980
980
    ADAFRUIT
    AIR GUN IONIZED AC 100/120V
980 数据手册
Page 1 of 3 SENSORS / PROXIMITY Maxbotix Ultrasonic Rangefinder - LV-EZ2 LV-EZ2 PRODUCT ID: 980 Page 2 of 3 DESCRIPTION - LV-EZ2 Maxbotix Ultrasonic Rangefinder provides very short to long-range detection and ranging, in an incredibly small package. It can detect objects from 0-inches to 254-inches (6.45-meters) and provides sonar range information from 6-inches out to 254-inches with 1-inch resolution. (Objects from 0 inches to 6-inches range as 6-inches.) The interface output formats included are pulse width output (PWM), analog voltage output (Vcc/512 volts per inch), and serial digital output (9600 baud). A good sensor for when a Sharp IR distance sensor won't cut it. For example of using this with an Arduino, see the Halloween Pumpkin project. Many applications require a narrower beam or lower sensitivity than the LV MaxSonar EZ1. Consequently, MaxBotix is offering the EZ2, EZ3, & EZ4 with progressively narrower beam angles allowing the sensor to match the application. LV-EZ2 Data Sheet / Product Information Guide is available here. Page 3 of 3 The different LV models have different beam width patterns, check this image for a comparison of all the LV model beam patterns. For higher sensitivity, check out the HR-LV models - they have up to 1mm sensitivity and 5 meter range! http://www.adafruit.com/products/980 7/27/2015
很抱歉,暂时无法提供与“980”相匹配的价格&库存,您可以联系我们找货
