28032
28032
    PARALLAXINC.
    Module
28032 数据手册
Wide Angle PIR Sensor | 28032 | Parallax Inc Equip your genius ® Microcontrollers News Tutorials Robots Forums Teach Support OBEX Home › Sensors › Infrared › Wide Angle PIR Sensor Wide Angle PIR Sensor Product ID 28032 Company Overview Similar in functionality to the PIR Sensor (#555-28027), the Wide Angle PIR Sensor features a larger detection angle of 180˚. This makes it ideal in applications where users need to track movements across a large, open area. The Wide Angle PIR Sensor is a pyroelectric device, and it detects motion by sensing changes in the infrared levels emitted by surrounding objects. When motion is detected, the Wide Angle PIR Sensor outputs a high signal on its output pin. Key Features: 180˚ detection angle for widespread motion detection Detects movement up to 30 ft away User-selectable "night-time mode" for detecting motion in decreased lighting conditions Adjustable sensitivity to tune for different operating conditions 4-pin SIP package perfect for breadboard-friendly projects Small size and mounting holes for easy concealment Application Ideas: Motion-activated nightlight Alarm system Holiday animated props Forums Home Learn Propeller Object Exchange (OBEX) Parallax Semiconductor Newsletter Sign-Up Details Voltage requirements: 3.0 to 6.0 VDC Current requirements: 150 uA idle, 3 mA active (no load) Communication: Single-bit high/low output Dimensions: 1.42 x 1.42 x 0.79 in (36.0 x 36.0 x 20.2 mm) Operating temperature range: 32 to 122 °F (0 to 50 °C) Additional Resources PIR Sensor (Rev B) Forums Learn Propeller Object Exchange (OBEX) Home Contact Us 888-512-1024 Parallax Semiconductor Newsletter Sign-Up Job Opportunities Policies Twitter Feed #TCEA14 continues through Friday. Please come visit our Education Team in Booth 508. http://t.co/H7RL2XLAXn #STEM RT @MrGoberTX: Andy Lindsay Equipping Genius with @ParallaxInc at #TCEA14 #STEM #robotics #edtech http://t.co/TnRzsuE5KG 'Microcontroller Shootout – Parallax Propeller' via HackShed http://t.co/3FntavJdfI http://www.parallax.com/product/28032[2/5/2014 2:07:04 PM]
28032 价格&库存
很抱歉,暂时无法提供与“28032”相匹配的价格&库存,您可以联系我们找货
