ABL005-00E
ABL005-00E
    NVECORP
    TSSOP8
    MAGNETIC SWITCH SPEC PURP 8MSOP
ABL005-00E 数据手册
ABL/AKL-Series Gear-Tooth Sensors Block Diagrams Features • Wide airgap • Analog and digital versions • Large analog peak-to-peak signal • Single- and dual-bridge versions • Operating frequency to 1 MHz • 150 °C operating temperature • Packages as small as 2.5 mm x 2.5 mm ABL00x Applications Motion, speed, and position sensing Linear and rotational encoders Closed-loop servo systems Automotive sensors ABL01x • • • • VCC Voltage Regulator 3.3V Switching Current Source GMR Bridge EEPROM Description ABL and AKL-Series Gear-Tooth Sensors are versatile, wide airgap sensors typically used with ferromagnetic gears and bias magnets. Offset Detector A A Gain Three standard spacings are available for use with gear pitches as small as 0.5 mm, to 6 mm or more (0.16 mm to 2 mm module). Current Level AKL00x GND ABL-Series analog sensors have differential sensor elements that provide sinusoidal outputs. Single- or dual-bridge configurations are available. Dual-bridge versions provide two phase-shifted outputs for A/B phase detection and absolute position interpolation. Outputs V V Gear Rotation ABL00x Single-bridge analog sensor Gear Rotation AKL-Series sensors combine a sensor bridge with integrated signal processing to provide a 50% duty cycle digital output. Integrated signal processing includes gain and offset normalization. AKL-Series sensors are configured as twowire devices, where the supply current indicates passing teeth. ABL01x Dual-bridge analog sensor mA 8 4 Gear Rotation AKL00x digital gear-tooth sensor 1 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Absolute Maximum Ratings ABL-Series Analog Gear-Tooth Sensors Parameter Min. Max. Supply voltage 30 Storage temperature −65 170 ESD (Human Body Model) 400 Applied magnetic field Unlimited Units Volts °C Volts Tesla AKL-Series Digital Gear-Tooth Sensors Parameter Min. Max. Supply voltage −60 45 Continuous output current 16 Junction temperature −40 170 Storage temperature −65 170 Junction temperature −40 170 ESD (Human Body Model) 2000 Applied magnetic field Unlimited Units Volts mA °C °C °C Volts Tesla Operating Specifications Parameter Operating temperature Supply voltage Resistance Offset voltage Non-linearity Hysteresis Saturation of GMR sensor elements Single resistor sensitivity Maximum output Resistance temperature coefficient Operating frequency ABL-Series Analog Gear-Tooth Sensors Symbol Min. Typ. Tmin; Tmax −50 VCC 0 4 5 VO −4 −18 ∆R/mT TCR fMAX 0 0.4 80 +0.11 1 Max. 150 30 7 +4 2 Units °C V kΩ mV/V % 2 +18 % mT %/mT mV/V %/°C MHz Test Condition At 25 °C Unipolar field sweep through operating range No applied field AKL-Series Digital Gear-Tooth Sensors (Tmin to Tmax; 4.5 V < VCC < 36 V unless otherwise stated) Parameter Symbol Min. Typ. Max. Units Test Condition Operating temperature Tmin; Tmax −40 150 °C Supply voltage VCC 4.5 36 V Off-state supply current IOFF 3.4 4 4.8 mA VCC = 12 V On-state supply current ION 7 8 9 Output duty cycle 40 50 60 % Airgap AKL001-12E 1 3.5 AKL002-12E 1 2.5 mm AKL003-12E 1 2 Operating frequency fMAX DC 10 kHz 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Operation Sensor orientation To align with the axis of sensitivity, sensors should be oriented with the gear teeth perpendicular to the length of the sensor as shown in Figure 1: ABL00X-10E AKL00X-12E Figure 1. Sensor orientation. Biasing To detect gear teeth, a permanent magnet is required to generate a magnetic bias field. The sensor can then detect magnetic field variations as the gear tooth passes by. Here are some tips for biasing: • Because of GT Sensors’ high sensitivity, small, inexpensive Ceramic 8 ferrite magnets can be used for most applications. Small sensors and magnets allow small circuit boards. Magnet • Alnico 8 magnets can be used in high temperature applications. • When using rare-earth magnets, care should be taken to avoid saturating the sensors. • Magnets and sensors can be placed on opposite sides of a 1.5 mm thick (0.062 inch) circuit board, which provides a convenient spacing for many applications (see Figure 2). PCB Figure 2. Biasing magnet. • The magnet can be glued to the circuit board using high-temperature epoxy adhesive. • For more precise positioning, a pocket to hold the magnet can be machined into a thicker circuit board. • If zero speed operation is not required, AC coupling the sensor removes the electrical offset induced by magnetic imperfections. Recommended sensor element spacing vs. gear pitch For ABL00x and AKL00x sensors, the best design margin is when the sensor element spacing is equal to approximately one-half the gear pitch. For example, this means the one-millimeter pitch ABL004 is ideal for two-millimeter pitch (0.65 mm module) gears. For ABL01x sensors, the relative phase of the A/B outputs is determined by the ratio of the bridge phase difference and the gear pitch: Phase Shift = ( bridge phase shift / gear pitch ) · 360° As an example, the A/B phase difference for an ABL015 detecting a 1.2 mm gear pitch is equal to (0.25 / 1.2) · 360° = 75°. Design Support Check out our free Web application for GT sensor design support: https://www.nve.com/spec/calculators.php#tabs-GT-Sensor-Output 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Sinusoidal output with rotation As shown in Figure 3 below, a biasing magnet provides a field, and the magnetic flux lines are deflected into the direction of sensitivity by passing metal gear teeth. Sensors are placed between the magnet and gear teeth. Thus the sensor produces a sinusoidal output with one cycle per tooth. Dual-bridge sensors provide a second bridge output that is out-of-phase with the first sensor. Bridge u u u u u Magnet Figure 3. ABL00x output vs. gear rotation. 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Typical outputs Figures 4 to 6 show typical outputs from each of the three GT Sensor types: 0.3 Output (V) 0.2 0.1 0 -0.1 -0.2 -0.3 0 Figure 4. ABL00x output (per tooth + gap) 0.3 Output (V) 0.2 0.1 0 -0.1 -0.2 -0.3 0 Figure 5. ABL01x output (per tooth + gap) Output (mA) 8 6 4 2 0 0 Figure 6. AKL00x output (one pulse/tooth) 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Illustrative Application Circuits Digital output from analog gear-tooth sensors A comparator can be used to provide a digital signal corresponding to each gear passing: 0.9 to 5.5 V Vcc Vcc 100 nF OUT+ OUT- GND GND ABL00x Sensor + OUT - TLV3691 Figure 7. Digital output from an analog sensor. If zero speed operation is not required, AC coupling the sensor remove offset induced by magnetic imperfections. Digital Speed and Direction Signals ABL01x dual-element sensors provide two outputs that can indicate direction of rotation. A dual comparator and flip-flop can provide direction and speed outputs. Direction is determined by detecting the phasing between the two outputs. The “Speed” output is one cycle per tooth: 3.3 V Vcc1 Vcc2 OUT-1 OUT+2 + OUT+1 OUT-2 D + MCP 6542 Q CLK 100 nF GND1 ABL01x GND2 - Direction SN74AU P1G79 Speed Figure 8. Digital speed and direction signals for gear-tooth sensors. 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com AKL sensor typical operation A single resistor in series with the sensor can detect the digital output. A 100Ω resistor provides a 400 mV peak-to-peak signal. VCC 6 Voltage Regulator 3.3V Switching Current Source GMR Bridge Offset Detector A EEPROM A Gain CurrentLevel Figure 9. AKL sensor test circuit. 5 IOUT VOUT GND Three-Wire Digital Gear-Tooth Sensor The two-wire AKL-Series can be easily converted to a three-wire interface: 5.2V - 36V 6 2.2K AKL00112E 2N2222 5 LED 100 Figure 10. Simple three-wire interface. When the current is 4 mA, the voltage across the 100Ω resistor is 0.4 V, which is not enough to turn on the transistor. With 8 mA, the transistor turns on. Note that the supply voltage must be at least 5.2 V to provide the sensor’s 4.5 V minimum Vcc. The LED is optional. 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com TTL Output Gear-Tooth Sensor The circuit below uses a simple comparator (7211 or similar) to convert the 4 to 8 mA AKL supply current to a rail-to-rail digital output. 5V Vcc AKL001 0.1 Gear- F 82K Tooth Sensor GND 4-8 mA 4 3 5 - 7211 + 1 0-5 V OUT 2 10 1M 1K Figure 11. TTL output gear-tooth sensor. The 10Ω series resistor is small enough to ensure the sensor Vcc voltage is above its 4.5 V minimum with a 4.75 to 5.25 V supply. The 1 KΩ and 82 KΩ resistors set a comparator threshold between 4 and 8 mA, and the 1 MΩ resistor provides hysteresis to enhance noise immunity. 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com ABL00X-XXE (single bridge) pinouts OUT+ Vcc NC NC NC NC OUT- GND Sensitivity TDFN6 (-10E suffix) Direction of MSOP8 (-00E suffix) OUT+ Vcc NC NC GND OUT- Pin MSOP8 8 4 1 5 2, 3, 6, 7 TDFN6 6 3 1 4 2, 5 Symbol VCC GND OUT+ OUTNC Description Power supply Ground Bridge differential output No internal connection ABL01X-XXE (dual bridge) pinouts GND1 VCC2 OUT1- OUT2+ OUT1+ OUT2- VCC1 GND2 Sensitivity TDFN6 (-10E suffix) Direction of MSOP8 (-00E suffix) GND1/ GND2 OUT1- VCC1/ VCC2 OUT2+ OUT1+ OUT2- Pin MSOP8 4 8 1 5 2 3 6 7 TDFN6 6 1 2 3 4 5 Symbol VCC1 VCC2 GND1 GND2 OUT1− OUT1+ OUT2− OUT2+ Description Bridge 1 power supply Bridge 2 power supply Bridge 1 ground Bridge 2 ground Bridge 1 differential output Bridge 2 differential output OUT1 and OUT2 are A/B phase shifted outputs. 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com AKL-Series Pinout VCC Voltage Regulator BRIDGE 3.3V Switching Current Source GMR Bridge Offset Detector A EEPROM A Gain Current Level GND TDFN8 Pin 6 5 4 7 Symbol VCC GND BRIDGE+ BRIDGE- 1, 2, 3, 8 Test Description Supply voltage Ground Bridge outputs (leave floating for normal operation) No connections should be made for normal operation 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Available Parts Part No. ABL004-00E ABL005-00E ABL006-00E ABL014-00E ABL015-00E ABL016-00E ABL004-10E ABL005-10E ABL006-10E ABL014-10E ABL015-10E ABL016-10E Part No. AKL001-12E AKL002-12E AKL003-12E Single or Dual Bridge Single Single Single Dual Dual Dual Single Single Single Dual Dual Dual Element Spacing 1 mm 0.5 mm 0.3 mm 1 mm 0.5 mm 0.3 mm 1 mm 0.5 mm 0.3 mm 1 mm 0.5 mm 0.3 mm ABL-Series Analog Gear-Tooth Sensors Phase Shift Between Recommended Recommended Bridges Gear Pitch Gear Module NA 1.7 − 6 mm 0.5 − 2 mm NA 0.8 − 1.7 mm 0.25 − 0.5 mm NA 0.5 − 0.8 mm 0.16 − 0.25 mm 0.5 mm 1.7 − 6 mm 0.5 − 2 mm 0.25 mm 0.8 − 1.7 mm 0.25 − 0.5 mm 0.15 mm 0.5 − 0.8 mm 0.16 − 0.25 mm NA 1.7 − 6 mm 0.5 − 2 mm NA 0.8 − 1.7 mm 0.25 − 0.5 mm NA 0.5 − 0.8 mm 0.16 − 0.25 mm 0.5 mm 1.7 − 6 mm 0.5 − 2 mm 0.25 mm 0.8 − 1.7 mm 0.25 − 0.5 mm 0.15 mm 0.5 − 0.8 mm 0.16 − 0.25 mm AKL-Series Digital Gear-Tooth Sensors Element Recommended Recommended Spacing Gear Pitch Gear Module 1 mm 1.7 − 6 mm 0.5 − 2 mm 0.5 mm 0.8 − 1.7 mm 0.25 − 0.5 mm 0.3 mm 0.5 − 0.8 mm 0.16 − 0.25 mm Package MSOP8 MSOP8 MSOP8 MSOP8 MSOP8 MSOP8 TDFN6 TDFN6 TDFN6 TDFN6 TDFN6 TDFN6 Package Marking Code FDB FDC FDL FDD FDF FDM FDG FDH FDN FDJ FDK FDP Package TDFN8 TDFN8 TDFN8 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Customer Support Evaluation and Demonstration Boards Inexpensive evaluation boards are available for the ABL- and AKL-Series GT sensors. AG920-07—GT Sensor Evaluation Kit Evaluate gear tooth sensors for measuring rotational speed with a variety of analog and digital GT Sensors, plus the DD001-12 stand-alone signal processing IC. A variety of PCB configurations are provided so the parts can be tested in different housing and barrel sizes, including the M8 housing. Biasing magnets are also included. AG921-07—AKL002 Gear-Tooth Sensor Demonstrator NVE’s AG921-07 evaluation kit is a self-contained demonstrator for NVE’s unique AKL digital gear tooth sensor. The batterypowered demonstrator (battery included) uses an AKL002 sensor to detect passing gear teeth. The demonstrator also includes a circuit board with an LED and driver, a biasing magnet, and a gear that can be turned by hand. No assembly required. Dimensions 3" x 3" x 1.5" (75 mm x 75 mm x 38 mm). Demonstration Videos NVE uploads regular new product and application demonstrations to Youtube; check out our channel: www.YouTube.com/NveCorporation Detecting tiny gear teeth with the ultraprecise ABL006: youtu.be/brDLly1L6aE ABL/AKL-Series GT Sensor oscilloscope demonstration: youtu.be/7R3qPD5lW2w Handheld AKL002 demonstration: youtu.be/sAA3ILHs7h4 Application Note Best practices and design support for NVE GT Sensors: https://www.nve.com/Downloads/SB-00-103_GT-Sensor-App-Note.pdf Design Assistance Web-Application We have a free web-based application to provide design support for ABL Series GT Sensors, including bias magnet selection. Enter your gear’s dimensions, then choose your sensor, bias magnet, and PCB thickness and view approximate sensor outputs for your system: https://www.nve.com/spec/calculators.php#tabs-GT-Sensor-Output 12 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Bare Circuit Boards and Magnets for Sensors PCBs NVE offers several bare circuit boards specially designed for easy connections to GT Sensors. Popular PCBs are shown below (images are actual size): 2 3 1 8 4 5 7 6 AG915-06: 0.25" (6 mm) octagonal MSOP8 AG918-06 (standard) / AG919-06 (cross-axis): 2" x 0.25" (50 mm x 6 mm) MSOP8 AG035-06: 1.57" x 0.25" (40 mm x 6 mm) TDFN6 Magnets NVE offers three standard ferrite disk magnets for use with GT Sensors: d t NVE Part # 12031 Material C5/Y25 Diameter (d) 8 mm Thickness (t) 3.2 mm 12216 C5/Y25 6 mm 4 mm 12217 C5/Y25 3.5 mm 4 mm 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Package Drawings MSOP8 (-00E suffix) 0.114 (2.90) 0.122 (3.10) 0.016 (0.40) 0.027 (0.70) 0.114 (2.90) 0.122 (3.10) 0.189 (4.80) 0.197 (5.00) 0.032 (0.80) 0.043 (1.10) 0.024 (0.60) 0.028 (0.70) 0.005 (0.13) 0.009 (0.23) 0.010 (0.25) 0.016 (0.40) 0.002 (0.05) 0.006 (0.15) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate TDFN6 (-10E suffix) 2.00 ± 0.05 0.80 MAX. 6 4 6 2.50±0.10 1.30±0.05 4 C0.10 PIN 1 ID 1 1 3 3 0.30±0.05 (6X) 2.50 ± 0.10 0.0-0.05 0.30±0.05 0.65 TYP. (4X) 1.30 REF (2X) 0.20 REF 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com TDFN8 (-11E suffix) PIN 1 INDEX AREA 0.75±0.05 4 4 1 1 6.00 ± 0.20 3.40 ± 0.15 Pin 1 ID 3.90 ± 0.15 5 8 5 5 0.65 ± 0.10 (8x) 4.900 ± 0.20 0.0-0.05 0.40 ± 0.05 (8x) 1.27 Typ. (6x) 3.81REF (2x) 0.75±0.05 MAX RoHS COMPLIANT All soldering profiles per JEDEC J-STD-020C, MSL 1. 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Revision History SB-00-061-C November 2019 Change • Clarified operating recommendations, updated customer support section. • Added a “Recommended Gear Module” column to the “Available Parts” tables on p. 11. SB-00-061-B July 2018 Change • Added E suffix to all part numbers in available parts table. SB-00-061-A March 2017 Change • Initial datasheet release superseding catalog. 16 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 17 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: sensor-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. November 2019 18 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com www.YouTube.com/NveCorporation sensor-apps@nve.com
ABL005-00E 价格&库存
很抱歉,暂时无法提供与“ABL005-00E”相匹配的价格&库存,您可以联系我们找货
