AD120-00
AD120-00
    NVECORP
    TSSOP8
    SENSOR MAG SW 28G STANDRD 8-MSOP
AD120-00 数据手册
AD-Series GMR Switches AD-Series GMR Switch™ Precision Digital Magnetic Sensors Functional Diagram Features • Digital outputs • Precision operate points from 1 – 8 mT (10 – 80 Oe) • 3 V – 6 V and 4.5 V – 30 V versions • 20 mA output drive • Temperature and voltage stability • Available with short-circuit protection • Standard or cross-axis orientation • Frequency response to 100 kHz • Ultraminiature TDFN6 and MSOP8 packages Vcc Short- Voltage Circuit Regulator Protection (optional) (optional) GMR Sensor Comparator Element Output Driver OUT Applications • Motion, speed, and position control • Pneumatic cylinder position sensing • Speed sensing GND Description AD-Series GMR Switches are the industry standard for sensitivity and precision. Idealized Transfer Function GMR Switches integrate GMR sensor elements with digital signal processing electronics. These sensors are more precise than other magnetic sensors, and magnetic field operate points are stable over voltage and temperature extremes. AD-Series models available in a wide variety of magnetic operate points and output configurations. Versions are available with short-circuit protection circuitry and with integrated voltage regulators. 1 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 Phone: (952) 829-9217 sensor-info@nve.com www.nve.com ©NVE Corporation AD-Series GMR Switches Absolute Maximum Ratings Parameter Supply voltage Symbol AD08x AD8xx/AD9xx All others Output voltage Continuous output current Operating temperature Storage temperature ESD Applied magnetic field VCC Min. −0.5 −0.5 −33 −0.5 −40 −65 B Max. 7 33 33 33 24 125 150 2000 Unlimited Units Test Conditions Volts Volts mA °C °C Volts tesla Human Body Model 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 Phone: (952) 829-9217 sensor-info@nve.com www.nve.com ©NVE Corporation AD-Series GMR Switches Operating Specifications Tmin to Tmax; 4.5 V < VCC < 30 V unless otherwise stated. Parameter Symbol Min. Typ. Max. Units Supply voltage VCC AD084 3 6 Volts All others 4.5 30 Operating temperature TMIN; TMAX −40 125 °C Magnetic operate point ADH025 0.8 1 1.2 AD004; AD021; AD621 1.5 2 2.5 AD024; AD084; AD824; AD924 BOP 2.1 2.8 3.3 mT* AD005; AD022 3 4 5 AD913 5 6 7 AD006; AD023 6 8 10 Operate/release differential ADH025 0.2 0.8 AD004; AD021; AD621 0.5 1.4 BOP−BREL AD024; AD084; AD824; AD924 0.5 1.5 mT* AD005; AD022 0.5 2.5 AD913 0.5 2.2 AD006; AD023 0.5 5 AD08x 0.7 1.2 1.8 3 2.5 4.5 4 6.5 AD0xx–AD7xx Supply (except AD08x) ICC 5.5 mA current 7.5 6.3 8.3 1.75 3.5 AD8xx/AD9xx 3 5.5 AD0xx–AD7xx 20 Output IO-ON mA current AD8xx/AD9xx 2 AD8xx/AD9xx 0.4 Sinking VOL output voltage AD0xx–AD7xx 0.2 V VCC–2 AD8xx/AD9xx Sourcing VOH output voltage AD0xx–AD7xx VCC–2.5 Output leakage current (output Off) IO-OFF 10 µA Short-circuit voltage (AD8xx/AD9xx only) VShort 0.12 0.17 V 5.8 6.2 AD4xx – AD7xx V VCC – 0.9 3.5 Regulator VREG output 5.8 6 AD8xx/AD9xx V VCC – 0.9 3.5 Regulator output (AD4xx – AD9xx) IREG 3 mA Frequency response fMAX 100 kHz Junction–Ambient Thermal Resistance 320 °C/W θJA Test Conditions VCC = 5 V; Output Off VCC = 5 V; Output Off VCC = 5 V; Output On VCC = 12 V; Output Off VCC = 12 V; Output On VCC = 24 V; Output Off VCC = 24 V; Output On VCC = 30 V; Output Off VCC = 30 V; Output On VCC = 12 V; Output Off VCC = 12 V; Output On VCC = 12 V; IO = 2 mA VCC = 12 V; IO = 20 mA VCC = 12 V VCC = 12 V Output On VCC >6.6V; 0< IREG 6.6V; 0< IREG
AD120-00
物料型号:AD-Series GMR Switches
器件简介:AD-Series GMR Switches是业界灵敏度和精度的标准,集成了GMR传感器元件和数字信号处理电子设备。这些传感器比其他磁性传感器更精确,并且在电压和温度极端条件下,磁场操作点保持稳定。
引脚分配:文档中提供了MSOP8和TDFN6两种封装的引脚分配图,例如MSOP8封装的GMR开关没有短路保护的引脚分配为:N/C(无连接)、Sink1、VCC、Source、N/C、Sink2、Vreg、GND。
参数特性: - 工作电压范围:3V至6V和4.5V至30V版本 - 输出驱动能力:20mA - 温度和电压稳定性 - 可提供短路保护(可选) - 频率响应高达100kHz - 超小型封装TDFN6和MSOP8
功能详解: - GMR开关在磁场超过设定的操作点时输出变为ON,在磁场下降至操作点减去释放差值时输出变为OFF。 - 具有全极性输出,即任何磁极的磁场都能使输出变为ON。 - 提供标准或交叉轴向的灵敏度选项。
应用信息: - 运动、速度和位置控制 - 气缸位置感应 - 速度感应
封装信息: - 提供超小型TDFN6和MSOP8封装选项
AD120-00 价格&库存
很抱歉,暂时无法提供与“AD120-00”相匹配的价格&库存,您可以联系我们找货
