979
979
    ADAFRUIT
    MAXSONARRANGEFINDERLV-EZ0
979 数据手册
SENSORS / PROXIMITY Maxbotix Ultrasonic Rangefinder - LV-EZ0 LV-EZ0 PRODUCT ID: 979 DESCRIPTION - LV-EZ0 Maxbotix Ultrasonic Rangefinder provides very short to long-range detection and ranging, in an incredibly small package. It can detect objects from 0-inches to 254-inches (6.45-meters) and provides sonar range information from 6-inches out to 254-inches with 1-inch resolution. (Objects from 0 inches to 6-inches range as 6-inches.) The interface output formats included are pulse width output (PWM), analog voltage output (Vcc/512 volts per inch), and serial digital output (9600 baud). A good sensor for when a Sharp IR distance sensor won't cut it. For example of using this with an Arduino, see the Halloween Pumpkin project. LV-EZ0 Data Sheet / Product Information Guide is available here. The different LV models have different beam width patterns, check this image for a comparison of all the LV model beam patterns. For higher sensitivity, check out the HR-LV models - they have up to 1mm sensitivity and 5 meter range! http://www.adafruit.com/products/979 7/27/2015
979
1. 物料型号:LV-EZ0 Maxbotix Ultrasonic Rangefinder。 2. 器件简介:该传感器提供从非常短到长距离的检测和测距,体积非常小。能够检测0英寸到254英寸(6.45米)的物体,提供6英寸到254英寸的声纳测距信息,分辨率为1英寸。 3. 引脚分配:文档中未提供详细的引脚分配信息。 4. 参数特性:传感器的输出格式包括脉冲宽度输出(PWM)、模拟电压输出(Vcc/512伏特每英寸)和串行数字输出(9600波特率)。 5. 功能详解:文档中提到,当Sharp红外距离传感器不足以满足需求时,这款传感器是一个很好的选择。例如,可以在万圣节南瓜项目中使用这款传感器与Arduino配合。 6. 应用信息:文档中提到了与Arduino的配合使用示例。 7. 封装信息:文档中未提供封装信息,但提到了不同LV型号具有不同的波束宽度模式,并提供了一个比较所有LV型号波束模式的图像链接。
很抱歉,暂时无法提供与“979”相匹配的价格&库存,您可以联系我们找货
  • 1+236.85231
库存:8
