SPECIFICATIONS
PARAMETERS
MAXIMUM INPUT VOLTAGE
CAPACITANCE
SPL (0 dB=0.0002 BAR)
CENTER FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
DIRECTIVITY (-6 dB)
TERMINAL MATERIAL
WEIGHT
VALUES
UNIT
30
2100 20%
115
40,000 1,000
-20 ~ +70
-30 ~ +80
70
Sn PLATED COPPER
4.8
VRMS
pF
dB
Hz
C
C
grams
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
9
12.8
REVISION HISTORY
LTR
DESCRIPTION
DATE
RELEASED FROM ENGINEERING
6/1/2016
APPROVED
0.3
0.3
POLARITY (+)
0.8
0.05 (2)
NOTES:
4.5
0.5 (2)
8.5
0.3
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
4. DESIGNED FOR USE WITH THE UR-1240K-TT-R.
UNLESS OTHERWISE SPECIFIED:
All PURCHASES ARE SUBJECT TO AND
INCORPORATE THE PUI AUDIO TERMS
AND CONDITIONS SALE FOUND AT
http://www.puiaudio.com
/pdf/terms_conditions.pdf
(paper copy available upon request).
DIMENSIONS ARE IN MILLIMETERS,
TOLERANCES ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
UT-1240K-TT-R.idw
Designed by
Date
Checked by
Date
Approved by
Date
Drawn Date
M.V.
6/1/2016
M.V.
6/1/2016
B.R.
6/1/2016
6/1/2016
UT-1240K-TT-R
Ultrasonic Transmitter
Edition
Sheet
1/1
很抱歉,暂时无法提供与“UT-1240K-TT-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+54.97200
- 200+21.93480
- 500+21.20040
- 1000+20.84400
