502-14000
502-14000
    PARALLAXINC.
    Ultrasonic Sensor 40kHz
502-14000 数据手册
承 认 书 SPECIFICATION FOR APPROVAL 客 户 CUSTOMER 奥迪威料号 T/R40-14U0-01 AUDIOWELL P/N 品 名 超声探头 DESCRIPTION 客户料号 CUST P/N 日 期 DATE 超声波传感器明细 ULTRASONIC SENSOR SPECIFICATIONS 1. 型号 MODEL 2. 电性能明细 ELECTRICAL SPECIFICATIONS 3. 外观尺寸 DIMENSIONS 4. 测试线路 TEST CIRCUIT 5. 指向测试 DIRECTIVITY TEST 6. 环境特征 ENVIRONMENTAL CHARACTERISTICS 7. 测试条件及仪器 TEST CONDITIONS AND INSTRUMENTS 8. 测试报告 TEST REPORTS 承认 APPD. 承认章 COMPANY CHOP 客户签认 CUSTOMER APPROVAL 制作 DWN. 审核 CHK. 核准 APPD. 出图 DRAWING 注:承认书一式两份,请返回一份 PLEASE SENT ONE OF THE SAME TWO BACK 广州市番禺奥迪威电子有限公司 AUDIOWELL ELECTRONICS(GUANGZHOU)CO.LTD 广州番禺市桥镇迎宾路东升工业区 DONG SHENG INDUSTRIAL PARK,YINGBIN ROAD, PANYU,GUANGZHOU,CHINA TEL:(020)84871596 FAX:(020)84665207 Http://www.audiowell.com DRAWING NO.: TC09069 REV.: A1 P A G E : 1/7 PIEZO ■MODEL: ULTRASONIC SENSOR SPECIFICATIONS T/R40-14U0-01 ■ELECTRICAL SPECIFICATION: 1 Center frequency(KHz) 40±1.0KHz 2 Echo Sensitivity Decay Time ≥230mV (FIG1 SIMULATION TEST CIRCUIT) Directivity (deg) X-axis 120±15 Directivity (deg) Y-axis 70±10 Capacitance (pF) Allowable Maximum Input Voltage(Vp-p) Mean Time To Failure Operating Temperature(℃) Storage temperature(℃) 1800±15%(at 25℃,1KHz) 3 4 5 6 7 8 9 10 ■APPEARANCE ≤1.2ms (FIG1 SIMULATION TEST CIRCUIT) 140(40KHz) Pulse width 0.5ms, interval 20ms 50000h -40~+80 -40~+85 AND DIMENSIONS TO P V IEW BOTT OM VIE W X X Y Y 11±1 8±1 6.0±0.3 12.0±0.3 9.0±0.3 φ14.0±0.3 2-φ0.6±0.05 5.0±0.5 DRAWING NO.: TC09069 REV.: A1 AUDIOWELL ELECTRONICS(GUANGZHOU)CO.LTD http://www.audiowell.com PAGE: 2/7 ■ SIMULATION TEST CIRCUIT FIG.1 ■ DIRECTIVITY TEST 探头 测试插座 桌子 (接测试板) 管 FIG. 2 DRAWING NO.: TC09069 REV.: A1 AUDIOWELL ELECTRONICS(GUANGZHOU)CO.LTD http://www.audiowell.com PAGE: 3/7 ■ ENVIRONMENT CHARACTERISTICS CONDITIONS High and low temperature (from-40℃ to +80℃ at a relative humidity of 30%) STANDARDS Sensitivity shall not change by more than 30% all of the conditions. Humidity of 10% to 90% at the temperature of 25℃ Storage at +85℃ for 96 hours and at -40℃ for 96hours followed by a normalization period at 25℃. As shown in FIG.3. Operation at 95% relative humidity and 40℃ for 100 hours, followed by a normalization period of 24hours at 30% and 25℃.As shown in FIG.4. All sensitivity shall be within 30% of the specified values after the device is subjected to any or all of the conditions. Vibration at 10Hz to 55Hz ,1.5mm amplitude. 1 minute sweep. X,Y,Z,3 each axis for 3 hours. As shown in FIG.5 DRAWING NO.: TC09069 REV.: A1 AUDIOWELL ELECTRONICS(GUANGZHOU)CO.LTD http://www.audiowell.com PAGE: 4/7 ■ TESTING INSTRUMENT AND CONDITION LIST No. 1 2 Testing item Testing Equipment/Methods Testing conditions Resonant Frequency Piezoelectric Transducer Resistance Testing System II Testing temperature :25±2°C Echo Sensitivity According to Fig. 1 Test Circuit Distance to obstacle: 1 meter , Obstacle: organic glass board with 20CM*20CM*1.0CM 1.The inductance :8mH, Q m Value: 60-80, Pulse :20 2.The Minimum detect distance≥35cm 3.The acoustic system without coupling 3 Ring Time According to Fig. 1 Test Circuit The sensor surface is covered by 100mm thickness of sponge 1.The inductance :8mH,Qm Value: 60-80, Max Pulse ≤20 2.The Minimum detect distance≥35cm 3.The acoustic system without coupling 4 Directivity According to Fig.1 & Fig. 2 Test Circuit In normal room temperature, the distance to the ground: 55cm the distance to the obstacle: 50cm the obstacle: diameter of 50mm PVC pipe, the obstacle height: 1 meter Note: there is no other obstacle in a circumference of 1 meter. 5 Capacitance Digital LC ZL5 Testing temperature :25±2°C 6 Maximum Input Voltage(V p-p) According to Fig.1 Test Circuit Oscillograph: Pulse Width: 0.5mS, Interval :20mS Tektronix TDS1002 7 Mean Time to Failure Aging Equipment AWHY001 Testing temperature :25±2°C 8 Operating Temperature(°C) High-Low alternating temperature Cabinet In normal room temperature, according to the Fig. 4 test circuit 9 Storage Temperature(°C) High-Low alternating temperature Cabinet In normal room temperature, according to the Fig. 4 test circuit DRAWING NO.: TC09069 REV.: A1 AUDIOWELL ELECTRONICS(GUANGZHOU)CO.LTD http://www.audiowell.com PAGE: 5/7 ■ NOTE: 1. DESIGN RESTRICTION/PRECAUTIONS ■ This sensor is designed for use in air environment. Do not use it in liquid. ■ In the case where secondary accidents due to operation failure or malfunctions can be anticipated, add a fail safe function to the design. ■ In the case where this sensor is to be hold in housing, use soft buffer between sensor and housing. The front convex part of this sensor vibrates in large extension. If this part is hold, its characteristics will vary. The top must be free to vibrate. SENSOR THE FRONT PART HOUSE HOUSE SOFT BUFFER 2. USAGE RESTRICTION/PRECAUTIONS: ■ To prevent sensor malfunctions, operational failure or any deterioration of its characteristics, do not use this sensor in the following, or similar conditions. a) In strong shock or vibration. b) In high temperature and humidity for a long time. c) In corrosive gases or sea breeze. d) In an atmosphere of organic solvents. e) In dirty and dusty environments that may contaminate the sensor front. f) Over specified allowable input voltage(Vp-p) ■ Do not solder adding stress on outer lead, also do not apply stress like spin or pressure just after soldering. In case you form the leads, support the root firmly. 3. WARRANTY: ■ Period Warranty period is three years after delivery. ■ Scope Defective sensors attributable to manufacturer’ responsibility shall be replaced for free during the warranty period. However, following cases are out of the scope. a) Unsuitable handling or misuse by user. b) Modification or repair by user. c) Any other cases not due to manufacturer’s responsibility such as natural calamity, accident .etc. This scope covers only replacement. Any loss derived from failure or malfunction of the sensor, or cost on replacing is excluded from this warranty scope. DRAWING NO.: TC09069 REV.: A1 AUDIOWELL ELECTRONICS(GUANGZHOU)CO.LTD http://www.audiowell.com PAGE: 6/7 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Parallax: 502-14000
502-14000 价格&库存
很抱歉,暂时无法提供与“502-14000”相匹配的价格&库存,您可以联系我们找货
