CJ25-82010
CJ25-82010
    NIDEC(尼得科)
    JOYSTICK ENCODER 8 DIRECTION OUT
CJ25-82010 数据手册
CJ25 JOYSTICK ENCODER ■ FEATURES RoHS compliant ● Multi-function device … Joystick, optical encoder, and push switch functions in one package. ● Suitable size for panels. Smooth operational feel. ● Long life … Joystick 500K cycles, encoder & switch 1M cycles ● RoHS compliant ■ APPLICATIONS Operation panels for; ● Medical device ● Broadcast equipment ● Surveillance camera etc. ■ PART NUMBER DESIGNATION CJ25 - 4 20 1 0 Series name Interface 0:Connector Joystick Push switch function 4:4 方向 Directions 8:8 方向 Directions 1:With push switch Encoder 20:20 Positions (5P/R) ■ LIST OF PART NUMBERS Part number Joystick CJ25-42010 4 directions CJ25-82010 8 directions Encoder Push switch function Interface 20 Positions(5P/R) With push switch Connector CJ25 JOYSTICK ENCODER ■ STANDARD SPECIFICATIONS ● Electrical characteristics ● Mechanical characteristics Encoder Mounting Torque 1.17N · m maximum (12kgf · cm maximum) Input voltage DC5 V ± 5 % Actuator Strength 19.6N maximum (2kg maximum) Input current 20mA maximum at 5V Max. Shaft Pull-out Strength 98N maximum (10kg maximum) Incremental signal (Square wave) Max. Shaft Push-out Strength 98N maximum (10kg maximum) Output wave form Pulses Per Rotation 5P/R Maximum frequencies response 10Hz Encoder Click Torque Open collector,Pull-up resistor 2.2KΩ Output Output Code 2-Bit, Channel A/B,Phase difference 90° Output Signal High : 3.8V minimum Low : 0.4V maximum Output Sink Current 6 mA maximum Joystick Input current 5mA maximum at 5V Output Code 2-Bit (X,Y) Output Signal Neutral : 2.5±0.5V High : 4.5V minimum Low : 0.5V maximum Switch 9.8±4.9mN · m (100±50gf · cm) Clicks Per Rotation 20 Rotational Life 1 million cycles Joystick Angle of Throw All directions 9±2° Operating Force X,Y 1.47±0.74N (150±75gf) Joystick Life 500,000 actuation each in directions (X, Y) Switch Operating Force Stroke Rating DC5V, 10mA Switching Life 3.43±1.47N (350±150gf) 0.5±0.2mm 1 million cycles 10Ω maximum Contact Resistance Switching : 4ms make Non-switching : 10ms break Contact Bouncing ● Environmental characteristics Operating Temp. Range Storage Temp. Range 0°C ~ + 50°C −20 ~ 80°C ■ RELIABILITY TEST Test item Test conditions Vibration Power OFF Amplitude : 1.52mm or 98.1m/s2 (10G)whichever is smaller. 10 ~ 500Hz excursion 15 min/cycle, 8 cycles each for X, Z, directions. Shock Power OFF 3 times each in directions (X, Z) at 490m/s2 (50G), 11ms. Power OFF 80 °C 96 h Power ON 50 °C 96 h Power OFF − 20 °C 96 h Power ON 0 °C 96 h Humidity Power OFF (To be measured after wiping out moisture and leaving samples for 1 h at normal temperature and humidity after the test.) Thermal shock Power OFF To be done 10 cycles with the following condition (To be measured after leaving samples for 1 h at normal temperature and humidity after the test.) 80 °C 0.5 h、− 20 °C 0.5 h High temperature exposure Low temperature exposure (To be measured after leaving samples for 1 h at normal temperature and humidity after the test.) CJ25 JOYSTICK ENCODER ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.4 (Unit: mm) 14.65 PIN ASSIGNMENT Joystick"X" 2 Joystick"Y" 3 4 Power"+5V" Output"A" 5 Output"B" 6 Switch 7 Switch 8 GND Nut 18 0 -0.07 1 24 M17 P=1.0 ±0.1 〈Panel cut-out dimensions〉 φ1.5 +0.05 -0.1 JST PIN No.8 .1 .2 6.35 M17 P=1.0 4.44 14.5 ±0 17 φ 9.65 ±0.1 17.3 15.6 SM08B-GHS-TB 出力 Connector PIN No.1 3 0  -0.8 6.2 φ1.2 4 5. φ2 5.56 ±0.05 9.65 ±0.05 Locating pin Pivot point 15.8 ±0.1 1 〈Accessories〉 5.3 0 Function φ6.35 -0.07 Pin No. 16.4 ■ OUTPUT ジョイスティック ● JOYSTICK 各アングル説明 エンコーダ 出力波形 ● ENCODER Output Y(High) X (Low) 2.5V スイッチ 回路図 ● SWITCH Waveform Switch High X(High) A Low B Low High 1  2  3  4  5  6 Y(Low) Switch →CW Position number: 1∼6…(Clockwise rotation) Position "Y (High)" defined by locating pin. Output A B 1 ● 2 ポジション 1 2 3※ 4 3 A相 4 ● ● ● オプション(ワイヤーハーネス) ■ OPTION(Wire harnesses) ±5 ● ● ● ● =High blank=Low ● Code repeats every 4●positions. = High ※1∼4ポジション繰り返し 150 B相 空欄 = Low ■ OUTPUT CIRCUITRY AND RECEIVING CIRCUITRY 出力回路及び受け回路図 10 ±1 1 Joystick “X” Direction 2 Joystick “Y” Direction 3 1 2 3 4 5 6 7 8 (Br) (O) (R) (Y) (G) (Bl) (P) (B) Wire color Br: Brown O : Orange R : Red Y : Yellow G : Green Bl : Blue P : Purple B : Black Optional wire harnesses are available upon request. 4 5 2.2kΩ Power “+5V” Output “A” Output “B” 6 Switch 7 Switch 8 Output Circuitry 2.2kΩ GND Receiving Circuitry
CJ25-82010 价格&库存
很抱歉,暂时无法提供与“CJ25-82010”相匹配的价格&库存,您可以联系我们找货
