20 3.07 2.71 2.40 2.16 24.30 12.68 8.62 6.64 3.90 3.51 3.13 2.85 Table 11. Vdd = 3.3V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF 30 pF 45 pF 60 pF L A R  B 3.39 1.74 1.16 0.81 6.88 3.50 2.33 1.82 11.63 6.38 4.29 3.22 17.56 8.98 6.04 4.52 23.59 12.19 8.34 6.33 T or "‐": default E U F 0.46 0.33 0.28 0.25 1.00 0.87 0.79 0.72 1.86 1.64 1.46 1.31 2.60 2.30 2.05 1.83 3.84 3.35 2.93 2.61 Rev. 1.01 Page 8 of 13 www.sitime.com SiT8918B High Temperature Oscillator The Smart Timing Choice The Smart Timing Choice Pin 1 Configuration Options (OE, ST, or NC) Pin 1 of the SiT8918 can be factory-programmed to support three modes: Output enable (OE), standby (ST) or No Connect (NC). These modes can also be programmed with the Time Machine using field programmable devices. Output Enable (OE) Mode In the OE mode, applying logic Low to the OE pin only disables the output driver and puts it in Hi-Z mode. The core of the device continues to operate normally. Power consumption is reduced due to the inactivity of the output. When the OE pin is pulled High, the output is typically enabled in
物料型号:SiT8918B
器件简介: - SiT8918B是一款高温振荡器,由SiTime公司生产。 - 它适用于工业、医疗、非汽车AEC-Q100、航空电子等高温应用。 - 工作温度范围从-40°C到125°C,对于-55°C的选项,可以参考SiT8920和SiT8921。
引脚分配: - 1. OE/ST/NC:输出使能/待机/无连接 - 2. GND:电源地 - 3. OUT:输出 - 4. VDD:电源电压
参数特性: - 频率范围:1 MHz 至 110 MHz,精确到小数点后6位。 - 供电电压:1.8V 或 2.5V 至 3.3V。 - 优秀的频率稳定性,低至 ±20 ppm。 - 低功耗,典型值为3.5 mA(在1.8V下)。 - LVCMOS/LVTTL兼容输出。 - 行业标准封装:2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm。
功能详解: - 该振荡器具有即时采样功能,可与Time Machine II和现场可编程振荡器配合使用。 - 符合RoHS和REACH标准,无铅、无卤素和锑。
应用信息: - 适用于工业传感器、PLC、电机伺服、户外网络设备、医疗视频摄像头、资产跟踪系统等。
封装信息: - 提供多种行业标准封装尺寸。
SIT8918BA-23-33E-100.000000D 价格&库存
很抱歉,暂时无法提供与“SIT8918BA-23-33E-100.000000D”相匹配的价格&库存,您可以联系我们找货
    • 5+18.08000
    • 35+17.17600
    • 100+15.95000
    • 500+15.18000
    库存:3000
