UTR-1440K-TT-R
UTR-1440K-TT-R
    PUIAUDIO
    SENSOR-2P_D14.4X9MM_TM
    ULTRASONIC TRANSMITTER/RECEIVER
UTR-1440K-TT-R 数据手册
SPECIFICATIONS PARAMETERS DRIVE VOLTAGE CAPACITANCE ECHO SENSITIVITY DECAY TIME CENTER FREQUENCY DIRECTIVITY OPERATING TEMPERATURE STORAGE TEMPERATURE TERMINAL MATERIAL HOUSING MATERIAL WEIGHT 14.4 VALUES UNIT 140 1,800 15% 200 1.2 40,000 700 70 15 -40 ~ +80 -40 ~ +85 Sn PLATED COPPER ALUMINUM 4.8 VP-P pF THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING ADDED HOUSING MATERIAL 6/1/2016 6/7/2017 M.V. mV mS Hz C C grams 9 0.3 0.3 NEGATIVE (-) 8 5 1 12.5 0.5 POSITIVE (+) 11 2 1 0.3 0.2 0.6 0.05 (2) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. THIS PART MEETS IP65 WATER AND DUST INGRESS STANDARDS. UNLESS OTHERWISE SPECIFIED: All PURCHASES ARE SUBJECT TO AND INCORPORATE THE PUI AUDIO TERMS AND CONDITIONS SALE FOUND AT http://www.puiaudio.com /pdf/terms_conditions.pdf (paper copy available upon request). DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 UTR-1440K-TT-R.idw Designed by Date Checked by Date Approved by Date Drawn Date M.V. 6/1/2016 M.V. 6/1/2016 B.R. 6/1/2016 6/1/2016 UTR-1440K-TT-R Ultrasonic Xmr/Receiver Edition Sheet - 1/1
UTR-1440K-TT-R 价格&库存
很抱歉,暂时无法提供与“UTR-1440K-TT-R”相匹配的价格&库存,您可以联系我们找货
